Question about Drills
HAve clausing 1650. Large Drill bits overheat and
HAve clausing 1650. Large Drill bits overheat and basically melt without cutting after initially starting. Bits show wear behind point.
    Guru:
  • 597 Answers
You should use a honing type of oil when drilling with large bits. There is a tremendous amount of friction and the oil keeps the bits cooler when cutting.
Posted on Nov 15, 2009
How do I remove a stripped bolt from my front brake caliper it's an 2005 Suzuki boulevard c90 need to change front brake pads
They make tools for this. Bolt extractors. You will have to heat them up a bit to get them out easily. Propane torch.
Apr 18, 2016 | Suzuki Cars & Trucks
Drill overheat
Soap might work. Some use candle wax, bees wax, WD 40. I've prayed silicone on the drill bit. Using moderate pressure and low speed definitely helps, and it is essential to clear out the hole of chips frequently. So drilling in increments works. You drill a little, lift the bit up out of the hole to clear the chips. Also the type of bit used is a factor in drilling efficiency: wood boring bits are a good choice. Forstner bits are excellent, and spade bits are just OK. Hope this helps....
Oct 15, 2013 | Drills
How do i use a spade bit?
I'm assuming you mean a spade drill bit?
For best results, try clamping a block of hardwood to the back side of the stock before drilling. When the bit approaches the end of the cut, it will be far less likely to blow through with another piece of wood to drill. However, if the stock placed on the back side is softer than the workpiece, or if it is not securely clamped to the workpiece, tear out can still occur.
To use a spade drill bit, mark the center point of the hole to be drilled on the wood, and install the shank of the bit into the drill. Align the point of the pilot tip of the spade drill bit with the mark on the wood, and adjust the angle of the handheld drill so that the shank of the bit is square to the surface of the wood. (Of course, if you're using a drill press, the bit's angle should already be square to the surface of the wood, unless your drill table is not square to the motor).
Depress the trigger of your drill slightly to engage the motor and turn the bit slowly. Hold the drill as still as possible so that the pilot point stays aligned with the mark on the wood. Because pilot tips can often "walk" away from the intended center point of the hole, some woodworkers will pre-drill the pilot hole using a small-diameter twist drill bit that is less likely to walk, and then proceed with the spade drill bit's pilot tip into the pre-drilled pilot hole.
Once the pilot tip is in place and engaged with the wood, increase the speed and proceed to drill the large diameter hole with the spade drill bit. Continue drilling until you reach the opposite side of the wood and the bit pokes out through the completed hole. Slow the speed of the motor, and pull the drill bit out of the completed hole.
For more details, check out my source: (link)
Mar 23, 2013 | YouTube Videos
Need the best bit for drilling through books without tearing internal pages
If you use a brad point bit or forstner bit or any bit that cuts around the circumference of the hole, you will create a disc of paper (several pages thick) that will spin at the bottom of the hole and impede your drilling, so those are out. If you use a standard twist drill you get a very rough hole and the pages tend to lift up. The simplest and cheapest is a standard twist drill but with scraps wood above and below the book, clamping the book tight. You might try a plug cutter that has an exit hole for the little discs of paper. Or, use a paper drill bit, these are about $40 and I have never tried one.
Jan 21, 2013 | Craftsman 3/8 in. Drill Press Bit,...
Mybrand new RZ20 keyless chuck will not close around a bit.
If a large enough drill bit is inserted too far so it bottoms in the chuck, the jaws run into the bottomed shank and will not close beyond a certain point due to the interference. If you hold the drill bit out about 1/2 inch from the bottom, the jaws should close on the bit. I assume you have tested the chuck without a bit to verify they can close.
Feb 15, 2012 | Drills
My bit in my drill is stuck into a large tree stump... that had been cut close to the ground. How can I get the bit unstuck? My dewalt drill is unable to drill in & drill out.
If it's a twist bit try putting a vice-grip pliers on the end and turn it so the fluting pushes the bit out. If it won't move or if it's a spade bit you'll have to split the wood around the bit. You may or may not be able to do this with the offending part of the stump in the ground. Using a wedge, drive it into the stump near but not next to the bit so you don't damage the bit. Don't drive the wedge flush into the stump or you may get the bit out and then have the wedge stuck. Worst case, carefully use a chainsaw to cut out the stump so you can split the wood around the bit.
Feb 01, 2012 | American Tool 6 each: Irwin Metal Drilling...
How do you release the drill bit on a Wacker drill/hammer?
if there is a large spring around the top of bit area,Just pull the spring to the side and bit will slide out.I could be more detailed with brand, make,model or anything else to go on.
May 14, 2009 | Drills
Matika hammer drill - bit stuck
The spade bit sold with the hammer drill was actually too large for the hammer drill. We found that the spade bit had over heated (not from overuse or heavy use as only two ladies were using the hammer drill) but because the bit was too large it put too much weight on the drill. The bit had to be removed from the chuck using a hammer and force causing a bearing to come out and the chuck now needs repair. Solution repair the chuck on the hammer drill and buy a lighter spade bit. Then continue jackhammering the cement out of the shower cubicle.
Mar 25, 2009 | Makita Drills
Drill doctor won't sharpen bit
sounds like the angles have been cut wrong on the bits or you are drilling too fast
Jan 02, 2009 | Dynamic Drill Doctor Large Chuck, Black,...
Makita 6222D hole drill bit is stuck
When this happened to me I held the shaft of the drill bit tightly with my hand and reversed the direction of drive for an instant. It released at that point. It still does that occassionally though.
Jan 27, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Drills Logo
119 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
