Question about Ovens
Operating instructions
Where do I get operating instructions for a new, Kenmore 30" gas stove... The delivery techs told us that they do not provide instructions any more, I needed to get that off the web?????
  • 26 Answers
Go to then customer care and enter your model # in search box to find and download your manual
Posted on Jan 09, 2008
Hello, We have a Kenmore gas stove model # 71761. The burners on top work good.The issue is with the oven portion. Oven is working. Flame comes on upon ignition to desired temperature setting and then...
It sounds like yous stove is working fine. Cycles fine. If you think the stove is cycling more often than when new then ck the seal on the door. You may be loosing heat.
Jan 14, 2011 | Ovens
My kenmore electric oven works on the 4 burners on top, but the oven part does not heat at all.
There is an upper and lower burner, since it's not heating at all it's either your gas control valve or your temperature control board.
Note: If you have Sears service come out to repair your stove beware, We had them fix our stove. They told us there would be a $65 charge for them to come out but if we had the repair done it would be included in the repair price. Instead after they had our stove torn all apart they told us we would have to pay both charges or they would just leave with our stove in piece and we would still owe them the $65.
Jun 11, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
My 3 year old barely used Whirlpool Gas Oven has stopped heating. The gas stove top still works. Whirlpool customer service told me to clean out the gas chamber with a pin...there's nothing TO cleanout....
Just had a repairman here today March 31, 2010 for the same problem. $350 repair bill. There was a short in the gas valve that cause it to go bad and it also blew out the ignitaion computer board. Forget about replacing the ignitor. I already did and that was not the problem. So the qauestion for you is pay for the repair or buy a new stove.
Mar 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My Gas stove Kenmore Model #362.75471690 The
you need new glow coil for over it may looklike its working glowing orange but it isnt getting hot enough so you neeed replace it
Feb 03, 2010 | Ovens
Kenmore stove oven does not shut off
Wow, this post is going to be extremely late. Actually, I was able to get a new control unit for my Kenmore gas range from Sears Parts Dirext for $156.06. That includes shipping and tax. The burners work without it. We just cannot use the oven until the new board comes in. It's very easy to replace. Remove the panel screws on the back (just the top) and you have access to unplug the unit and remove the 4 screws holding the assembly in.
Jun 05, 2009 | Kenmore Ovens
Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
Apr 16, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
My kenmore electronic stove is having a beep with code F1 on the
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Mounting a microwave above stove
A copy of the installation instructions for your units should contain how far it should be.Try to study it. You'll likely find that the over the range units will fit the standard 30" cabinet and also provide the required clearance to the range top. Consider the following:- power source (dedicated circuit, with an outlet box in the cabinet above). Venting (outside ot inside), and attaching method. Though they're simple in concept to install, it's a bit awkward in reality. The main thing you need to determine is sufficient space between the MW and the stove. You will have to check, but I believe you need 18" beneath the microwave. Many companies have brackets for that purpose.
Jul 15, 2008 | Frigidaire FGB24S5A Gas Single Oven
Pilot light
When you smell it all the time? If so, this is dangerous. If it only happens when you're trying to start the oven, no problem. Push the red button and hold it while lighting the pilot. Hold for 30 REAL seconds more. Release. The pilot should stay lit. If not, get a service tech.
Jun 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
I have a double gas oven and no instructions
I have an O'Keefe & Merritt double oven gas stove. The model number is 72 7242 23. The upper oven is about the size of a large microwave and sits above the range burners. The lower (full-size) oven is below the burner unit and includes a broiler draw below it.
So, when you say, double oven, I wonder if you are just talking about the main oven with broiler drawer (both of which are below the burner unit.)
Mine was a builder-supplied appliance in the new house we purchased in 1986. The upper oven has never performed very well. And, yes the upper oven can only be used for baking.
I have an instruction manual for it, but it doesn't provide that much information. Getting parts for it is extremely difficult, since Tappan is no longer manufacturing this brand. (I've been trying to locate a flat oven ignitor for the upper oven and can't seem to find a replacement that's the same 6-1/3" length.) In the 1980s Tappan apparently purchased O'Keefe & Merritt and marketed this brand for several years. Models originally manufactured by O'Keefe & Merritt in the 1930s-1950s are considered collectible antique stoves!
If you want to email me, I'm at
Apr 20, 2008 | Stoves Premier 900GRa Gas Double Oven
Ovens Logo
90 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
