KFL1600 - stops with Error 7.
Hi
I have Kleenmaid Wachine Machine front loader model KFL1600. It's been working for a couple of years OK but now it stops every wash with Error7. Manual said that Error 7 maybe related to outlet hose - but I checked it few times, - looks nothing wrong with it. I regulary clean a filter. Every wash it stops with error 7 and if you press a button to continue - it might (ot might not) go further for a while and stops again. We cannot wash our clothes at all at the moment - as 1 wash may take up to few days for us (family of 5 people). And you cannot get clothes out of it too as the door is shut as the cycle is not finished. Do not know what to do.
My phone (home) is in Melbourne - 955358212 and email alexlik@optusnet.com.au
Thank you
Alex Likhovetsky
    Brigadier General:
  • 4,088 Answers
If you unplug the machine when it stalls, that should reset the controller to allow release of the door. Does the pump run when it is supposed to? If ok, check the drain coupling at the bottom of the outer tub. If you pull the drain hose loose at the tub, water should run out (if water is in it). If not, there may be a stray sock or similar that is blocking the drain opening. Hopefully, there may be an access plate nearby that allows cleaning of the port. Otherwise, the machine will need to be torn down completely to access the port. (BIG job!) If you lay the drain hose down at floor level, an open drain system will allow gravity draining of the machine which would point to a defective or inoperative pump.
Posted on Nov 15, 2009
The filling water doesnt stop on my samsung wachine machine
water inlet valve is bad
and stuck in open position faulting
replace with new water valve.
Nov 13, 2013 | Avanti W797 12 lbs. Top Loader Fully...
What causes "Error 4" to
Hi, googled this problem myself and found this page. Doesn't help much though. Will still have to get someone out to look at it.
http://kleenmaid-appliances.com.au/TSPM/WM/Kleenmaid/KFL1600_Fault_Codes%2040220415.pdf
Good luck, we'll need it now our warranties are useless.
Dec 04, 2010 | Washing Machines
ERROR CODE CL for a Westinghouse front loader Model 708
Hi, cl means that the machine is over loaded, push stop clear to clear then try again with a lighter load....
Take care
Jun 15, 2010 | Siemens WE61021GB Front Load Washer
Kleenmaid top loader replace timer
Kleenmaid timers do fail from time to time. Reconditioned timers are a viable remedy and not as expensive as new ones. Depending on where in oz you are, a tech will have to sight the faulty timer to ensure the correct replacement unit. You can't rely on model number alone........Nomess
Apr 07, 2010 | Washing Machines
What's the capacity of a Simpson 175 HD washing machine (approx 22 years old). What new top load should i buy? dials or push button?
about 6to7 kg.to b honest the machines i find that last the longest r kleenmaid top loaders,maytag top loader,whirpool top loaders,and miele front loaders, i would try to advoid electronic units.nothing will b as robust as your 175.
Apr 06, 2010 | Washing Machines
Can you tell us what error 6 is as displayed on Kleenmaid KFL1600 front loading washing machine. We have the manual and it is not listed. Many thanks
Hi I've got a KFL1600 with error 6 too - I fixed this once by cleaning the filter, but now it's come up again and the filter is clean. Not sure if it's related but the door has stopped unlocking too and we have to open it by pulling the little tag in the filter door. Very reticent to get it repaired as everyone says that these machines are a nightmare and costly.
Jun 20, 2009 | Washing Machines
Kleenmaid kfl1600 front loader, does not start
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 05, 2009 | Washing Machines
Error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Sep 08, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Washing Machines Logo
670 people viewed this question
Top Washing Machines Experts
