Question about Cell Phones
SGH-A801 screen ribbon is broken. is it possible to turn on using keypad or other side buttons?
How to turn off the keypad tone for my samsung d900i
On the phones sides there are two buttons. Press the lower button severally and the tone reduction will be displayed on the screen. Alternatively, go to settings, then select sound profiles then select normal then option, edit then scroll to keypad tone then mute.
Oct 04, 2011 | Samsung SGH-D900 Cellular Phone
My problem is a broken ribbon cable. Is there a
Donor camera off ebay would be your cheapest option. But, You will have to make sure ( some how) that the donor camera has a working keypad. This is an old camera now and the keypad ribbon, where it is folded over ( twice) will have become brittle and split (non working buttons/functions) as yours has.
May 21, 2010 | Fuji FinePix F470 Digital Camera
Screen goes off often
ribbon connecting keypad to screen probably worn new ribbon cost less than a fiver on ebay
May 13, 2010 | Samsung SGH-U600 Cellular Phone
How to take apart the samsung gravity sgh-t459
Remove battery cover and battery. Using a #00 philips head screwdriver, remove the 6 screws around the perimeter. Slide phone open and carefully pry up on the edge of the green (or blue) trim near the space bar. The colored back should unsnap. There will be two philips head screws visible on the now exposed circuit board. Remove these and carefully pull up on the rectangular ribbon cable to disconnect the main circuit board from the keypad circuit. Carefully peel the two button contacts from either side of the phone. On the spacebar edge, there will be a clip holding the circuit board in place. Gently pry it away from the board and the board should come free (there will be clips on the other side but you should be able to lift the free side of the board up and slide it out from under the clips). Remove the QWERTY keypad. Unglue the remaining ribbon cable from the keypad frame. Undo the 8 silver screws securing the keypad frame to the hinge and lift frame off. There will be 4 screws visible on the back of the LCD case. Remove these and insert a thin plastic spudger at the top of the frame and carefully work your way around. The two halves will separate (should hear two snaps on each side). You will now be into the keypad/LCD section of the phone. Removing everything else is pretty straight forward. Follow these directions backwards to reassemble.
Oct 10, 2009 | Samsung Gravity SGH-T459 Cell Phone
Keypad is broken
your phone needs service.
Jul 02, 2009 | Samsung SGH-G600 Cellular Phone
The icons across the top of my screen disappear
Souds like the ribbon connecting screen to keypad is worn tricky job to change it . a new ribbon is less than a fiver on ebay
May 10, 2009 | Samsung SGH-U600
My sons U600 smaung phone has a blank screen, buttons light up when I try and turn it on but turn off when I take my finger off the on button. Nothing works can you help?
the ribbon connecting screen to lower keypad is probably worn
tricky job to change it but can be bought on ebay for less than a fiver
Mar 26, 2009 | Samsung SGH-U600 Cellular Phone
How to turn off keypad sound
hi there to turn off your key pad tones slid open your phone and on the side of the handset there is a up and down button press down untill you get the volume you require.
Jan 27, 2009 | Samsung SGH-G800 Cellular Phone
Picture will not display on my samsung sgh-u600
Probably the ribbon that connects screen to keypad
common fault on this phone
Aug 12, 2008 | Samsung SGH-U600
Keypad
the only thing that you can do is to change the hall keypad.
because if you take off one button, the hall keypad is going to get messed up
Feb 14, 2008 | Samsung SGH-T519 Cellular Phone
Cell Phones Logo
89 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
