Computer says found new hardware,doesn't show in computer{w 7).same on xp machine
    Guru:
  • 480 Answers
Ok try disk management and format the disk
the disk may be corrupted the partition
go > control panel>administratve tools>computer management>then select disk management on the left side
ok
Posted on Nov 15, 2009
Can I use alohabob to go from Windowsxp to Windows 10
You might be able to move specific applications or software from a Windows XP computer to a Windows 10 computer, using that software. But you cannot go from Windows XP to 10 on the same computer. The hardware of the Windows XP machine, unless you downgraded the OS from Windows 7 or 8 to XP, was NOT designed to work with a operating system higher than XP. You can only upgraded a Windows 7 or 8 computer to Windows 10 (not that you would want to as the Windows 10 system is useless junk).
One of the reason that Microsoft offered the Windows 10 free was that people using 7 would not ditch their old computers to buy a new one fitted with windows 10. However to get around the problem of not having new hardware. They had to fudge and bodge the Windows 10 software to make it work on hardware designed for Windows 7.
So basically it's rubbish because corners were cut.
May 15, 2016 | Computers & Internet
360 desktop wit Window Xp. Hardware (CDROM -PLDS DH-16AAS DVDRW) installing problem
Two items on a single IDE ribbon cable require a master and a slave. The next step is to let BIOS know of the drive. Press F2 during boot and check. Look for it were other drives are, and there maybe a auto select / discovery option. It must show in BIOS, or there is no going forward.
If BIOS sees it and XP does not. Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Walla CD-ROM in the house.
If none of this works. Test another cable, CD-ROM, or computer. Oh yea, virus protection. Do a thorough scan. This was a common problem back in the day.
Oct 12, 2012 | Dell OptiPlex 360 Desktop Computer
I cam't install driver for windows 7
The problem with Windows 7 as you have found out is that older Windows (XP and back) based hardware drivers do not work on windows 7. There is seldom a fix other than just buying new hardware with drivers that work with Windows 7. I would google this and see if any fix shows up at the Microsoft support site that may offer a work around for the problem. I have an older printer that would not work with 7, I found that by using the basic driver of new model of my printer it would work, but without any special features, just prints and nothing else. I ended up buying a new Canon printer (less than $75.00) in the end so I could use the photo features.
Jun 20, 2012 | Datacard SP35 Plus Printer
Windows 7 will not recognise vdr-m70 dvd camcorder
Panasonic supplied software for the VDR-M70 for Windows 98 through XP on the CD. Due to changes in the OS over time, the installer can't run under Windows 7. Panasonic has not updated the drivers for Windows 7 and Microsoft indicates that it is not compatible with any version of Windows 7.
There are work-arounds depending on your version of Windows 7. If you have the 32-bit OS, try using the compatibility mode. To find out which version of Win7 that you have, click Start > Control Panel > System and Security > System. If the name of the OS ends with x64, then you have the 64-bit version of the software. Otherwise, you have the 32-bit version.
For the compatibility mode, right click on the installer on the CD (browse Computer). Choose Properties and then click on the Compatibility tab. Select Always Run this program as and an older version of Windows (XP). Apply and Save your changes. Then right click again on the installer and choose Run as Administrator.
This may not work (and won't work for the 64-bit Windows 7). If it doesn't work, you need a machine with an older version of Windows. This can be a second computer, a dual boot computer or a virtual computer (if your hardware supports virtual computing). For most options, you will need a licensed copy of the older version of Windows.
If you have Windows 7 Pro or Ultimate or upgrade to one of them, you can have a virtual version of XP for free. Download and install Virtual PC and XP mode from Microsoft in order. Then install the software for the camcorder in XP mode as if it were your only computer. (Of course this doesn't help if your hardware doesn't support the Virtual PC.) Other virtual computer programs are VMWare and Parallels.
Note: you can not directly share files or hardware between the Win7 and the virtual computer. You have to put files on an external drive (optical, flash drive or other external hardware) to share them.
I hope this helps.
Nov 12, 2011 | Panasonic Palmcorder VDR-M70 DVD Camcorder
I was using winXp & vista before win 7 ultimate, now when i am going to install bluetooth driver the massage is bluetooth device not found. please give me solution soon
first attach the Bluetooth to the computer and restart the computer when it shows new hardware found so it automatically scan for driver from system If it found the drivers already in the windows so it run you device if it not found the driver so it ask form you to install the drivers and if is not showing any hardware so go to the control panel and click on add hardware
Aug 04, 2011 | Computers & Internet
Recently upgraded my pc to windows 7 from windows xp professional. now my scanner does not work, not compatible with windows 7.. are there any drivers available that are compatible with windows 7
BenQ apparently never updated drivers for this hardware to work un a Windows 7 environment. I do not have this scanner myself, but I did come accross a site that indicated many were having luck with a driver found there. I was unable to test it as I lack the hardware. I do not know it it will work for you or not, but I offer the info for you to investigate to see if you can get it to work in Windows 7. The site is: http://www.bioticaindia.com/benq-s2w-4300u.html
Lastly, if your version of Windows 7 is "Pro" or "Ultimate", it supports "Windows Virtual PC." Windows Virtual PC is a fully *free*, fully functional licensed copy of Windows XP Pro direct from Microsoft that "runs" in Windows 7. You can install applications and hardware in the Vitual PC just as if it were another computer. Follow the Virtual PC link above to learn more about it. You may be able to breathe new life into your BenQ scanner running it in the Virtual PC, if the driver mentioned in the first paragraph doesn't work for you.
Good luck! Please rate my reply "4 thumbs up" if it was helpful - thanks!
Jul 25, 2011 | BenQ Scan to Web 4300U Flatbed Scanner
Cannot access DVD drive. Shows as BD-ROM and does not show disk. I'm only able to eject the disk by starting in setup mode.
1.control panel->system->hardware->DEVICE MANAGER 2.uninstall your driver 3.restart you computer 4.on tray icon a balloon come with a MSG of 'found new hardware' 5.click on it 6.select your driver from it .then select suitable option
if you still have problem buy a you op(win xp,vista,7..).using that disk repair you computer
Feb 27, 2011 | Dell (WT927) DVD+RW Burner
My hp pavilion dv2000 cd/dvd-rom drive is not showing its icon on my computer
if you still have problem buy a you op(win xp,vista,7..).using that disk repair you computer.
Feb 27, 2011 | HP (346789-001) CD-RW/DVD-ROM Combo Drive
When i connect my drive to my pc using windows xp in show Found new hardware searches for drivers and completes the search. but when i go to my computer it does not show up
Windows XP can only see up to 120GB. If you can partition the drive in 4 X120GB and 20GB XP will see five drives. If you need to use the full 500GB, you will need to upgrade to XP with SP3 or Windows 7
Jan 26, 2011 | LaCie 500GB USB 2.0 7200 RPM 8MB 500 GB...
Dynex Easy Transfer XP to Windows 7 not working
Remove old drive from computer and install in new computer using ide ribbon. It will connect as a secondary unit and you can then using windows explorer transfer any data on old drive to new one.
Jun 19, 2017 | Dynex Computers & Internet
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
