Question about Car Audio & Video
The odometer and speedometer work intermittenly
  • gaide Nov 16, 2009
    I replaced the speed sensor but it has not solved the problem. Any other ssuggestions.
    Changing the sensor didn't work so I changed the head and that solved the problem.
    Top Expert:
  • Car Audio & ... Master
  • 76,164 Answers
The most common cause of this is a defective vehicle speed sensor followed by a defective speedometer, either can cause the problem, u don't say year or model or type of vehicle so that is about all i can offer.
Posted on Nov 17, 2009
  • 6,826 Answers
The speed sensor is going out most likely,Do not know year make or model,but just the same,you most likely have a speed sensor that controls the speedo,so replace it,and you should be fine.I hope this was helpful,and you can find this part at the auto parts store,let us know if this was helpful in any way at all,thank you.
Posted on Nov 15, 2009
  • Ronny Bennett Sr.
    Ronny Bennett Sr. Nov 16, 2009
    I am sorry,but the speedo itself is most likely the problem,if you remove it ,see if the connection on the back is tight and making good contect,and if it is,replace the speedometer.
My speed ometer and odometer stoped working in my 93 jaguar
To troubleshoot the issue.Few related help links are provided with solved solution.Click the link below and go through the procedure:---Speedometer/ odometer Display Resets? http://howtobyme.blogspot.in/2012/05/2000-toyota-avalon-speedometer-odometer.html
---------Speedometer works Intermittently? http://howtobyme.blogspot.in/2012/05/2005-lexus-gx470-speedometer-works.html
How to trouble shoot speedometer?
http://schematicsdiagram.blogspot.com/2011/06/speedometer-not-working.html
-------Speedometer works but odometer not working? http://technoanswers.blogspot.in/2012/01/speedometer-works-but-odometer-not.html
------- Speedometer runs backward? http://technoanswers.blogspot.com/2012/01/speedometer-runs-backward.html
--------Speedometer not working on 1993?
http://repairhelpcenter.blogspot.in/2012/02/speedometer-not-working-on-1993-ford.html
These will help.
Thanks.
Jun 19, 2012 | 1993 Jaguar XJ6
Speedometer doesn't work
For speedometer related issues,the help links are provided below.Click the link below to go through its details :----
why speedometer not working? http://technoanswers.blogspot.com/2012/01/1996-fiat-bravo-speedometer-not-working.html
Speedometer works but odometer not working? http://technoanswers.blogspot.in/2012/01/speedometer-works-but-odometer-not.html----------- Speedometer runs backward?
Warning lights on and speedometer died?
http://howtobyme.blogspot.com/2011/08/warning-lights-on-and-speedometer-died.html
ABS & Brake lights warning indicator steady on dash and speedometer not working?
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
Vehicles Cluster panel Not reading Miles?
http://schematicsdiagram.blogspot.com/2011/12/vehicles-cluster-panel-not-reading.html
Odometer works properly but speedometer works intermittently? http://technoanswers.blogspot.com/2012/01/odometer-works-properly-but-speedometer.html
How odometer works in cars?
http://technoanswers.blogspot.com/2011/11/how-odometer-works-in-cars.html
Speedometer not working on Ford?
This will help.
Thanks
Feb 14, 2012 | 1996 Plymouth Voyager
Which fuse do i replace for the speedometer?
For speedometer related issues, the help links are provided below. Click the link below to go through its details: ----
Speedometer works but odometer not working? http://technoanswers.blogspot.in/2012/01/speedometer-works-but-odometer-not.html ----------- Speedometer runs backward?
This will help.
Thanks
Feb 04, 2012 | 1999 Ford Windstar
Where is the speedometer sending unit located
This will help.
Thanks
Feb 03, 2012 | 1993 Ford F250
The speedometer does not work
This will help.
Thanks
Feb 02, 2012 | 1998 Chevrolet S-10 Pickup
What does it mean when the speedometer goes out?
This will help.
Thanks
Feb 02, 2012 | 2000 Dodge Intrepid
2009 digital speedometer problem yamaha
This will help.
Thanks
Feb 01, 2012 | 2011 Yamaha XJ6 Diversion ABS
Odometer inop and speedometer erratic over 50mph
Yes your speedometer, and odometer are controlled by your speed sensor.
May 20, 2009 | 1993 Saturn SW1
Tach and speedometer work intermittenly and sometimes trans doesnt shift until 4500 rpm. vw cabrio 1999 automatic.
Good question! My Cabrio's odometer works only when the outside temps are really cold... that means about freezing temp. My VW repair shop guru guy says that the Cabriolet is notorious for this failing. Since the odometer is driven through a small gearbox via the speedo cable, I suspect the odometer "transmission" is mostly kaput. The tach is also mechanically driven so it also may have a semi-functional cable. The only way to really know is to pull the cable and check it for damage. As far as the trans goes have you tested it for codes?
Sep 15, 2008 | Volkswagen Cabrio Cars & Trucks
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
