Question about Dell Dimension 4700 PC Desktop
Sata hdd windows dell recovery cd will partition install windows
Sata hdd windows dell recovery cd will partition and copy files during installation multiple .dll files will not copy hit esc to skip files and system goes to blue screen stop error .
  • 59 Answers
The system is originally designed to use IDE HDD, make sure the necessary chages for Sata HDD are made in the BIOS, next make sure the Recovery disc is fine without any scratches. You can order a new Windows OEM recovery disc by calling Dell tech support (1-800-624-9896-US) and try installing the OS. The disc will cost you not more than $12.
Posted on Nov 15, 2009
How do I make Dell 530s boot and load windows?
Are there any sets of audio 'beeps' that occur during startup? If you get anything other than a single beep during startup, it could indicate an error code for hardware failure detected during the POST phase of bootup.
If you have recovery or Windows installation CD's, try pressing F12, go to the bootup menu and try booting from the CD.
Look at the bootup menu and see if there is a hard drive as one of the options. If the hard drive is not there, or if you try to boot from the hard drive from that menu and you get error messages, that might indicate something wrong with the hard drive.
If you can boot from the CD, you may be able to use the Windows Recovery Manager to restore Windows on your hard drive, if the hard drive is working. There may also be a recovery partition on the drive that will allow you to recover Windows, but beware that files on the hard drive may be lost when you use the recovery partition.
If you have files on the hard drive you need to recover, you may be able to remove the hard drive, put it on an USB drive adapter, and use another PC to copy files off of the old drive, even if it cannot boot the old computer. After you have recovered your files, you can try the recovery partition or format the drive and use Windows install disks to restore Windows to the drive.
Apr 01, 2015 | Dell Computers & Internet
Rv510 disc controller
You may have a manufacturer recovery partion that windows installer see but it's uwriteable as it's protected. The usual partion is C:
Try again with C: as the partion, if it's not C: then look for the biggest partion, usually in Mb's.
Jul 08, 2017 | Computers & Internet
Reload windows XP without loosing data
If you have free space just make new partition and install there otherwise bootfrom any external cd with file manager and copy to something like a portable hdd or large usb.
May 01, 2012 | Dell Precision M70 Notebook
The HDD of my Acer Aspire 5102WLMi got broken. I bought a new one, partitoned it, load the D: drive with Acer stuff from backup, mounted it in the laptop and started this with the recovery CD. This...
@hellepie
The HDD interface on this machine is a PATA so BIOS shows the correct interface as IDE 0. Upon loading up the recovery disc (I'm assuming it's a good condition genuine Acer recovery media), what it does is that it re-images the HDD to the default file system and automatically occupies the full partition of the HDD so if you have already re-partition it, the problem might lie right there. Try to do the following:
1. Erase all partition on the new HDD that you have purchased and format it with NTFS and try to load the Acer recovery discs again.
2. If that won't work, try to use a retail copy of Windows and check if it fully install Windows. If it does, try to create a duplicate copy of your Acer recovery discs, it might just be faulty and try again.
Good Luck.
Sep 04, 2011 | Acer Computers & Internet
Windows won't recognize the HDD in my Dell XPS 400.
hawkdawg
In regards to installing your new harddrive if you are installed a SATA drive the issue is that not all versions of Windows has SATA drives native on the Windows install CD. So during the first part of the install you will need to press F6 to load the SATA drivers of the driver CD. If you do not have it you can download the drivers from support.dell.com
Let me know if you have any more problems or questions
Issken
Apr 13, 2010 | Dell XPS 400 PC Desktop
Dimension 4700 with Barracuda 500Gb SATA HDD
You have to go online and search then download the drivers for preparing SATA laptop harddrives for installation of Windows XP otherwise during installation it will tell you there is no hard drive found.
Dec 12, 2008 | Dell Dimension 4700 PC Desktop
Failing install of PCI SATA Drive
You need to load the SATA Controller driver for the XP install to access the HDD.
The driver will need to be downloaded and extracted to a floppy diskette, then loaded during the XP install.
If your system doesn't have a floppy drive, you'll either need a USB floppy drive or create a slipstreamed XP CD with the driver added to the CD.
Aug 12, 2008 | Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
Xp professional installation on hp pavilion dv6700 cto notebook
The original Windows XP Installation CD, a freeware application named NLite and a blank CD.
we need the drivers for the SATA controller provided by the manufacturer.
When you start the Nlite application, you will be asked to provide the location for the Windows installation package. Insert the genuine Windows Installation CD into the CD drive and, inside the application, select the CD drive letter.
To insert the SATA drivers within the installation package, you need to have it saved on the HDD. Hence, when the warning window appears click OK and select the destination folder for the files to be saved. Make sure that the destination partition / HDD has enough space to store the contents of the installation CD.
Immediately after you have chosen the destination folder, the application will start copying the Windows installation files. When finished, it will display some version information regarding the newly copied Windows Installation Package.
Now, click next twice until you get to a screen where you get options sorted in 4 categories: Integrate, Remove, Setup, Create. We are interested in the integration procedure, therefore select the Drivers button and click next. From the next menu window, click Import and select multiple drive folder option from the drop down menu. This option permits you to browse to the location where the downloaded drivers are found.
Select the containing directory and click next. You will get a list with the available drivers (in case there are more than one) or simply one driver. Select it (them) and click next. Now the application will ask for the permission to start the integration procedure. Choose Yes and wait for the drivers to be inserted into the installation package.
With problematic driver being included in the installation package you can install Windows XP on your SATA HDD...but...the installation package is on the HDD. You need a bootable CD in order to start an installation. Don't worry, once the installation package has been adorned with additional user selected drivers it can be transformed into a bootable disk image and later burned on a CD. To encapsulate the installation into a ISO image use the same Nlite application.
Open it, make sure the HDD installation folder is selected and click next. Select "Last session" preset and click next again. Now from the options menu choose Bootable ISO and click next. In the following window, make sure that the mode is set to "Create Image" and click Make ISO. A destination folder is required where the resulting ISO image will be saved. Once the image saving process finished you have the freedom to burn it on a blank CD with whatever you favorite CD burner software may be.
The new CD will be the twin copy of the Windows Installation CD but with one difference, it includes the SATA driver
Mar 17, 2008 | Microsoft Windows XP Professional With...
Recovery partition - repair
You have obviously deleted the partition that the laptop could recover from but usually if you are supplied a cd to recover windows, there is normally a drivers folder within the cd but not the aplications, such as anti virus although these are only for a trial period. for things like microsoft works if supplied, are normally on a seperate cd. Without knowledge of your partition software, you should be able to partition the HDD and then copy the files from one drive to another, but the restore may not work as the system files may not weave together when you come to restore. I would imagine it's only the drivers that's youre main concern, which you can install from your other laptop.
Jan 31, 2007 | IBM ThinkPad T30 2366 Notebook
Dell Dimension 4700 PC Desktop Logo
122 people viewed this question
Alun Cox
