I have a Mitsubishi Big Screen TV that is about 20 years old. There seems to be a problem with the PIP. The entire middle of the TV screen goes black, you can see the outside edge of the program in the background and can hear the programing just fine. If we hit the PIP button the screen will temporarily return to normal, then go black again. I do not have an owners manual, the TV was given to us. I have tried unpugging the whole unit, waiting and turning it back on but that does not work. Do you have any troubleshooting suggestions?
  • 145 Answers
I have the solution. common problem. it has a pip module with defective (leaky) capacitors. they are surface mount capcitors. mcm has a mitsubishi pip module repair kit order number 32-11755 $14.95. 1800 543-4330 customer service 1877626-3532. www. mcminone.com
Posted on Nov 17, 2009
Testimonial: "Thank you so much, I have not been able to find parts information or even a repair number to call anywhere. This is great! Thanks again."
Mitswubishi VS-5077 TV - Display would work and flicker to black screen. We would wait awhile try again.....picture would work and then flicker and go to black screen. Now black screen w/ only volu
The most common issue here in the old sets is bad solder connections--the problem is you have to get the entire chassis free and up so bottom of boards face rear of set---look to power supply---a lot of 2 and 3 lead parts there from heat come loose from the boards and also to the middle of the set on the middle board.
If you are not able to attempt this the set is too old for a shop repair in my view as many parts for it are no longer available.
Nov 04, 2012 | Mitsubishi VS-5077/78 TV
I have a vs-60609 60"
Sounds like a Picture in Picture screen popping up, but if you do not have a signal from another tuner, it will be blank.
Try hitting the PIP button on your remote to see if it turns it off and on.
Plus go into the tv menu and find the PIP settings.
Apr 15, 2011 | Mitsubishi VS-60609 60" Rear Projection...
White dots are showing up on the screen. They are multiplying quickly. I was told to clean the filter but that did not help. The lamp is less than a year old. Nearest dealer is 2 states away. How can this...
This problems is the tv Projection Light Engine design flaw with it IC chip.These problems happen to many models of it DLP tvs Big Screen 60 and up.Mitsubishi,Samsung,Sony,Toshiba all used the same IC chip on their 60 and up on their DLP tvs Big Screen.Tries make deal with Mitsubishi help u split the cost of repair the tv Projection Light Engine by replacing the IC chip or replaced the entire Projection Light Engine system.This problems is not new,been going on for a few years.Many people when on Youtube **** about this problems with white dots showing up on their tvs screens and multiplying rapidly.
Nov 20, 2010 | Mitsubishi WD-73734 73" Television
Hi, I have an old CRT TV and it is 20 years old. Yesterday when i switched on the TV, It was fine. After a minute, the entire screen turned orange. Service folks said that there is a short...
ok on the crt the board that it goes on the tube take the cover off on the middle there is a board its attack to the tube solder it all 80% soldering on this board the 20% on the chassis board from the buttom the video or the color area soldering its only a soldering problem there are no bad parts on it
Oct 17, 2010 | Televison & Video
Big Screen Projection receiver TV vertical pincushion problem
the aliment is out need a profession to adjust it for you
Jul 24, 2009 | Televison & Video
Scrolling picture on an old big screen
These models have been known to have faulty capacitors on the PIP module as a result thy loose vertical synvh and the picure will roll. The PIP module is no longer available. But if you would like I can post a way for you to bypass the module and if the modle is at fault your tv will work fine, but you wont have PIP anylonger
Feb 23, 2008 | Mitsubishi VS-60719 60" Rear Projection...
Entirely black screen Mitsubishi Model CS40503 SER. 530082
  1. YOU WILL NEED TO CHANGE
  2. Q6c2
  3. Q291
  4. D251
  5. CHECK MOUNTING OF PIP-PCB TO MAIN-PCB
Nov 25, 2007 | Mitsubishi CS-40503 TV
Televison & Video Logo
123 people viewed this question
Top Televison & Video Experts
Electro Med Services...
