Question about Ovens
Glass for stove
Hi just trying to chase up a new piece of glass for the front door of my stove its fridgidaire and the model number is fe537
  • 26 Answers
You need the full model # off the range not the owners manual
Posted on Jan 09, 2008
I have a bassano oven and my door has smashed i am not sure where i can buy bassono parts in qld, thanks
I believe bassano is a type or model name and likely to be little or no use when trying to locate spare parts. You will need more details, including the name of the manufacturer and possibly the serial number as well as the model number.
Appliances, like cars, are often badge engineered - where similar models are produced by the same manufacturer with slight differences in specification but named differently because they are destined for different markets.
You should find manufacturer details in the instruction book or if that is absent an experienced white appliance engineer might recognise the parent company from sight.
If all else fails it should be possible to have a replacement glass door manufactured. A local glazing expert should be able to advise you. Such things aren't cheap but neither are replacement glass oven doors and a manufactured door could even be cheaper, but of course a manufactured replacement will not be painted.
Jun 27, 2016 | Ovens
Replacing oven door glass
You didn't say what brand or model but here is a link to a youtube video for a Frigidaire oven, Other brands and models on youtube too. You will probably be able to get a replacement kit from sears parts direct if you have the brand and model number. Or an appliance parts store or ebay.
Range Stove Oven Repair Replacing the Inner Oven Door Glass Frigidaire...
Aug 16, 2014 | Ovens
The black tinted outer glass of my univa stove broke in pieces, can you replace it or make another glass the same?
Go to appliancepros.com and put in your model number and look up the glass. They will give you the price. I know on most models u can order the glass without buying the whole door.
Apr 23, 2014 | Maytag Ovens
Trying to find piece of heat resistant fabric (don't know name - something like old asbestos) to replace degenerating fabric on light fixture gasket on otherwise perfectly working caloric electric wall...
If it would help you to find the model number, I would look for a way to remove the oven door. Usually there will be a release near the hinge bracket that you push in or push to the side to allow the bracket to release and you can remove the door to see the ID plate. Otherwise, I would suggest going to a wood stove dealer and looking at the door gasket material they have in stock. They usually have rolls of heat resistant gaskets for sealing doors and glass panels in wood stoves. Last idea would be exhaust gasket material available at Napa Auto parts. Good luck!!
Nov 04, 2013 | Ovens
Our top oven inner door glass for the model 720EF shattered and we need a new one. The number is 059040415.D you sell such a thing and if so how much?
Try espares. If the part is not listed, there is a section where you can leave your requirements and they will get back to you.
Apr 05, 2011 | Stoves 720EF Electric Double Oven
Cleaner has gotten behind the front glass, how can i remove the front glass? thankyou
Here is a tip that I wrote about the oven door glass replacement...
You can use it for getting to the glass also...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Dec 10, 2010 | Ovens
The front glass blew out of it! Completely shattered and no one had touched it. Now we need to clean it up. I suppose we need to take off the door and get a new one. OR do we get a new glass plate and...
Hi and welcome to FixYa I am Kelly.
Since you did not include a model number this solution will be from the hip as I can not refer to any manuals to assist you. Most ovens the oven door comes off by tilting the door out to the first stop and then lifting is vertical inline with the position of the hinge at the bottom of the door. Some of them may have retaining screws on the inside of the door to keep the door attached to the hinge area that must be removed FIRST. The hinge itself should stay attached to the oven.
I can probably provide you with a source (Maybe more than one) for the door glass if you respond with a model number,
When you attempt to take the door apart lay it down on 2 rugs so you do not scratch it. Use some blocks of wood UNDER the rugs to prop the door up so as not to damage the handle.
The door glass is replaced by removing the screws from the indide of the door. Sometimes you have to remove the trim pieces in addition to the multiple door panels. Everything is done from the inside of the door. You must take out the inner panel, Then the inner glass, then the spacer, the insulation if any and finally the outer door glass. Reassembly is in reverse order. Outer glass, spacer, insulation if any inner glass, the inner panel and re-install the trim if you had to remove it.
Thanks for choosing FixYa.
Kelly
Sep 11, 2010 | Ovens
Broken glass front panel
Have the make and model number and contact any appliance parts supply, they can order the glass. or call a service man who can do it.
Nov 01, 2008 | Ovens
Ovens Logo
78 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
