Question about Nintendo DSi Black Console
Will a card working on 1.4 also work on 1.4a etc...?
  • 127 Answers
Most likely, i mean they are different, but they still are the same version after all, so the changes shouldnt be ig enough to chene the whole layout of the DSi or anything.
Posted on Nov 15, 2009
My controller for my texas instrument ti-99/4a isn't working
If they are the original blue controllers, rekove the bottom of the controller and run a fine piece of sand paper folded so both sides of the sand paper make contact through the contacts, this should clean them where they will work, If this does not work, the wiring or the controller circutry is defective.
Oct 19, 2014 | Texas Instruments 1 TI-99/4A Personal...
Blue Screen Computer Crashes
Blue screen error is occurred when the PC memory is not good or display card is not working.
Try to change the memory first, and turn on again the PC.
And then, not work, try to change the display card.
Nov 06, 2013 | Dell Alienware Computers & Internet
Instructions for Intel motherboard D845HV
Process of elimination (easiest to hardest)
1. Check all cables. (be surprised how often one will come loose)
2a. Is the computer beeping at all when turned on? Fans powering up? anything that would indicate life. (Note: one short beep typically means the computer is working properly)
2b. If there are a series of beeps, post the pattern as this is called a "Post message" which will aid in the troubleshooting...
3. Can you test the monitor with another computer? Even most laptops come with a VGA port you could test it with.
4a. If monitor is bad then replace.
4b. If monitor is good, remove CPU, RAM, HDs, any add on cards with the exception of the video card. When booted if you still have no video then try resetting the CMOS... then try another known good AGP video card if possible.
5. If you still get no video... then it's probably the mother board and honestly... probably time to just upgrade.
Sep 25, 2012 | Computers & Internet
Replacing oil pan in 1990 Toyota Corolla
Vehicles covered: Toyota Corolla, 4A-F, 4A-FE, and 4A-GE Engines
Here's your maintenance manual entry for the complete procedure:
OIL PAN REMOVAL & INSTALLATION - 1990 Toyota Corolla
4A-F, 4A-FE and 4A-GE Engines
See Figures 1 through 7
1. Disconnect the negative battery cable.
2. Raise and safely support the vehicle.
Fig. 1: Exploded view of the oil pan assembly-4A-F and 4A-GE engines
3. Drain the engine oil into a suitable container.
Fig. 2: Remove the oil pan drain plug to drain the engine oil from the crankcase
4. Place a jack under the transaxle to support it.
5. Remove the splash shield from under the engine.
6. Raise the jack under the transaxle slightly.
7. Remove the front exhaust pipe between the exhaust manifold and catalytic converter. Some models have an oxygen sensor, disconnect the oxygen sensor wiring.
Fig. 3: Remove the front exhaust pipe for better access during oil pan removal
8. On the 4A-F and 4A-FE engines, remove the center mounting.
Fig. 4: Remove the bolts and nuts retaining the center mounting-4A-F engine
9. Some 4A-FE engines and all 4A-GE engines are equipped with a stiffener plate. Remove the set bolts and pull the stiffener plate from the vehicle.
10. On the 4A-GE engines, unbolt and lower the flywheel housing under cover.
11. If equipped, remove the oil cooler hose and union from the oil pan. Remove the two nuts and nineteen bolts retaining the oil pan.
12. Insert a blade between the pan and cylinder block, cut off the applied sealer and remove the pan.
Fig. 5: Insert a blade and tap lightly to loosen the oil pan free from the block
To install:
Note: Be careful not to drop any oil on the contact surfaces of the pan and block.
13. Using a razor blade and gasket scraper, remove all traces of packing (FIPG) material from the gasket surfaces. Thoroughly clean all main surfaces to remove loose material. Clean both sealing surfaces with non-residue solvent.
Fig. 6: Apply a reasonable amount of sealant (FIPG) to the oil pan surface-except 7A-FE engine
14. Apply new packing (FIPG) 08826-00080 to the oil pan as shown. Avoid applying excessive amounts to the surface. Be especially careful around the oil passages.
Note: Parts must be assembled within 3 mins of application. Otherwise, the sealer (FIPG) must be removed and reapplied.
15. Install the oil pan over the studs on the block with the nineteen bolts and two nuts. Tighten the bolts to 43 inch lbs. (5 Nm). Make sure when you install the oil pan drain plug using a new gasket.
Fig. 7: Tighten the 19 oil pan retaining bolts securely-4A-F, 4A-FE and 4A-GE engines
16. If equipped, install the oil cooler pipe, two new gaskets and union bolt. Tighten the union bolt to 18 ft. lbs. (25 Nm).
17. Install the front exhaust pipe (with new gaskets on either end of the pipe) to the manifold.
18. On the 4A-GE engines, install and secure the flywheel housing under cover if removed.
19. On the 4A-FE engines if removed, attach the stiffener plate. tighten the No. 1 bolt first then the 5 bolts in the sequence shown. Tighten to 17 ft. lbs. (23 Nm).
20. On the 4A-GE engines, attach the stiffener plate with the 3 set bolts and tighten them to 27 ft. lbs. (37 Nm).
21. Attach the center mounting and tighten the member side bolts to 38 ft. lbs. (52 Nm), plate side to 17 ft. lbs. (23 Nm).
22. Lower the jack from the transaxle.
23. Lower the vehicle, and fill the crankcase with the appropriate amount of engine oil. Engine oil crankcase capacity is 3.4 quarts (with oil filter change).
Above -9 degrees Fahrenheit, use 10W-40 motor oil, and above 10 degrees Fahrenheit, use 20W-50 motor oil.
24. Connect the negative battery cable, start the engine and check for leaks. If all is well, raise the vehicle slightly and install the engine splash cover.
25. Recheck the engine oil level, top off if necessary.
Feb 14, 2012 | 1990 Toyota Corolla
5(a+3)-a=-(4a-6)+1
For this problem you have to type solve(5(a+3)-a = -(4a-6) +1,a)
See captured image
Oct 18, 2011 | Texas Instruments TI-86 Calculator
Kodak memory card.4G, SDHC. Have uploaded pix, erased and reformatted this card. Camera still says its locked? Slide is up closest to contacts. Can you help? Thanks.
Just checking, but it's important that you format the card in the camera, and not in the computer. Here are some troubleshooting steps for a locked SD card. If the slide switch is indeed toward the contacts, might consider trying the toothpick fix (Fix 4), and if that doesn't work, the tape fix (Fix 4a).
Jul 22, 2011 | Kodak Cameras
A+1/4a
a+1/4a = 4/4a+1/4a = 5/4a
Jan 16, 2011 | Mathsoft StudyWorks! Mathematics Deluxe...
Just simplify this rational algebraic expression 16a^2-8a 1/4a-1
16a power of 2, -8a,),,(1/4a-1) are these two prolems polynomials, to be multiplied togethor? is 4a to the third power-18a squared+8a, used the distributive property
Michael
Oct 04, 2010 | Mathsoft StudyWorks! Mathematics Deluxe...
HOW DO I SET DISTRIBUTOR TIMING?
Actual timing would depend on what engine is installed in the 1985 Corolla. There are some versions that uses the 4A-GE, 4A-GEC, 4A-C engines. There are even some Asian versions that used the 4K/B engines.
The correct method would be to use timing light, engine analyzer and some other test equipment, However, below is a quick and dirty procedure. Basically, to adjust the distributor timing, you need to:
1. make sure cylinder 1's piston is at firing position/TDC (top dead center);
2. crankshaft pulley's timing mark is between the markings on the engine with numbers on them;
3. unplug the rubber boot of the high tension wire for #1 cylinder;
4. connect to it a spare known good spark plug and allow to touch any metal surface of the engine;
5. slightly loosen the single locking bolt of the distributor stem;
6. turn ignition key to ON but not start;
7. carefully swing the distributor assembly till there is spark in the exposed spark plug;
8. tighten locking bolt.
You may need to readjust the distributor for highest idling RPM with the engine running by simply turning the entire distributor assy.
The timing mark must coincide with the specified advance for whatever engine is used by the Corolla. 8 degrees would be a fair start.
Extreme care when working with engine running; extremely high voltage at the high tension wires, distributor and ignition coil and the fan/belt has been known to catch loose clothing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 09, 2008 | 1985 Toyota Corolla 2 Door
PS-4A
Tom, Are you logged in as administrator? Have you checked firewall settings on the machine and the router? Permissions(if not admin)? Have you checked the print spool service or another needed service. Just some quick thoughts. Tim
Jan 27, 2007 | Keyspan (PS-4A) (PS4A) Print Server
Nintendo DSi Black Console Logo
63 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
