Question about RSQ ECHO-E500 Portable DVD/ CDG/ VCD/ CD Karaoke System
RSQ E500N Tray will not open, plays disk that is in the machine.
4 Suggested Answers
  • 11 Answers
SOURCE: The tray won't open.
something like this is a physical problem. you should contact the manufacturer to see if there is a manual eject button and if not you will have to take it apart to get the disk.
Posted on Oct 29, 2008
IrishDruid
  • 2712 Answers
SOURCE: Why won't the disk tray open?
Press the eject button and using two small screwdrivers on either side of the tray, try to manually coax the tray out GENTLY.
SOURCE: RSQ e500n
did the same thing on setting up! there is either a p/n or v-mode button on the remote try pressing it a few times! hope this works for you
Posted on Nov 27, 2008
Why do my CD tray keep ejecting?
Seems that what you have is an error or bug in your system. This is not an uncommon issue with your kind of karaoke machine. Your best bet is to call the manufacture RSQ who have an excellent customer service staff. They will most likely have you senf it in but for tye most part, because it is a programming issue, should fix and send it back free of charge.
Mar 08, 2016 | RSQ NEO-22 Multi Format Karaoke Player
Had the RSQ HD 787 for almost a year and now i am having problems. Need help. Can you help me?
Try this:
1. Login as an administrator and open "Device Manager"
2. Click on View and select "Show Hidden Devices"
3. Open "Disk Drives"
4. Delete any device that is grayed out
5. Disconnect your usb cable and reboot your laptop
6. When Windows is fully loaded reconnect your usb cable
Hope that does it for you.
May 16, 2014 | RSQ HD-787 HDD Multi-Format Karaoke Player...
Cd tray will not open or load cd
try to use a safety pin to slide the tray out. u might see a small hole in the tray just slide in ur pin and push it, it might work
May 06, 2014 | RSQ HD-787
The disc tray does not open in my RSQ NK2000U
I have the same problem wtih a RSQ500. I removed the cover and unscrew the top of the disk drive to remove the disk that was inside. I going to try to put the cover back and see if it works
Mar 21, 2013 | RSQ NK 2000U
I need a manuel for my RSQ-MV-333, where can I get one?
Retrevo has the manual for the RSQ MV-333 here: http://www.retrevo.com/support/RSQ-MV333-DVD-Players-manual/id/8203ag317/t/2/ . You will need to enter a code to download the file; then use Adobe Reader or a similar program to read the manual.
The unit can play compact discs with digital video, compact discs with digital video and playback control, CD-G (compact disc - Graphic) and audio CDs (finalized CD-A discs, not MP3s or open CDs made on your computer).
I hope this helps.
Dec 20, 2012 | Cars & Trucks
Hi, after about an hour of playing, my machine starts missing parts of song, often sticks and skips tracks, it does this on all the formats that we use, ie CD+G , Neo+G, Zoom DVD, RSQ SH01 [ 1200 songs ]...
This sounds like a CD read error problem. I would clean the read head (read instructions for this as the head is very fragile).
If there is any chance of warranty being active, exercise it.
ALSO verify the discs are CLEAN with no smudges on the read surface. If you have dirt, clean with windex, rinse, and wipe OUTWARD radially, not in circles.
Remember these disks read from inside out unlike phonograph records.
Feb 15, 2011 | RSQ Neo Nk-2000 Dvd Karaoke Player Nk...
No sound from rsq e500n
S-VIDEO only carries the video signal and NOT the sounds.
You would also need to hook up the audio leads (red nd white phono) also for it to fully work.
Dec 06, 2008 | RSQ NEO-E500 DVD Player
Door wont open on the RSQ E500 player. seems to freeze when open button is pressed
I found the drive mechanism to be stuck. Also there was a little oxidation on the pins on the drive tray plug. Solution was to move the lever underneath and to the front of the drive to free the mechanism, and remove and clean the pins on the plug. Worked fine after that
Nov 08, 2008 | RSQ NEO-E500 DVD Player
Rsq s222 karaoke
rsq karaoke machine. words of songs skiped or spaces on screen and also get jumbled? checked disk and tried other good known disk same result.
May 13, 2008 | Televison & Video
RSQ e500n
Dec 22, 2007 | RSQ NEO-E500 DVD Player
RSQ ECHO-E500 Portable DVD/ CDG/ VCD/ CD Karaoke System Logo
149 people viewed this question
Top RSQ Televison & Video Experts
Are you a RSQ Televison and Video Expert? Answer questions, earn points and help others
