Question about Cell Phones
I have Boost mobile Unlimited Plan and I have a i920 Windows Mobile Version the Internet does not work and my contacts do not show up. Can this be resolved?
  • 2,359 Answers
If you just activated the SIM card via the web then just wait for email confirmation.
It took Boost about 1/2 hour to enable all settings on my iDEN phone.
The quickest way to test for FREE is to dial 225 and check for balance.
It's a free call.
If all else fail,power off unit,remove sim card and let it sit for 1 hour or more.
Here the link to i920 setup
Page 77 explain how to verify the iDEN data setting.
The current Windows ActiveSync is Version 4.5
Link HERE
The original ActivcSync from the original package can be dated back in 20006!
Check the version and make sure your are on Version 4.5
Also make sure the sync cable metal contacts are clean.
use a dry cloth to clean the contacts on the phone and sync cable.
If ActiveSync does not see the phone the you will need to go into system/hardware manager verify the COM setting.
Setting the Way Your Phone Searches for
Networks
When you are traveling internationally, you may want to configure the phone to search
for a specific network or enable it to select the best network. You do this using the iDEN/
GSM Selection setting.
There are six options available:
Note: Your phone comes programmed with Last active as the default setting. This is
the recommended setting, which reduces network registration time.
• Last active — This option enables the phone to switch between iDEN and GSM
systems that do not overlap. For example, you send or receive calls on an iDEN
network while in New York. Then you travel to Paris. Your phone will first search for an
iDEN network. If it cannot locate one, it will automatically search for a GSM network.
Your Smartphone will always register on the last active mode.
• iDEN preferred — This option is useful if your home system is iDEN and you travel to
a country or region where GSM coverage is also available. Your Smartphone always
searches first for iDEN networks. If an iDEN network is not found, your phone will then
Nextel Worldwide® Services 77
• GSM preferred —This option is useful if your home system is GSM and you travel to
a country or region where iDEN is also available. Your phone will always search for
GSM networks first. If a GSM network is not found, your phone will then search for an
iDEN network.
• iDEN only — This option is useful when you are in an area that is covered by iDEN
and GSM networks, but you want to use iDEN. Your Smartphone attempts to register
only on iDEN networks. This is the optimal setting you should set your Smartphone to
when in a Nextel iDEN service region.
• GSM only — This option is useful when you are in an area that is covered by iDEN
and GSM, but you want to use GSM. Your Smartphone attempts to register only on
GSM networks. This is the optimal setting you should set your Smartphone to when in
a region with only GSM carriers.
• Roam — This option is useful when you are in an overlapping system-coverage area
and have no preference for either the iDEN or the GSM network. Your Smartphone will
switch between iDEN and GSM until it finds an acceptable network.
Note: Be aware that some features that are supported by the Nextel iDEN network
are not supported when you connect to a GSM network.
Select iDEN/GSM options
1 On the Home screen, select Start.
2 Select Settings and then Phone Networks.
3 Select iDEN/GSM Selection.
4 In iDEN/GSM selection, select to the option you want.
5 Select Done.
Searching for a Network
While you are on a GSM network, you can perform an automatic or manual search for
available networks. A manual search allows you to view the available networks and
make a selection rather than use the network automatically selected by the Nextel
Worldwide Service.
Note: Your phone will automatically attempt to register with networks that have
agreements with Nextel. By manually selecting a network, you may choose a
network that does not have an agreement with Nextel or does not offer optimal
coverage in that area.
View current network
3 Select Current Network.
4 Select Done.
View current GSM band
3 Select GSM Band.
4 Select Done.
Nextel Worldwide® Services 78
Select a GSM network
3 Select GSM Network Selection.
4 In Network selection, select the option you want: Manual or Automatic.
5 If you selected Manual, select Menu and then Select a Network. Select the network
and select Done. The Smartphone will use the selected network.
6 If you selected Automatic, select Menu and then Preferred Networks. Select the
networks to use and select Done. The Smartphone will automatically use the
preferred networks.
7 Select Done.
Limit calls to specific area codes or phone numbers
Note: You will see this option only if you are on a GSM network.
2 Select Settings and then Phone Calls.
3 Select Fixed Dialing and then Enable fixed dialing.
4 Select Menu and then Edit Numbers.
5 Select Menu and then Add.
6 Enter the phone number or area code to which to restrict calling and select Done.
7 Repeat steps 4, 5, and 6 to add more numbers as necessary. You will be able to
make and receive calls only to and from the numbers or area codes specified.
Using Wireless Data Services
Internationally
Many of your Wireless Data Services can be used internationally just as you use them in
the U.S. on the Nextel National Network. To activate your Wireless Data Services for use
abroad, contact your Nextel sales representative. See sprint.com for a list of wireless
data services you can use internationally and in which countries you can use them.
Data Connections for GSM
Setting Up Your Smartphone for Wireless Data Service Access
If you activate your Wireless Data Services for use in GSM countries (GPRS) you can
set up a GPRS connection to gain access to your corporate network or the Internet on
your Smartphone.
Before accessing your data services internationally for the first time, see “Create a
GPRS connection” and “Connect to the Internet with a GPRS connection” on page 79.
Create a GPRS connection
Note: You are not required to enter a user name, password, primary DNS, secondary
DNS, or IP address to create GPRS connection.
2 Select Settings and then Data Connections.
Nextel Worldwide® Services 79
3 Select Internet Connection.
4 Select Menu and then Edit Connections.
5 Select GPRS Connections.
6 Select Menu and then Add.
7 Enter the requested information as follows and select Done:
• In Description, enter a name for the connection (for example, Nextel, GSM,
GPRS).
• In Connects to, select the type of network to which you will connect (for example,
Internet).
• In Access point, enter the information provided by Nextel.
When you open a program that connects to the Internet, the Smartphone uses this
connection.
Note: If you are not sure about the information to enter, ask your Sprint Customer
Care Representative.
Edit a GPRS connection
6 Scroll to the connection to edit.
7 Select Menu and then Add.
8 Change any information and select Done.
Delete a GPRS connection
6 Scroll to the connection to delete.
8 Select Yes.
3 In Internet Connection, select the GPRS you want to use and select Done.
Tip: After you use the GPRS connection once, you may want to change your
Internet Connection back to Automatic. Your phone will then automatically
select the correct connection based on the network.
Posted on Nov 15, 2009
Trying to convert,if possible, nextel blackberry 8530i to boostmobile
watch this video
Boost Mobile has the cheapest (and slowest) data service around, and the Nextel Branded BlackBerry is the only smart phone that works with Boost's iDEN service.
The old 7520 and 7100i BlackBerry's can be purchased for around 50 dollars, and are very usable smart phones.
The newer BlackBerry 8350i is one of the best blackberry smartphones available. However on Nextel it costs more then 120 dollars a month for unlimited everything and on Boost mobile you can get unlimited service for $50 a month.
The difference however is that Boost mobile does not offer a Blackberry Data Plan and Nextel does. So if you want to browse the web, send emails, and be able to download apps, you have to convert your Nextel Blackberry to Boost Mobile.
The email works a little differently in that you can set up your yahoo or aol mail to forward to your Blackberry by using the email address
yournumber@myboostmobile.com as the forward to email address.
What are the differences of the Nextel Blackberry models?
Besides the obvious difference which is the design of the phone and the applications and memory available, the 8350i runs BlackBerry OS version 4.6 whereas the 7520 and 7100i run version 4.1. The older OS does not support as many apps and features.
To sum it up Boost Mobile Phones aren't good and Blackberry's are. It's really that simple.
Does Boost support the BlackBerry?
Not officially. Boost sells their Starter kit to "give new life to a previously used Boost or Nextel phone", but they make no specific mention of its compatibility with the BlackBerry. Using a BlackBerry on Boost is consistent with their terms and conditions, but you won't get any help from Boost for configuring your BlackBerry.
Which features work?
Voice service and basic data service work.
3rd-party apps work, including apps for web browsing, email, GPS, and instant messaging.
Over-the-air installation of apps using the BlackBerry Browser will work if youfollow the how-to.
Text messaging will work if you follow the how-to.
Apps can also be installed using the Desktop Manager software on your PC.
Which Boost plans included data service?
All Boost plans include basic data service
May 19, 2011 | RIM Cell Phones
I can't get the data to work on my Motorola Cliq phone. I do have the data plan. People keep telling me I need to change the APN settings???
You need the "T-Mobile Android Unlimited Web + Unlimited Messages" plan or the "T-Mobile Android Unlimited Web" plan for the CLIQ. Give T-Mobile a call.
Mar 01, 2011 | Motorola Mobility CLIQ Cell Phone
If i surf the internet then charges is applicable from my balance
Unless you have a Data plan on your account then, yes - you'll be charged for your Internet usage. If you have a pay-as-you-go account, Internet usage will be deducted from your available balance. (Read: Less minutes to talk). Without a Data plan, surfing the Internet is VERY expensive.
If you plan to both, use the Internet a lot from your phone and talk and text a lot, too (and you want a pay-as-you-go account) and if you have iDEN service in your area then Boost Mobile would be your best choice. (If you have Sprint service in your area then you'll have Boost service as well.)
And, For every 6 on-time payments, Boost will lower your monthly payment by $5. You'll start off at $50 per month for unlimited service and 18 months later you'll only be paying $35/month for unlimited Internet, talk and texting. It's the best deal out there.
Boost Mobile website: http://www.boostmobile.com/
Feb 05, 2011 | Samsung Cell Phones
How Can I Use My Boost Mobile Sim In My I776 Sprint Nextel Phone?
Yep, the 1776 is a boost phone...you can NOT put a nextel sim in a boost, but putting a boost sim in a nextel works fine.
Dec 03, 2009 | Motorola Mobility i776 Cell Phone
Just bought a used motorola i425 where can I purchase the sim card
The SIM is based off of the network you are using, AT&T, T-Mobile, etc. You would purchase it from a store of theirs.
Oct 02, 2009 | Motorola Mobility i425 iDEN Cellular Phone
I have a i920 for nextel and i have boost mobile and i cant txt
Commonly, you need to contact Boost Mobile to have them set that service up for you. You usually need an internet package that you have to pay for upfront seeing as Boost is a prepaid phone service. But to fix it- Try taking the battery out of your phone while it is still turned on. That is called a hard reset. It usually refreshes the phone with the cell towers and updates the roaming list with them. But call Boost for your phone email address. Hope i've helped.
Mar 18, 2009 | Motorola Mobility i920 Cellular Phone
Blackberry Curve.?
I haven't heard of an Internet-only plan on T-Mobile, as I don't think there is one. If you don't use a lot of minutes then I recommend the BlackBerry Minutes and Mail plan. It allows for 1000 Anytime Minutes, unlimited data (including Internet) and e-mai, and unlimited text messaging for $59.99
Oct 07, 2008 | AT&T Blackberry Curve 8300 Smartphone
Sidekick slide
to add ringtones and pictures you have to have the sidekick plan for your service. it comes with unlimited internet and free text. depending on what yur plan is depends on what the price is. my boyfriend pays a dollar a day for his prepaid sidekick plan which includes unlimited internet web and picture messages.
Apr 09, 2008 | T-Mobile Sidekick
Cell Phones Logo
61 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
