Question about Passport 9500i Radar/Laser Detector
When I connect the chord to cigarette plug, the red and green light appear for a moment and the passport does not come on. I have tried this in two vehichles..please advise
  • 3,489 Answers
Its the circuit board. if you saved the receipt, take it back and exchange it. if you have any paperwork on it, it should give you a toll free number to call the company.
Posted on Nov 15, 2009
    Top Expert:
  • 80,339 Answers
Ther is a fault in the radar detector, have it repaired.
  • 11,896 Answers
Try slightly turning the plugin in the the lighter socket. Some of these are touch. Or try to take the metal prongs on the plugin and gently pry them outwards just a bit for a better connection.
  • Nate Stansfield
    Nate Stansfield Nov 15, 2009
    you can also get similar plugins on amazon.com and newegg.com
    Just make sure the plug-in ends are same size and the DC Voltage Output is the same as well.
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
Im trying to connect my hp pavilion laptop to my 2003 Sony trinitron color tv KV24FS100
Hi gg_fan_03
Between your laptop and the TV ,
• you may need a PC to TV Converter
like one of these:
http://sewelldirect.com/pc-to-tv.asp
instruction is on the web page.
• to enable on your laptop, set your Sony TV as secondary monitor.
• use the Video driver control panel.
Sep 11, 2012 | Sony FD Trinitron WEGA KV-24FS100 24" TV
The DP26649 model TV has three inputs; video one (which is fine and has all color and everything), video 2 (if you plug them in certain ones the best i can get is full sound and all but its black and...
OK, here is the breakdown on whet you are doing wrong.
Video 1 - Composite -
Video - Yellow
White - Audio In - Right
Red - Audio in - Left
Video 2 - Components - HD - RGB = Red, Green, Blue
Video -
Red - Red Colors
Green - Green Colors
Blue - Blue Colors
Your GameCube will only work on Video 1, unless you buy an HD (Component cable). You will need to buy HD cables for your device connected to Video 1 to work on video 2. I will assume it is a DVD player. This is a high definition cable to produce a better picture. Let me know if you do not completely understand
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 06, 2011 | Televison & Video
320 GB Passport External HD recognized as drive F get i/0 error when try to access I have tried other usb ports with same results tried 2 different chords with same results Is this just toast?
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
May 24, 2011 | Western Digital Passport 320GB External...
Can I join green and red power leads to a single power source?
Yes, but it will be on all the time, when the green is connected the kit will start to search for the phone and when power is removed it will turn off.
Dec 04, 2009 | Motorola Mobility Bluetooth??¢ HF850 Car...
I need to switch my three prong power chord to a four prong
your terminal block on the dryer will have three screws in a row and there will be a green screw on the outer skin next to the terminal block cover - your four-wire cord will have a white wire, red, black and green wires - white wire goes on the center screw of the terminal block, red wire goes on one of the other screws of the terminal block, it doesn't matter which, black wire goes on remaining terminal block screw, green wire goes to the green screw
Aug 17, 2009 | Dryers
Lowrance 350 wont turn on
Plug it in. Is there a green or red light on the iWay 350? If red, it will probably turn on now while plugged in and just needs to be charged. If it won't charge, it is malfunctioning. If no lights come on when plugged in, the 350 is malfunctioning.
Does the green light come on the cigarette lighter adapter? If not, the fuse in the cig adapter is blown or the power cable needs to be replaced.
I
Jul 13, 2009 | Lowrance Boating
When I plug in the router my power light never goes green.
try getting another router, had it been the chord you wouldn't have had any light at all.
what kind of router is it ??
Mar 22, 2009 | 2wire Computers & Internet
Passport 9500i Radar/Laser Detector Logo
118 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
Jason
Steve
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
