Question about Lifetime PQI24200-1GSB TurboMemory 1GB PC2-4200 DDR2 533MHz 3-3-3-8 PC Memory SDRAM with Mirrored Black Coppe... Graphic Card
Sd cards How do I use the sd card in my nuvi 260 so I can load more favorites address?
    Genius:
  • 1,067 Answers
Maby format it 1st with card reader in windows to what that nuvi takes ntsc or is it fat format
Posted on Jan 21, 2008
Need to know how i update the maps card for it
The latest version of Garmin Express provides the ability to install a map update directly to an SD card.
The SD card installation option will only appear when updating a compatible device that does not have sufficient internal memory for the largest allowable map region. When using the SD card installation option, critical files are loaded to the SD card so it must remain in the device after the update to ensure full functionality. For the largest size SD card a device can use, refer to: What is the largest size Secure Digital (SD) card that an automotive device can accept?
The SD card support during the map update will only function with up-to-date software. It may be necessary to update the device's software with Garmin Express prior to updating the maps. These devices do not support the SD card option:
  • Nissan 700
  • nuvi 295
  • nuvi 300 series
  • nuvi 500 series
  • nuvi 600 series
  • nuvi 800 series
  • nuvi 805 series
  • nuvi 5000
  • StreetPilot series
  • zumo 450
  • zumo 550
  • zumo 665
For devices that do not support using the SD card with the map update application, any maps that do not fit in the internal memory can be installed to the SD card manually, using these instructions:
Try the link.it may help.Under support.
Garmin United States Home
Nov 09, 2015 | GPS
We downloaded a European map onto the SD card, however, when we look at maps available, the Garmin 260 is not looking at the map on the SD card. How do we tell the device to use the card to search for the...
You need to download the map to your compute rather than the SD card. When downloading the default destination is the satnav but you can change it to your computer. When it's installed to your computer you then click the windows START button and in the list of programs you'll find a GARMIN folder with a program called MAPINSTALL. Connect the satnav to your computer with the SD card in. Run MAPINSTALL and select the SD card as the destination.
You can get more details of how to do it at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
Note maps installed to SD cards do not always work with Garmin Nuvis. To give it every chance of success please follow the instructions at the above link about formatting the SD card.
Jun 14, 2011 | Garmin nuvi 260W GPS Receiver
My garmin nuvi 215w does not safe any address on my sd card.why?
When you are saving POI's and favorites they will be stored on the internal memory of the GPS, these can be transferred VIA PC to your SD if you wish. You will need to go into the internal memory and copy the folder to your SD card manually.
Hope this helps!
Apr 27, 2011 | Garmin nuvi 215 GPS Receiver
Garmin nuvi 1340 freezes on start up
If your nuvi series device is freezing on the map screen but still providing voice prompts there are two steps you can try to resolve the issue including updating the software using WebUpdater* and performing a master reset.
To download WebUpdater and update the software:
  1. Go to http://www8.garmin.com/products/webupdater/howtoinstall.jsp
  2. Follow the on screen instructions.
To perform a master reset on your nuvi series device: CLICK HERE
Warning: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 18, 2010 | Garmin nuvi 1300 Car GPS Receiver
Can't unlock maps on the SD card
I am still waiting for the promised free solution suggestions
Jun 12, 2009 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 360 can't read sd card
Make sure you format first the sd card and then the maximum giga byte is 2 mb and the minimum is 16 mb.
Jun 09, 2009 | Garmin NUVI 360 GPS Receiver
Have usa garmin nuvi 260 ,want to load austalia maps how?
well you need to update the firmware of your gps also call garmin customer support they are great tell them about the map, also the poor satelite cover might be because of your location or weather conditions
May 26, 2009 | Garmin nuvi 200W GPS Receiver
How do youcess your sd card on the garmin nuvi 200w series please
i lost my card for my garmin nuvi 200w series do i really need it
Mar 21, 2009 | Garmin nuvi 200W GPS Receiver
SD card access problem (nuvi 660)
Try seeing if your computer can recognize the card in a card reader. Your SD card might be corrupt.
Sep 26, 2008 | Garmin Nuvi 660 GPS Receiver
SD Card slot Garmin nuvii 260
I have found that waypoints, routes and directions work only when I load it on the unit itself as opposed to the SD card. The SD card works more like an expansion slot for pictures or maps.
When you open up Mapsource you'll see the map on the right and the pane on the left, above the pane there are 4 tabs (Maps, Waypoints, Routes and Tracks). As you select a map or create a waypoint, route or track. It will put a number in parenthesis which will increase in numbers as you add an item corresponding to each category, for example if you create a waypoint. So once you have done that, click on the TRANSFER tab in the Menu selection bar and choose SEND TO DEVICE. A window will pop up that will say...Device: with a drop down menu if your Garmin unit has an SD card in it, if not it will just show the Garmin unit. Then right below that there will be a section that says WHAT TO SEND with 4 check boxes that will say Maps, Waypoints, Routes and Tracks. Make sure that you have selected the Garmin unit, not the SD, and the waypoints, routes or tracks you want to send. I hope this solves your problem or at least points you in the right direction...
Jun 20, 2008 | Garmin nuvi 200W GPS Receiver
Computers & Internet Logo
78 people viewed this question
Top Lifetime Computers & Internet Experts
Corey Bartlett
Level 1 Expert
Paul Bade
GG TECHNOLOGIES
Are you a Lifetime Computer and Internet Expert? Answer questions, earn points and help others
