Question about Refrigerators
Top Load making noise. Wash cycle finished, open
Top Load making noise. Wash cycle finished, open with clothes and water still in it. Set it to spin cycle, closed door and smelled burning something. Opened door, not spinning or draining and smoking. What is wrong.
  • 77 Answers
Bad lid switch.coupling broke and rubber burning or trans locked up
Posted on Nov 15, 2009
Our Kenmore top load model 22422 started having problems with the spin cycle. Once it gets to the spin cycle, it makes a terrible grinding like noise - it is not spinning. However it will drain if you let...
The double shaft motor does double duty. One direction for wash and another direction for spin. In wash mode the water stays put in the tub because the pump is running backwards. In spin mode the motors turns in opposite direction. This pumps the water out and spins the clothes dry. From what you have described the drive coupler is toast.
This video shows how to swap the drive couple out:
More HERE
Mar 01, 2011 | Kenmore 22422 Top Load Washer
I just purchased my Cabrio washer...have had it a week. When I use the normal cycle, the machine does not spin the clothes at the end of it so when they cycle is done the clothes are dripping wet. I then...
I have had my Cabrio washer a little over a year. No it isn't suppose to do that. There is a setting for spinning high medium and low spin. Maybe you can change the spin setting manually. See if that works The washer is computer operated so the spinning cycle must be out on your normal cycle. I did myself a favor and I keep all clothes on towels and sheets. I set the temp for the water on what I would like manually. The washer fills up with more water and seems to clean the clothes better and My washer does the same thing from time to time about not spinning. Just remember you can set all wash manually with water temp and spin cycle. Is your washer still under warrenty?
Jan 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My Maytag Neptune FAV6800AW top load washer only runs for the first few minutes of the cycle, it will not spin..it just stops..we've tried two cycles, the quick wash...it starts at 33 mins and then stops...
I'm and owner and will try to help. Are you handy and do you want to try a DIY fix?
From the wash times is sounds like the washer is agitating the wash load (tumblers are rotating the wash basket load) is that correct?
If so see if the machine will complete a Spin Only cycle with no clothes in the wash basket. Set the Spin setting to Spin/Hang dry seting and start the cycle. It should take about 10 min complete. Does the Spin Only cycle complete with no clothes in the wash basket?
Some handy links if you are going to DIY.........Service Manual for reference.
Sep 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
GE washer, does not spin
You probably broke the 4 black snubber straps on the top of the tub lid and it is cousing your washer to always be off balance and not reach a full speed spin
Oct 30, 2007 | GE WBSR3140DW Top Load Washer
SPin CYcle Noise
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump. Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then try to remove the clothing through the port.
Apr 16, 2007 | Kenmore 42722 Top Load Washer
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
