Question about Grundig GU22DVDPX 22 in. LCD TV
How do you remove the stand of a grundig gu22wdvd3 so we can put it on a wall bracket ; it has the holes for a bracket to fix into.
First remove the two screws from the underside of the base, pull the oval base clear from the stem. This will reveal two screws within the stem, remove these and the four on the back of the stem. Job done, hang enjoy.
Posted on Dec 26, 2009
How can i wall or bracket mount a Samsung Syncmaster S27B350
dear very easy. you just purchase a wall bracket from market and unscrew the stand from your monitor and place that bracket instead of monitor stand and make holes in the wall and place it on wall.
Oct 20, 2014 | Samsung S27B350H - SyncMaster S27B350H -...
Rca manual instruction
"RCA manual instruction" is not a model number. But as long as the TV has wall bracket fixing holes and a removable table stand then yes, it can be wall mounted
Sep 03, 2014 | Televison & Video
Remove stand from monitor
there will be screws on the back which will allow you to remove the stand, then on the back of the monitor their should be 4 screw holes, use these to attach a a flat plate wall bracket to it.
but if you can't remove the stand, then put a clap speaker bracket on the wall & just clap the base of the monitor, as this type of bracket can be adjusted both in & out & up & down.
Jul 21, 2012 | Acer AL1711 17" LCD Monitor
TH-C4HD18
the four holes on rear are for wall mounted bracket, the stand that goes in bottom generally requires the removing of a cover plate which will be about size of the upper part of stand and will be approx four screws, remove cover and stand will slot in and fix with scres/bolts accordingly.
May 05, 2012 | Panasonic TH-C42HD18 42 in. Plasma TV
Rehow could fix the sreen on wall?
Remove the LCD monitor stand, purchase a wall mounting bracket. There are several types, one is on an articulated arm which allows you to left, right, up and down. Another type mounts flat to the wall with limited up and down adjustment.
You need to check the mounting holes on the wall brackets so it matches the mounting screw holes on the LCD screen.
Nov 26, 2010 | LG 22" FLATRON LCD Monitor
How do i take the stand off a toshiba 32AV635D to wall mount ?
On my 32AV635D there are 4 Allen bolts in recessed holes on the back cover. Remove these (but no others!) and the stand just slides out. Under the base of the stand there are two more Allen bolts which fix the metal brackets to the stand. Removing these will enable you to pack the whole thing into its original box (which you kept) so you can put it on Ebay when you get a bigger model :-)
Sep 16, 2010 | Toshiba Televison & Video
Can you please advise the type of wall bracket required to suit Grundig GLCD3206HDV
Here's a link to a website that has the brackets for your TV
http://www.theplasmacentre.com/tv_wall_bracket_info/247/grundig/32
Aug 03, 2009 | Grundig Televison & Video
I want to wall mount my 26LB30QD but the stand needs to come off, there is nothing in the instuctions on how to remove the stand, please advise.
With the tv laying flat on to the screen, remove the two screws in the recessed holes. Then remove the two screws above towards the input panel, one under AUDIO-L/AUDIO-R and the one under HDMI-1. The stand should easily slide out.
Mar 06, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
How do you remove the table stand from a 19 inch Grundig TV so that a wall bracket may be fitted? Released three screws at rear on the mounting but it would not come off.
there should be a little plastic button bottom middle of the stand plate on the back of the tv, find this press and slide off the stand
Dec 16, 2008 | Televison & Video
How to fit wall bracket to tv
the bracket should have instructions. the set will have screw holes on the back to bolt to the bracket.
more detailed info needs to come from the bracket MFG
Dec 05, 2008 | Televison & Video
Grundig GU22DVDPX 22 in. LCD TV Logo
689 people viewed this question
Top Grundig Televison & Video Experts
Henry  Thomas
Henry Thomas
Raj Patel
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
