Question about Acer Aspire 3690-2196 Notebook
When I plug my laptop in it shorts out the plug in my house
    President:
  • 788 Answers
You will need to purchase a new AC adapter for your laptop. Somthing in the power supply has gone out.
You can google the adapter or check out this link.
http://www.blazintech.net/laptops/ac-adaptor-chargers/universal/prod_35842.html?gclid=CL_Jk5uOjJ4CFRlcagodISGGnA
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Posted on Nov 15, 2009
Projecta charger is shorting out house when plug in
Don't plug it in then and return it. Problem solved!
Just kidding. This means that either your house has a huge flaw, the ground on the plug isn't working, or that your Projector is using too much power.
Jun 02, 2017 | Computers & Internet
AC Adaptor not working in laptop
the problem is in your laptop...maybe it damaged too when you plugged your old adaptor. you should check your laptop for a repair...maybe it needs to replace tha spare parts that may have been damaged.
Dec 01, 2011 | Computers & Internet
1993 previa, engine water leaking from transmission bell housing at bottom. is there a freeze plug that is behind the bell housing??
yes there is a engine core plug and its behind and inside of the bell housing,, sorry its a gear box out job to fix it,,,or you could try
"block weld!" that may stop the leak for a short time,,,
Oct 18, 2010 | 1994 Toyota Previa
My acer netbook just shuts down while it is still booting. how to fix?
Remove the battery pack. With the laptop plugged into house power, try booting it.
I am trying to describe the work-around to a shorted battery. If this works, you will need to replace the battery
Nov 27, 2009 | Acer Aspire One PC Notebook
House fuse box blows when you plug machine in.
There is a short in your vacuum that is cause your circuit to trip. It is more then likely a ground wire that has come loose in the plug that attaches to the motor of the vacuum
May 16, 2009 | Vacuums
Dead short on power jack
Should be battery first, Then AC adapter (Charger)
Dead short on DC Power Jack?
Are you aware of how a DC Power Jack is made, (Component structure), and how it attaches to the motherboard?
If not, allow me to explain. This is an example of an average DC Power Jack,
http://us.st12.yimg.com/us.st.yimg.com/I/yhst-42877593004970_2046_1336946
The outside housing of the DC Power Jack, is barely larger than the outside of the AC adapter (Charger) plug.
It's about a 1/4 inch wide, 3/8 inch inch tall, and 1/2 inch long.
The body is made of plastic.
The outside shell opening in the body is the Negative contact.
The pin in the center is the Positive contact.
Those flat metal prongs, or pins, you see in the photo, go down through the motherboard, are are soldered on the bottom side.
The photo of the jack is upside down, in relation to how the jack sits on the motherboard.
When the 'Charger' plug is plugged into the power jack, it can get bumped. A hard enough bump, or repetitious bumps can damage
the center pin mounting, break the outside metal shell loose, and/or break the plastic housing.
It can also break the solder joint/s for those flat metal pins.
AC adapter unplugged from the laptop, battery removed, see if you can take a pencil eraser, and move that middle pin around. You may see the entire jack move.
There is also a large number of laptops, made with a defective motherboard design. To explain, I'll have to give you a crude example.
Think of the laptop motherboard as being a 1 foot square. (It isn't. It's irregular shaped)
Now along the edge of the 1 foot square, attach a 2 inch square.
It's actually all one piece.
Due to accidental bumping of the 'Charger' plug while in the power jack, this 2 inch 'Peninsula' can break away from the main body of the motherboard. (1 foot square)
There are circuit traces on the motherboard. (Think of a circuit trace, as a Very, Flat, Thin, copper wire)
These circuit trace can become stretched by the cracking, or breaking away of the 2 inch 'Peninsula'. They can then be exposed to circuit traces they're not designed to touch. This can cause a direct short.
(Also, due to the bad design of these motherboards, the laptop user can be just using the 'Charger', in an everyday situation, and this 2 inch 'Peninsula' can break.
Just by plugging in, and unplugging)
Apr 23, 2009 | Gateway MT6840 Notebook
Kenmore side by side shorts out when plugged in
you have a short may be refrigerator or wall check panel
Jan 31, 2009 | Kenmore 53082 / 53084 Side by Side...
Stopped turning on, charge light appears when plugged in...
try removing the battery and plug in AC power only and power up, sounds like you may have shorted the battery
regards
Nov 24, 2008 | Gateway CX2610 Notebook
Acer Aspire 3690-2196 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
