Back to:
Tags:
GE 31GT740 31
Help Finding Replacement Parts
posted by BeeeDeee on Jan 09, 2008
I believe that the power/channel/volume control panel on my TV has gone bad. If I press VERY hard on the buttons, they'll work. The TV powers on and off by itself and the channels change by themselves. Replacement seems pretty straightforward, but I can't figure out what the part number is for the button cluster. Can anyone help determine the part number and a source for the part? The numbers on the button cluster are: 1515631E, but I haven't had any luck locating anything close on the web. Any help would be greatly appreciated. -Matt
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Feb 22, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I had the exact same problem with the channel/volume autoshifting. I found a electronic firm that would rebuilt the board for $185.00 plus shipping-----screw that. I cut the plastic hold down nubs on the channel/volume buttons itself and disassembled the contact. Inside the button was a copper metal disc showing arc tracks and "carbon scoring" on the underside. I just removed the button guts and now use the remote for channel and volume adjustments. So far the power button still works for me. I may try buffing and cleaning the disc and contacts later, but what the hey, I'd rather surf with the remote from the couch.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Help Finding Replacement Parts:
I don't want to Accept this solution
Can you Help with these Standard Televisions problems?
GE 31GT740 31" TV
can you help me find a part?
GE 31GT740 31" TV
ok i can't not set my dvd to this tv i had it for min i...
GE 31GT740 31" TV
loud pop,then dim pic and the horizontal lines. can this...
GE 31GT740 31" TV
the flyback is bad pn1544445a. i need to replace it
Loading problems.
Repair Service
Find Standard TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
