Question about HP Pavilion dv9000z Notebook
HP DV 9000 bad motherboard_will not power up.
I have an HP DV 9000 and I do know for a fact that the motherboard needs to be replaced. I have the issue where it will try to power up briefly but then blinks off and tries to power up again then blinks off. It will repeat this cycle but never power up.
I have found the exact motherboard I need to replace the one I have but there is no guarantee that the problem will not come back since all the motherboards of that particular model had the same problem. I'm wondering if there is another motherboard that can be used instead of going with the exact motherboard. Is there a way to cross reference and perhaps use a different motherboard? Thanks for any insight.
  • Barrett Canning Nov 16, 2009
    Followed the steps you described today and am currently typing this response with my fixed laptop. Thanks for clear easy to follow advice.
  • 458 Answers
It is fixable without having to replace the motherboard...
I repair these on a weekly basis, It's a common issue with All DV9000 and DV6000 Series Laptops...
Your Issue Is The GPU/Graphics Chip, The Chips have overstressed due to Overheating..
The Fix is to Reflow the Graphics Chip Back Down To The Motherboard..
Reflowing is the heating of the graphics chip.. either by infrared or by a heat gun.. The chip needs to be weighted.. Use 8 Quarters, place the Quarters on top of the center of the chip, Cover any plastic plugs on the motherboard, Cover the CPU, Cover the RAM area.. Use A Heat Gun, set it to Low.. Hold it 6 inches from the chip, Go in slow circles around the stack of quarters-pointing the heat gun at an angle towards the edge of the graphics chip.. very slowly move the heat gun closer, NO CLOSER THAN 2 Inches away!! then pull it back to 6 inches away after about 30 seconds (moving in circles around the chip the whole time)..
This whole Reflow Process will take aprox. 2 minutes..DO NOT OVERHEAT the chip, the chip needs to get hot enough to melt the solder balls on the underside of the chip.. 2 minute max on the heat gun will do fine.. Leave the stack of quarters on the chip for 5 more minutes after shutting off the heat gun... This will allow the chip to safely cool-without cooling too quick... Then make sure you have a good thermal pad between the chip and the heatsink/fan assembly... Reassemble and power on..
Posted on Nov 15, 2009
Testimonial: "Great advice. I'll be sure to try this. Thank you."
I have HP DV9000 laptop when i switch on it powers but the display is like in safe mood i cant see anything
i am mr john uche aaron
in Nigeria ,
my hp pavilion dv 9000
cannot bootup
but display only light on the quick bar
and blank screen
what is the solution
Dec 12, 2010 | HP Pavilion dv9000 Motherboard
I'm having problems starting my HP Pavillion dv 9000. When I press the power button I can hear it trying to start, the quickplay blue lights come on and then the computer shuts off and tries to start...
99% sure you have suffered a motherboard failure. This particular failure is common for the DV series of HP laptops. There is an Nvidia chip that sits next to the processor and this chip is resposible for many things that go on with that particular laptop and in laymens terms....the solder that binds the connections of that chip to the motherboard comes loose from excessive heat that builds up in these models. The motherboard needs to be "Re-Flowed" in order to complete the connections once again. Do-it-yourselfers have been doing it with a heatgun and there are several videos of this on youtube. I have even done successfully 75% of the time.
Jun 10, 2010 | HP Pavilion dv9000t Notebook
My hp pavillion dv 9000 will not turn on, it is plugged in and the charge light is on, but it will not turn on. I have tried taking the battery out and just using the outlet, but that doesn't work either.
The power supply could be the problem.
The fact that some light go ON, doesn't mean its working properly.
Another reason could be the memory.
Sometimes they get bad as well.
Remove all the memory from your computer.
You will hear a sequence of beeps.
If there is no beeps, then power supply for sure.
A replacement will bring back joy.
Don't forget to rate this answer if it helps.
Dec 04, 2009 | Computers & Internet
PAVILION DV 9000 wireless card bios system
I've ran into that defect repairing these laptops and its a crappy motherboard issue, my wife daughter bought her pavilion dv 9000 over and i put my wireless card that was working in hers and it wouldn't even see that one.
The motherboards are junk and all HP is doing is replacing it with updated ones that doesn't have that problem with the faulty wireless card slot.
Sep 02, 2009 | HP Pavilion dv9000z Notebook
BLANK SCREEN HP DV 9000
Run system restore to factory default.
Start the system and hold down the f11 key till you hear a beep. Then follow the onscreen instructions.
Good luck.
Aug 23, 2009 | HP Pavilion dv9000z Notebook
Blank screen
Please, we need to have what you have submitted, but also need to know what and how this all happened in your own words. As soon as I get the info, I will begin to work. Thank you for considering our service...
My name is Constantin (arzconst)
May 24, 2009 | HP Compaq Motherboard
My hp pavilion dv 9000 does not start.
Hard drives are cheap. Find out what type of drive this supports (i.e. ATA or SATA), and buy a new drive. They're quite easy to replace, too. You'll just need a recovery CD to re-install your OS (operating system) after you put in your new drive.
Jan 03, 2009 | HP Pavilion dv9000z Notebook
Hp dv9000 will not start up. blue lights are go
you get a black screen right, nothing at all then no bios, no logo, nothing at all?
Do you get any beep codes and if so in what order?
did you try different ram?
First try to plug your laptop to an external monitor. If it works, you screen is bad, if it doesn't you probably need a new motherboard.
Dec 23, 2008 | HP Pavilion dv9000z Notebook
Laptop hp wont fire up hp DV 9000 pavillion 17 inch
Please add more details to your question. when you press the start button what happens. are you getting the boot screen... after that what happens
Robert
Aug 28, 2008 | HP Computers & Internet
HP Pavilion dv9000z Notebook Logo
537 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
