Question about AK Mobile Dash Smartphone
I can not find the cincinnati bell wap settings or can't get them to work on my unlocked t-mobile dash
I need an unlock code for nokia 6086 locked to cincinnati bell imei:354811010096438
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Aug 03, 2012 | Nokia 6086 Cell Phone
Need puk code cincinnati bell i wireless motrola
Instructions
    • Contact Cincinnati Bell Wireless customer service from another phone by dialing 1-888-391-3925. Ask to speak with a customer-service representative.
    • 2 Inform the representative you need to switch service providers and need the correct code to unlock your phone from the network. You do not need to specify a reason. Keep in mind that Cincinnati Bell does not have to release the code, but generally, if you are moving to another location not covered by Cincinnati Bell, the company will release the code.
    • 3 Give the representative the make and model of your phone, along with the IMEI (International Mobile Equipment Identity) number. You can obtain your IMEI number by pressing #06#. The representative will retrieve and divulge the unlock code.
    • 4 Put the SIM card from your new provider into your phone and turn it on. The screen will automatically ask for the unlock code. Input the code to unlock it, and your can begin using the phone.
Courtesy: How to Unlock a Cincinnati Bell Wireless Phone ' eHow.com http://www.ehow.com/how_7652326_unlock-cincinnati-bell-wireless-phone.html#ixzz1jmmG9z4v
Jan 18, 2012 | Motorola Lands Phones
Need to unlock my dell streak 5 phones lock by at&t but need unlocked for t mobil .
Unlocking your Dell Streak 5 from AT&T is easy but if you use it on T-Mobile, only 2G will work and not 3G. However, if you get a Dell Streak 5 locked to Cincinnati Bell and unlock it, it WILL work on T-Mobile 3G.
How to unlock Dell Streak 5: http://www.unlockstreak.com/pages/download-dell-streak-unlock-software
Cincinnati Bell Dell Streak unlock info (if you need this):
Aug 01, 2011 | Cell Phones
When i turn my phone on it says input NP code, I have went to the store I bought it from they have never heard of such code I called cincinnati bell they said call motorola i called motorola they said call...
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Jun 01, 2011 | Cell Phones
I have cincinnati bell wireless and need the wap,mms and text settings so i can get on the internet on my lg ke850 prada phone(unlocked)
Homepage: http://wap.gocbw.com
Connection Type: HTTP with proxy
IP address:216.68.79.202
Port number:80
access Point: CBW internet
Hi, i have the same phone unlocked and everything, those are the WAP settings, i haven't been able to find the MMS settings, if you find them it'd be awesome to email me them dmuddrunner@yahoo.com.
i hope this helps.
Oct 25, 2009 | LG Prada KE850 Cellular Phone
How do i unlock the sidekick slide for cincinnati bell?
I don't believe there is a way to unlock your phone. Most cell phones are made specifically for a certain network, in this case being T-Mobile. The only way to get a Sidekick to work on another network is to buy a Sidekick is to buy one from the other company.
Jun 21, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Roaming doesnt work
Try typing *228, and send. Select option 2 -- updating your roaming capibilities. The phone will go through a sequence of unlocking and reprogramming...DO NOT SHUT THE PHONE OFF DURING THIS PROCESS. It only takes a couple of minutes...or less...and will notify you that the phone was successfully updated. I had a similar problem a couple of years ago, and this seemed to solve it. Good luck!!
Jun 10, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Tmobile Dash with ATT number and sim card
Go to start-settings-connections-gprs: Delete the T-mobile settings. Create a new connection labeled MediaNet Connects to: The Internet Access Point: wap.cingular
Go to start-settings-connections-proxy: Delete the t-mobile settings. Create a new proxy called Cingular WAP Connects From: The Internet Connects To: WAP Network Proxy: wireless.cingular.com:80 Type: HTTP
Nov 06, 2008 | T-Mobile Dash Smartphone
Nokia unlock code
go this link they will open for you
www.unlockinglab.com
Mar 02, 2008 | Nokia Consumer Headset
AK Mobile Dash Smartphone Logo
56 people viewed this question
Top AK Mobile Cell Phones Experts
William Alequin
Are you an AK Mobile Cell Phone Expert? Answer questions, earn points and help others
