Question about Zanussi 10.31 cu. ft. / 292 liter Chest Freezer ZCF106A
We have an Amana fridge with the freezer on bottom
The freezer is not working, the food is totally thawed out, it is cool so far, we took the back off and vacuumed every thing out, and the front, then flipped the breaker to reset it, also it makes a rhythmic noise a buzzing/humming like it is trying to kick on but cant? I put thermometers in, the fridge is now 58 and the freezer is 52, dont know hwo accurate these are though, if we knew what part to replace, we could do it.....
    Problem Solver:
  • 7 Answers
Compressor may be locked up
Posted on Jan 17, 2008
Demo icon is on and some food wind stay frozen
if the machine has been put into 'Demo Mode' the cooling stops working. It is a special setting for when the unit is on the sales floor.... What is the model number and brand?
For Kitchen Aid the way to end DEMO is to hold the 'max cool' and 'cooling on/off' for several seconds until the control beeps...
Apr 12, 2016 | Freezers
Top shel and top door shelfs are not freezing food solid ... Bottom freezes , all food on top portion thaws
you may have ab ad fan inside the cooler and all of the cold air is staying at the bottom. Also there may be bad insulation at the top and there may be warm air up there.
Jan 11, 2016 | Amana 20.1 cu. ft. Frost Free Upright...
Freezer temperature keeps climbing thawing out the food.
Check the thermostat, and the cooling fluid.
Tao the thermostat en see if it will start the compressor. When you hear the compressor running and still no cooling, you must have lost the cooling fluid. (used to be freon)
Mar 07, 2015 | Samsung Freezers
Why does my daewoo fridge freezer works intermittently ?
You either have a faulty thermostat, a loose connection or most likely a build up of ice inside the freezer. I had the same problem. Almost replaced fridge. Took all the food out one day, took out the racks and disassembled bottom and rear and found a two foot log block of ice inside air return. Removed ice everything works perfectly.
Jul 22, 2014 | Daewoo Freezers
Door seal not tight on upright freezer
Check the door sits straight and square on the front. You can "adjust" with the heel of your hand to make it sit flat against the frame. Even a poor seal shouldn't make frozen food thaw - check and clean the condenser and fan
May 08, 2012 | Kenmore 16.7 cu. ft. / 473 liter Upright...
We have a Amana BR18 Easy Reach bottom freezer. The fridge is turned up all the way, barely keeping food cold. The freezer is not freezing anything (ice, etc.). The freezer is still blowing cool air, but...
Low refrigerant assuming the compressor is always running and not being shut down by the thermostat.
You can hook up an ammeter to the unit to see if the current consumption is below spec, another sign of low gas situation since the motor is not working as hard as under normal conditions.
Jun 10, 2017 | Freezers
The top half of the upright freezer is totally thawed but the bottom is frozen. I need the whole thing to freeze.....
Check for ice on back wall if iced up check defrost heater and defrost timer also check and besure evaperator fan is working check wireharness on heater, timer, and evap. fan motor.Sounds like you have a defrost prob. Turn off for 24hrs to melt ice turn unit back on if it works for a few days then ices back up you have a defrost prob.
May 16, 2010 | Freezers
Freezer started emitting a chemical smell and food is thawing.
if its a sweet sickly smell then its possibly just a relay thats burnt out,should be cheap enough to replace,its the call out thats the killer.
Mar 11, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Maytag freezer keeps thawing food
I am no pro on these but it sounds like your defrost heating coils are coming on to often. You may want to check them. Aslo just for good measure>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 20, 2010 | Freezers
Zanussi 10.31 cu. ft. / 292 liter Chest Freezer ZCF106A Logo
151 people viewed this question
Top Zanussi Freezers Experts
AJMAL KHAN
Dado
ray gallant
Are you a Zanussi Freezer Expert? Answer questions, earn points and help others
