Question about Cell Phones
My lg env vx9900 will not turn on and it will not charge. i've tried to dry it out but it wont work.i've taken the battery cover off and the battery out to see if water or sand got in any small cracks
LG enV VX9900 turns on but stays on the startup screen?
It sounds like your firmware is messed up. Have you taken the battery out for a while then put it back in? You might have to take it in to verizon and have them reset your firmware. Also if you put a memory card in it can stop it from booting too. Try taking it out starting the phone then putting the memory card back in while the phone is on.
Jan 07, 2011 | LG enV VX9900 Cellular Phone
EnV touch phone won't turn on. Charged overnight, went to unplug phone and it would not turn on. Screen stayed on charging screen What to do?
Unplug the battery. Leave it for half an hour. Put the battery back in and then try to on it. If it still won't on, try to change the battery to a new one. If it still doesn't work, that means your phone power chip has been damaged.
Apr 29, 2010 | LG enV VX9900 Cellular Phone
LG enV touch keeps shutting off when charging
I would replace the battery and see if that helps with this problem
Mar 30, 2017 | LG enV VX9900 Cellular Phone
My lg vx9900 shuts down at random times. when i turn it back on it says "use genuine batter" then does a count down from 10 and shuts back off
Take the battery out and wiped it off with a clean, dry cloth and try again.If is still doesnt work buy a new battery
Jan 10, 2010 | LG enV VX9900 Cellular Phone
Phone stuck on verizon screen
turn the phone off and take the battery out and immediately put the battery back in the phone that usually works on mine
Jul 23, 2009 | LG enV VX9900 Cellular Phone
MY ENV WONT CHARGE - even with pushing down
does it work when you plug it in on charge and then turn it on? if not its a battery replacement!
Feb 28, 2009 | LG enV VX9900 Cellular Phone
Same with me
http://www.fixya.com/support/r3771170-phone_water_damage
Oct 24, 2008 | LG enV VX9900 Cellular Phone
LG ENV VX9900 crashes
Hello there.
If the phone is not turning on thats a bad sign.
Before taking the handset back to where you purchased it, try holding the power button in to soft-reset it. From the sound of your description the phone may need replaced.
Hope this helps.
May 05, 2008 | LG enV VX9900 Cellular Phone
EnV vx9900 will not charge
I had this problem. I went to verizon and got a new battery. Hope this helps
Oct 30, 2007 | LG enV VX9900 Cellular Phone
Cell Phones Logo
96 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
