Question about Radio Communications
I get a 3sec beep everytime the pc tries to boot from the hd, the actual hard drive is fine, we know this as we have connected to another pc, any suggestions ?
  • 6,831 Answers
Hello
The beep code you are getting has nothing to do with your HDD, it is actually a fault with the ram chip(s) in your computer.
If you have 2 or more ram chips installed, take out all the ram and install the one by one. Doing this you can find out which ram chip is faulty. If you only have one chip installed, take it out and test in in another computer before buying a new chip.
This is how the ram module looks like in general:i get a 3sec beep everytime the pc tries to boot - 06931a6.jpg
Hope this can help
Kind regards
Andrea
Posted on Nov 15, 2009
  • 557 Answers
Remove the memory. Clean the connections and replace. If you have more than one stick try them one at a time.
When my lacie external hard drive is connected,my
Check your BIOS > StartUp sequence
Maybe the USB boot option has much higher priority that HDD boot. Try exchanging their priority and then reboot, with your external HD connected to pc.
Jan 03, 2010 | LaCie (300951U) 500 GB Hard Drive
My Seagate starts to boot up but then goes to a dark blue screen(no words) and you can hear the H.D> working, then the computer beeps once and nothing further happens.
the blue screen, is usually a Hardware Or Software ( operating System error ) The Computer beeping Once, States that The Computers Hardware is Fine. I,d try formatting the hard-drive, and reinstalling Your Operating System et,c. I,d assume this is a missing or corrupt windows system file. Or possible hard-drive error. ( virus-Trojan-Worm ) are also suspect.
Mike @ Compurepair.
Dec 01, 2009 | Dell Dimension 3000 PC Desktop
Pcu will not boot it can't find primary hard drive
go into BIOS and check to see if your HD is being detected.
If you don't know how to access BIOS go here and look up your PC information
or
Open the machine and see physically if your HD is connected.
Jul 13, 2009 | Dell Computers & Internet
IBM T20 hard disk won't start, no display, and beeping
it may be drive issue,:
- replace the hd and cmos battery,
- change boot device priority in BIOS
to 1st: cd/dvd
2nd: hd
3rd: floppy or network boot or usb-boot
- exit BIOS saving changes: yes
- reboot from windows cd-rom for testing the cd drive
- try booting from new hd (if bios recognizes it,
then install operation system
- if still the same prob, see a technician about this issue
Jun 13, 2009 | IBM ThinkPad T20 Notebook
Emachine crash
Yes, with that beeping sound that you're hearing from your hard drive is a sign of a bad hard drive , that's also the reason why the computer wont even boot because the hard drive is already bad, the best thing that you can do here is to get a new hard drive..
Hope that helps..............
Sep 12, 2008 | E-Machines eMachines Desktop PC
Getting error beeps-1-8-2-1 and I need diag. chart info
Try removing all connections to M/board except for Video card and memory and boot if computer boots with no beeps try fitting others one at a time until beeps happen that is faulty unit
if will not boot without beeps try different memory
Also check cables into hard drive are fitted correctly
stripe goes nearest 4 pin power plug on H/D CD DVD and floppy
Aug 24, 2008 | Gigabyte GA-7ZM Motherboard
Boot up problem
youre hd needs an os installing on it.first partition,then format ,then install os(windows)
the system is looking for a os not a hd ;the beeps indicate no os found(no drive by default)
if there is no hd,memory,or video card or stuck key the pc will beep.also with video card not connected the screen will be blank also with many models no memory will result blank screen.In ur case its only the hd.make sure all items are fitted insert os disk in cd drive start pc and boot from cd,to create partition,format and install
Mar 04, 2008 | HP Pavilion dv6000z Notebook
Compaq laptop/no boot up
Initially it may be suspected that your laptop is detecting a hardware problem, probably the hard disk. Since it partially boots and there is display, the following can be ruled out: video card, memory and display systems. That would leave us the hard disk and the motherboard left. If the motherboard is in question, chances are it is the BIOS.
Pls try and verify that the hard disk is connected snugly. The hard drive is usually inside one of the slots covered by a panel/lid held by a single screw.
If your concern has not been corrected after completion of the above procedures, further diagnosis may be required.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 15, 2008 | HP Compaq Presario V2000 Notebook
Quantum 13Gb FIREBALL CX 3.5" IDE HD p/n cx13a013
One word. VIRUS. You know, or you deleted one of windows boot files. Basically, switch to a Mac.
Oct 19, 2007 | Quantum 13Gb FIREBALL CX 3.5" IDE HD p/n...
Radio Communications Logo
57 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
