Question about Panasonic CQ-DF201U CD Player
Wont powewr up
No black ground wire
  • 2,039 Answers
Our metal housing of the radio is our ground metal of the car to housing of radio put a faily big wire cheers
Posted on Jan 14, 2008
Wiring a Stark 220V 1.5 HP pool pump
you cant run a 220 pump on 110.. thats what youhave..need a 220 circuit to do this..the black is hot.. the white is neutral and the ground goes to the casing of the appliance but this wont run .. you need a 4 wire line..black/red/white/and earth ground(bare wire)..220
Dec 22, 2013 | Pool & Spa
Engine wont fire....
There should be 1 black wire that grounds the coil(s) for kill. Be sure this black wire is not grounded when switch is in on or start position. It will be connected to the coil(s) at the flywheel.
Feb 10, 2013 | Snapper 21 hp* Briggs & Stratton...
Wont turn on i bought it though craigslist
well this is what you do to check it to see if you bought a blown amp.
wire it into your car and then take a digital volt meter check to see if you have power and ground and remote turn on .
take the red lead and put it on the battery wire at amp and the black lead to the ground then see if you get 12volt to 14.4 use the amps ground for the black test lead if nothing you may have blown fuse or bad ground.
check the remote wire same way as about if you get 12 to 14.4 volt it works if not could be blown from radio or bad ground
checking the ground put the black meter lead on ground wire and the red lead on 12 volt power source if nothing a bad ground.
if your get voltage on the remote wire and battery wire and have good ground then you need to call the seller and get your money back ..
Oct 16, 2010 | Eclipse EA3422 Car Audio Amplifier
Need a wiring diagram for a sony cdx-gt08 it is going into a 2000 saturn sl2 I have the new wiring harness but need to know what wires go where
yellow to yellow main power wire
red to red key wire
black to black ground
speaker wires are green purple for rear speakers and white and grey for front speakers solid wire color is power and black lines is ground
orange is dimmer switch you wont need it
blue wire is for power anntenna your car shouldn't have it and blue with white stripe is remote wire if you have an amp it will shut off your amp when hooked up any other wire unnessary for your car some head units need a anntenna adapter to work good luck. remember ground before anything and disconnect the battery so you don't blow the fuse
Mar 13, 2010 | Sony XPLOD CDX-GT200 CD Player
I connected yhe power and ground wires but the radio wont turn on
Hi
1. Try with the ignation switch in ON position.
2. Check if wiring is correct i.e. Red wire to wire and Black to ground.
3. Check the fuse.
Regards
Berry
Feb 04, 2010 | 2006 Hyundai Sonata
The windows wont roll down, the auto lights dont work, the door locks wont lock, the remote mirrors wont work,
There is a black ground wire in the door that is a bit thicker than the others. This has a tendency to break after time. You need to cut the casing where the wires are, strip down the black wire coating and reconnect the wire. Then either sodder or tape the wire up and you will be just fine.
Free and easy way to fix the problem.
Dec 30, 2009 | 2004 Jeep Grand Cherokee
Dvd player while driving
he is right to an extent i have installed many of these the yellow black wire off the rca harness you have to pull the pin out of the harness and move it up one space and ground it out just an fyi if you vss wire is connected it wont work either let me know if you have any other questions
Sep 12, 2008 | Pioneer AVIC-D3 Car DVD Player
1998 Pontiac Sunfire
check wiring harness if head lights are dim ussually wire harness near washer bottle of infront of rad broken wires.
Sep 05, 2008 | 2002 Pontiac Sunfire
Panasonic CQ-DF201U CD Player Logo
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
