Question about LG KS360 QWERTY Keyboard Phone BRAND FREE10 TOP UP
Keys don't work have to press them multiple times my "y" and "u" keys are the worst
How do I put an upper case into the key pad for my wifi password has a capital letter in it.
Try pressing the letter multiple times to get UPPERCASE.
Example: Press "a" once for "a". Press "a" multiple times for "A"
Jun 08, 2016 | HP OfficeJet Office Equipment & Supplies
Tip
Nokia N97- AMAZING FACTS!!!
d019b14.gif DID U KNOW???
…that by pressing any key on the top row of the keyboard (with the exception of Backspace) from the homescreen will bring up the Dialer?
…that by pressing the Shift key twice, this will allow you to type in CAPS LOCK but you can’t do this at the beginning of a sentence?
…that by pressing the Function key twice, this will allow you to type in SYM LOCK.
…that by holding the Sym key and pressing any vowel key or the ‘C’ or ‘N’ key, you will get accents above or below the letter? Pressing the letter key multiple times while holding the Sym key will cycle through the different accents (only vowels have multiple accents however).
…that the scroll key in the middle of the D-Pad functions like an OK/Options button?
on May 27, 2010 | Cell Phones
Where would the reset button be inside a laptop.
Disconnect the power, remove the battery then press and hold the power button for 15 seconds. Reassemble.
  1. Make sure the computer is turned off ("Shut-down" from the Windows Start menu)
  2. Remove any peripherals such an external mouse, keyboard, monitor, USB flash drive etc.
  3. Make sure the AC Adapter is plugged in and working.
  4. On machines with the F key numbers on the top edge of the keys and in White:
    • Press and hold the 0 (zero) key and power up the laptop.
    • Release the 0 (zero) key when the recovery warning screen appears.
    On machines with the F key numbers on the bottom edge of the keys and in Gray:
    • Power up the laptop.
    • When the initial TOSHIBA screen displays, press the F12 key to enter the boot menu.
    • Use the arrow keys to select the HDD Recovery option and press the enter key to begin.
  5. The TOSHIBA recovery wizard warning screen appears stating that when the recovery is executed all data will be deleted and the original factory software image will be rewritten. If the recovery process offers a choice of Operating Systems, select the appropriate one for you.
  6. After you are sure you have everything you want from the laptop saved, click Yes.
  7. When the Toshiba Recovery Wizard opens, the default and recommended option is "Recovery of Factory Default Software".
  8. After selecting your desired recovery method, select Next.
  9. On the next screen you may have recovery method options. The default and recommended method is to Recover to Out of Box state.
  10. Select next to continue.
  11. Follow the on screen instructions as you navigate through the system recovery steps.
  12. The laptop will restart multiple times and install the needed components.
Dec 11, 2014 | Computers & Internet
Unfortunately my mobile language is change to Hindi . i don't know Hindi .how can i change to English.i don't have user guide
First Open Menu(Center key)>>press Down1 time (Scroll key down) >>Press Left 1 time (Scroll key left)>>Select (center key)>>Press Down Key 10 times>>Select(Center key)>>Select(center key)>>Select (Center key)>> Press UP 1(scroll key up) and press center key.Try this ,I think this will helpful to you.Good luck Thanks for visiting fixya
Sep 21, 2011 | Nokia 2730 Cell Phone
Ti89 responds to resets but nothing else
If the calculator is several years old it may be showing its age.
There is a connection point between the keyboard and the display
that over time loses its efficiency. Try this: press a number key
and at the same time apply pressure with your thumb or index
finger to the region of the calculator just below the display.
If you press hard, the number may just show up in the display.
This is a test for the tightness (or electrical efficiency) of the
keyboard-to-display connections.
Another way to make this test is to twist the calculator while
you depress a number key.
Sometimes the effect is such that the keys on one side or the
other work, or don't work, and the keys in the middle don't work
or work okay. By twisting (don't break it!) the calculator body
while you press the keys will show the weakness of the
connector between the display and the keyboard.
This can be repaired by a good electronic technician if you
explain to him what I just told you.
Aug 29, 2011 | Texas Instruments TI-89 Calculator
I pressed some keys on the computer and now when I use the computer keyboard when I type o I get the number 6 and when I time i Iget the number 5. what did I do I am using a different keyboard as I type...
Hi Carol,
It seems that the function key (Fn) on the bottom left of the keyboard is stuck or jam. Try hitting the key multiple times or raise it with your fingers. Then try to press I and O again. Below the is image of the key you need to press and clear the jam from. You can also pat the keyboard/ laptop from at the bottom in case the jam wont clear by pressing the key.
Fig 1 : The function key
Fig 2 : The the shown below have multiple icon, those are activated by pressing Fn (function key)
Regards,
Shrey
Jun 04, 2011 | Acer NSK8458AN Keyboard
Avital 473L bought for a 99 Nissan maximal. How to program? Instructions say to press valet button? Don't have one that I know of. The Nissan instructions, put key in and out 6 times, hazards flash,...
Some of those cars did not have that option on them. You must frist open the drivers door. then press the lock button on the main switch oin the door. Then close the door and slowly insert the key 6 times within 10 seconds but do not go to fast and when the flashers blink then turn the key to the ACC potion and press one of the buttons on the remote.
May 28, 2011 | 1999 Nissan Maxima
What do I have to do to use the multiplication symbol that is situated on the += button?
If the multiplication symbol is a slightly different colour to the +/= symbol, try pressing and holding Fn key then press the +/= key. If that doesn't work then try pressing Alt Gr key then multiplication symbol. One of these combinations should work.
Oct 27, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
LG KS360 QWERTY Keyboard Phone BRAND FREE10 TOP UP Logo
37 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
