Question about Sharp LC-32SB24U 32 in. LCD TV
The volume control does not work by remote control anymore. I have two remotes that used to work and now I can only control the volume directly on the tv.
  • 405 Answers
Have you tryed unpluging the TV and pluging it back after 30 seconds?
Posted on Nov 15, 2009
4 Suggested Answers
SOURCE: Remote Control Code for Element LCD TV -- & Direct TV
try these codes i got from my local cable company
1144, 1240, 1331
Posted on Oct 04, 2008
dsacco86
  • 1077 Answers
SOURCE: Direct TV remote does not control TV on/off or volume.
I have the same setup like you. Direct TV and Emerson LCD TV. The Direct TV remote stores a limited amount of codes and none worked on my TV. Sadly it's not something you can update. They seem to only stick with the popular codes. Welcome to the "head of the curve" like me. lol
Posted on Jan 12, 2009
hi! i have here a couple of codes for your tv, just try them, 1468, 1004, 1011, 1013, 1025, 1028, 1031, 1033, 1036, 1044, 1045, 1080, 1097, 1101, 1102, 1107, 1382, 1383, 1483, 1484, 1512, hope this helps!!!! goodluck!!!!
Posted on Jun 06, 2010
Loewe tv power
Hi, the original remote that comes with your tv is the correct remote for you. because you have it connected to the sonos-playbar you will now need to use the Sonos remote to control the volume. The Loewe remote will not work for the volume anymore. Sorry.
Oct 18, 2013 | Logitech Televison & Video
Had my samsung dlp tv repaired today. tvs fine now but the remote does not work(still works on dvd player) direct tv remote does power on tv either or control volume anymore
It sounds that the remote control should be programmed once again with TV with its setup codes. Setup codes for Samsung TV are:
0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Check these codes, and select one which have maximum functionality with your TV.
Jun 28, 2012 | Samsung TV Remote Control
Sony model KDL-32L5000 does not respond to the commands of its remote control model RM-YD028. We have been using a Direct TV remote as well to control volume but its not reacting this remote either...
If the only thing not reacting is the audio, then the audio board or the main board has gone bad. Enter the model number and tv make on you tube to get more detailed info.
Dec 15, 2017 | Sony KDL32L5000 32 in. LCD HDTV
Remote stopped working so I cant use the tv what can I do I was trying to set the firect tv remote and could not get it to work. After I tried that the remote to the tv would not work anymore. I tried...
your best bet is going to be contacting rca and having them send you out a new remote alot of the universals have a 50/50 chance of having the needed frequency so I try to say away from them
hope this helped
Robb
Apr 22, 2010 | RCA RCU600M Remote Control
Volume controls on the unit and the remote don't work ... the batteries on the remote are new ... the remote will turn the system on and off but will not operate the volume controls
Hello
Ok, sometimes some of the circuits on the circuit board of the remote itself malfunctions, thus some of the buttons will not work anymore.
I will suggest that you buy yourself a universal remote, it will be much cheaper than buying the origional remote that came with the unit directly from the manufacturer.
Just click on the link below and you will be directed to site where you can read some reviews and check out the prices on the corrosponding remotes.
http://www.remotecentral.com/
Hope this can steer you in the right direction.
Kind regards
Andrea
Dec 21, 2009 | Audio Players & Recorders
Jan 04, 2009 | Televison & Video
Volume controls dont work when using remote
I would start by trying other codes on the universal remote. Sometimes codes will only work part of the remote such as the numbers or channels but not volume. Your motorola cable remote sounds like it may only need a good cleaning. sometimes when you take remotes apart it will look like somthing got spilt in it. I would start there first.
Mar 17, 2008 | Sanyo DS27910 27" TV
Direct tv remote control - tv volume
PaulTulsa is actually incorrect, Directv remotes do allow this function. I had this problem too... but was able to fix it. You have to go back into the system settings menu. Depending on your receiver (I have the hr21-100) press "Menu" then scroll to "Parental, Fav's & Setup" then "Sytem Setup" then "Remote" then select "Program Remote". Scroll to "TV" then select the brand name (I also have a Samsun tv). Follow the directions to change the code of the remote and manually go through the codes they have posted. The second one worked for me. Good luck.
Feb 17, 2008 | Universal Remote Control DIRECTV Universal...
Volume not responding on Direct TV remote
http://www.directv.com/learn/pdf/System_Manuals/RCA/RCA_DRD221RD.pdf
See Page 15.
Worked like a charm! Good luck!
Jan 31, 2008 | RCA DIRECTV Satellite Remote Control
Remote control not working
if you still have a problem (and the tv!) email me at gmail.com
May 01, 2007 | Protron PLTV-32 Television
Sharp LC-32SB24U 32 in. LCD TV Logo
606 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
