Question about Cell Phones
I'm getting the 7 blinking lights. Is it worth getting repaired
  • 11,896 Answers
I believe it is. About $250 repair if you bring it in. $400 at the very most. I would have a quote done before makng a final decision. It may just be as simple as needing a power supply or capacitor which is common now-days.
Posted on Nov 15, 2009
7 blinks
Assuming the basics have been signed off, the usual reason that a set will not fire up is a power supply problem. In sets like yours the supply comes from the transistor that supplies the screen with pulses and hence high voltage. In short with a set as old as this I personally would not be bothered getting it repaired. You could probably find someone giving a working set away for free on numerous local selling websites.
Jul 29, 2014 | Sony FD Trinitron KD-30XS955 30" TV
Power light blinks
Circuit board problem pawer supply
and or horilz deflection HV
Requires proffessional Service
May be worth repair. you could
get an estimate, and then decide
whether to throw it away or not
Nov 24, 2007 | Samsung LTN1565 15 in. HD-Ready LCD...
Standby light blinks 7 times on my kv30hs420 is it worth the repair
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Gopakumar Gopalan Google
Mar 09, 2014 | Sony FD Trinitron WEGA KV-30HS420 30" TV
7 blinking light on TCp54s2
7 blinks? Driver SOS 2 SU / SD / SS Boards (SC floating voltage area). These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 12, 2013 | Panasonic Viera TH-50PZ800U Plasma TV
I have a sonyTrinitron KV32HS510 .It will not turn on ...it sounds like it will but then I get a blinking code.Most of the time its 6 blinks .Sometimes its 7 blinks.Is it worth fixing and what should I...
six blinks mean that the tv has a problem in the horizontal circuit.have a tech repair your tv.the problem is in the following component. C 515 AND 516 and IC 206 which is the jungle IC.since you say it also blinks 7 times then there is a high voltage shut down which exceed 33k chech the power supply regulation and of course the horizontal circuits.a cost for this job is around $100.00 Good luck. if you dont want to invest in repair then i advise you buy a new tv.good luck.
Sep 14, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
15 months into owning our Panasonic TC P46S1 (3 months past warranty), the screen has gone black. The red light on the front flashes 7 times with a pause of 3 sec and then repeats. I have heard horror...
My suggestion is that you get an estimat from a dealer on repair costs and you decide whether you want to spen money on a part or new set. This is a bad circuit board and probably the power supply. The repair will be around $200.00 minimum unless you get lucky and there is no major issues and the board can be repaired.
The service manual says. you have what you call a "shut down circut" it is for safety and when one of the internal boards gets shorted or is not working properly, service doc reads as follows
7 Blinks SOS:
Pin 93 of the MPU IC9003 monitors the status of the SC, SU, SD board. During normal operation, the photo-coupler PC6480 outputs a low to pin 93. If the SC, SU, or SD board becomes defective, a high is provided to pin 93. As a result, the unit shuts down and the power LED blinks 7 times
thiera blinking 7 times is cuase by a fualt in sc,su,sd board.
If the board shorted another before it went dead you could have other issues, thats why you need a tech to look at it and give you an estimate. You never know, this being so close to warranty they might work with you on it.
Mar 23, 2011 | Panasonic TC-P46S1 TV
Philips 42 wont turn on
I am having this same problem. I have "fixed" this problem twice by replacing 2 failed capacitors inside. The fix is pretty easy and the cost of the replacement parts is about $2.50. Unfortunately, the fix doesn't last. The first time, the TV worked again for about 6 months, but the 2nd time, when I replaced with higher grade capacitors, I only got another 2 weeks out of the TV. I think it's time to cut my losses and get a new set. Repair costs were estimated at $600. ...just not worth it.
Jan 25, 2010 | Philips Televison & Video
My sony wega 32hs420 timer light is blinking 7 times stops then blinks 7 times and so on. do i need a repair man to come look at it?
Yes,this problems must have parts change.Repair and parts should be under $250 more than that not worth it to repair old CRT tube tv.High Voltage parts are dead must get it replaced.
Jan 23, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Red LED light blinks 7 times when the set is turned on; no pictur
if you have the circuit diagram of your tv,check the horizontal polarisation IC closer to the line transformer and replace it.If it doesn't work,send the question again.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Power light blinks and no picture
sounds like loose connections on the convergance amps ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 15, 2007 | Toshiba 65HX81 65" Rear Projection...
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
