1991 Isuzu Trooper Logo
Posted on Nov 15, 2009
After driving for 30 mintues if i turn off the car it will not restart untill it cools down. Then starts up and runs like a dream. What is wrong?
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on May 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
405
Points
5
I would check sensors.I have seen other brands with bad sensors kill the engine when it heats up.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Nov 15, 2009
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
1259
Points
18
Could be the plugs are oiled up until it cools down , the oil is gone of it and will restart
Drivability problems after driving 20 - 30 miles
Try changing or switching out the distributor. Most likely getting hot and shuts down. Does it crank but no start whenever it stops? May only start when it cools down again.
2answers
After highway driving for 2 hours and stopping for gas the car would initially start and then stall, it would run again until the car cooled for 30 minutes.
Sounds like your coolant level might be low. At highway speed you probably have enough coolant and with the air passing thru the radiator keeps the temp down, but at idle not so much. Or depending whether you have a belt drive or electric fan. Belt driven, could need a new belt.
I have a 1993 ford mustang with the six cylinder engine. I have an over-heating problem. Every once and a while (almost rarely) the engine overheats. When it does, the air out of the heater becomes...
this could be a couple of things - you might check to make sure the fan is spinning ok ( it could be going out or not spinning proper ) ,, also check that your water pump belt is at the correct tension, make sure your anti-freeze and water is at the proper ratio, and I know that you said that you replaced the thermostat - but there is a chance that the thermostat is not opening all the way and is restricting water flow. since you also brought up the ' heater blowing cold ' problem, I would say that there seems to be a water cirulation issue -- ( again to the pump or thermostat ).
c...
Can the anti-theft system be disabled on this '02 Taurus? Dealer has replaced PATS sensor, recoded keys/remote, and it still starts intermittently...and they have no more ideas!...and they still have the...
car quits after 30 miniutes of run time no enjine codes fuel system is ok enjine will not restart untill i turn the key to the off position but will only run intermitantly untill you lit it cool down then the same thing all over again
1995 Daewoo Racer, Stops suddenly for no apparent reason.
Check heat level of your at that time. A sensor is installed in its Radiator, which automatically turn off the vehicle (as the Temperature needle crosses 3/4) until its temperature falls. In case it is true, then; 1) clean its radiator 2) Check the sensor installed in its radiator. (this sensor was not available in 1993 model)
Car starts then quits. have to wait about 20 mintues
I have the same problem with my bimmer.To find out if the fuel pump problem take fuel pump out and get something kinda nock on the pump put it back in and start the car. It will run but not 1 or 2 days it will die again. You know that mean.Replace the pump.
1helpful
1998 ford explorer stalls when driving, have to wait 30 minutes
possible fuel pump. Try spraying starting fluid into breather while someone is cranking engine. if vehicle tries to run it is fuel problem. If not it could be an electrical componet overheating and cooling and restarting. Coils, relays, ecm.
1helpful
2answers
1999 4.0L Jeep Grand Cherokee shuts down after 20-30 minutes.
I'd suggest the ignition control module, however I'd have a certified mechanic check it out just in case...
Top Isuzu Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you an Isuzu Expert? Answer questions, earn points and help others
