Question about One For All URC4220 Remote Control
What to press to put code in
I have the code i need put what sequence do i mash
  • Anonymous Jan 11, 2008
    your site is a joke
What if no magic button
Posted on Jan 12, 2008
  • 129 Answers
Hello, follow this link to download the manual and the codes for your remotes:
just right click and save as on the download links.
To input a code hold down the setup or "magic" button until the led flashes twice, when this happens you are ready to type in your code.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
(For replacement remotes visit
Posted on Jan 10, 2008
  • ellibum Mar 23, 2014
    I followed your instructions i got my tv to switch off and back on i pressed the agic button it flashed twice but then it did nothing else and it now wont turn it on or off again. can you help?
How do I save the radio code once I put it in It is a MICRA 2015 build
You need to be certain you are entering the correct code in the correct way to avoid being permanently locked out of the radio.
Different territories and models have slightly differing radios and the coding sequence can vary slightly. The vehicle literature pack should either contain an audio manual or the details will be found in the vehicle handbook.
Sep 21, 2016 | Nissan Micra Cars & Trucks
Car shakes when you put on brakes
When you say that you "mash" the brakes, do you mean that you are pressing ******* the brake pedal? If this is the case, you may be forcing the brakes to go into "Antilock Mode"...this is a NORMAL condition. Otherwise, it could be going into "overactive antilock mode" if you are pressing the pedal normally. This condition is usually caused by malfunctioning wheel speed sensors. You must scan your antilock control module to verify this.
Dec 21, 2011 | 2006 Suzuki Aerio
Need trouble shooting proceedure to enter self diagnostics for maytag neptune
From the service manual there is more to it but that was all I could put here.
Accessing Service/Diagnostic Mode:
Pressing down the damp dry and time (-) keys
for 5 seconds places the machine in the
diagnostic mode.
The following table lists the various tests
available while in the Service Mode, which
can be accessed by pressing the following
Press Keys Special Test/ Function
release Diagnostic Codes
temp(^ )
Sequences up the
help/diagnostic code list
dryer temp(v) Sequences down the
time (-) Displays Software Revision
very dry(< ) View current cycle
temperature (Co)
Start or pause cycle running
but remain in Diagnostic
Accessing Diagnostic Codes
After the machine is in the diagnostic mode,
a ‘d’ will display and let the technician know
they are in the diagnostic mode. Pressing the
wrinkle release key will access the diagnostic
codes.The diagnostic codes can be viewed by
using the temperature (^) & (v) keys.
The down arrow key will sequence down the
list one each time it is pushed with no wrap.
The first time the down arrow key is pushed
the display will sequence to the next code
logged. The last code being displayed being
the oldest code. The up arrow will sequence
up the list one code each time it is pushed
until it reaches the top code. If there are no
diagnostic codes available, ‘00‘ will be
displayed for the diagnostic code.
There will be no multiple occurrences of
either a diagnostic code or help code generated
in the same cycle reported on the list.
But if the same code occurs in repeated
cycles, it will be registered.
To clear the diagnostic code list press
wrinkle prevent and very dry (>) for 5
seconds while viewing the list.
System Check Mode
While in diagnostic mode, pressing the damp
and signal (+) keys for 2 seconds, will
put the dryer into the system check mode.
"SC" will display.
This mode will allow the various inputs and
outputs to be controlled and viewed by the
technician by pressing individual keys. If no
activity is seen for 5 minutes after a key is
depressed, the control will reset back to the
normal mode. If no further activity is seen
after an additional 5 minutes the washer will
turn off. The following table lists the various
functions based upon on keys being depressed.
Membrane Pad Check
While in system check mode, pressing the
damp dry and sensor dry keys for 5 seconds,
will start a membrane pad switch test.
The membrane check involves turning all the
embedded LED on the membrane pad on.
All the LED’s can be toggled off by pressing
the key associated with the LED. To exit the
test at any point, press the damp dry (>) &
sensor dry keys again for 5 seconds or press
the off key to exit diagnostic mode.
Key Pressed: Function Performed
sensor dry
Enable sensor dry circuit.
(sense dry LED) When short
circuit is detected across the
sensor bars the normal dry
LED will turn on.
start/ pause
Cycles the motor relay
on/off. When the motor is
running the start/pause LED
is on.
dry temp(^ )
If motor is running, cycles
the heater/gas valve on/off.
When the heater is regular
temp LED is on.
temperature (Co)
Mar 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I need instructions to turn off service light in 1995 850 volvo
Keep pen and paper ready, as you might have to write down error-codes as you want to do this.
Turn ignition OFF
open the lids of the diagnostic sockets situated in front of the enginecompartment (by the fillercap for the windshieldwasherfluid)
Put the socket with a short lead on in the hole marked "1" on module A
Turn ignition ON
press the pushbutton on the top for about 1 second and WAIT.
The LED will blink in a sequence that indicates if there is any problems that need to be solved.
The led will blink 1 to 5 times, have a pause, blink 1-5 times , have a pause and blink 1-5 times.
Write down the sequence as you count the blinking. eg: 1-3-1
When one sequence is finished, you press the pushbutton again, and read the next code.
Repeat this until you read the first code again.
If the first code reads 1-1-1, all is OK and you can proceed.
After this you can reset the servicelamp:
Leave the connector in socket 1 on modula A.
Turn ignition OFF
Turn ignition ON again
Press the pushbutton for 5 seconds. Be patient.
Release the pushbutton and wait about three seconds, then the LED starts to blink rapidly
press the pushbutton for 5 seconds again and release it.
Turn the ignition OFF
Remove the connector from the socket, replace the lids and put the connector back in its rest.
Turn on ignition and start engine, the service lamp should not be on.
Any error-codes? Refeer to a Volvo-dealer.
Jun 30, 2009 | 1995 Volvo 850
Unfreeze code does not work
I am not a technical person, but I know how to unlock mobiles as I was used to it, I used
Mar 16, 2009 | Samsung Cell Phones
DS Lite's A button is mashed in from button mashing.
try pushing it in and wiggle it straight, if half is mashed push the other half in that should do it
Mar 12, 2009 | Nintendo DS Lite Console
Change boot sequence for HP L2000
You need to enter BIOS at startup. The correct key to press will be displayed at the bottom of the black screen when you bootup. Usually, F10, F8 or F11 or Del. Mash them all on booting up.
Now navigate the Bios settings with the arrow buttons and select cdrom as 1st boot device with the enter button. Then Save and Exit.
Chris (ziraffa)
Jan 10, 2009 | HP 418446-001 - HP Special Edition L2000...
Error Code
All you can do is Reinstall windows. You should get the Windows Vista Installation CD with your laptop and all you have to do is put it in and restart your computer and when the message that says "Press any key to boot from CD" press a key.
If it doesn't show up, you may have to press a key like DEL or F12 to get the boot sequencer. When you first turn on the computer you should see the Compaq logo. At the bottom of the screen you should see some buttons to press to do things like BIOS and Boot Sequence. You want Boot Sequence. Once in boot sequence, select the CD-DVD and press any key when it says to.
Once in follow instructions or oyu can reply and i will tell you how to install.
Oct 06, 2008 | Compaq Computers & Internet
Need unlock code for Toshiba dvd player/recorder RD-XS24. Can anyone help? Thanks. tomr.
Ensure that there is no disc in the tray,
Using the remote:
1, Press the “0” button 5 times at approximately one second intervals.
2, Press the “Instant replay” button.
3, Press the following sequence of numbers very quicly (less than one second
intervals) :
If your player is a Region 1 machine, the sequence of numbers to press is 2,
9, 3, 3, 4 and 9 :
If your player is a Region 2 machine, the sequence of numbers to press is 5,
7, 5, 3, 8 and 9 :
If your player is a Region 3 machine, the sequence of numbers to press is 5,
6, 7, 3, 2 and 9 :
If your player is a Region 4 machine, the sequence of numbers to press is 5,
6, 8, 8, 4 and 9 :
If your player is a Region 5 machine, the sequence of numbers to press is 5,
3, 8, 1, 4 and 9 :
If your player is a Region 6 machine, the sequence of numbers to press is 2,
4, 4, 6, 2 and 9 :
4, Open and then close the tray.
Jul 30, 2008 | Toshiba Televison & Video
Need code for durabrand portable dvd player
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
One For All URC4220 Remote Control Logo
74 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
