Question about Danby DCR412 Compact Refrigerator
I have a ge fridge it got a icemaker on it it works good but the flap wont let the ice fall down in the glass
  • 22 Answers
Ice sticks together, what pushes the ice out? gravity ,
hyperlink for the danby dcr412
http://www.ajmadison.com/ajmadison/itemdocs/dcr412productmanual.pdf
Posted on Nov 15, 2009
My Whirlpool refrigerator, model GT22DMXGW00, leaks. Water is accumulating in the bottom-underneath the right hand side crisper. It then drains out onto the kitchen floor. Some is freezing too. It is...
check the ice door flap where ice drops into a glass.sometimes the flap doesn't close completely and allows heat to enter threw the flap.this causes frost to build and melt thus you have water you can't explain. hope this helps.
Dec 11, 2014 | Whirlpool Refrigerators
Ice maker subzero 690 stuck won't make ice because i think the plastic flap that rises when the ice bucket fills is stuck and won't come down to turn on the water
There is a screw sticking out from the right side of the freezer wall that has a grey plastic spacer around it that acts as a stopper for the ice level arm. I have seen the ice level arm get stuck on top of this stopper before somehow. you just have to carefully bend the level arm around it and move it below the grey plastic stopper. If it is not stuck above that but the arm still will not come down, then the only other solution is likely a new icemaker, as the arm is geared internally to the icemaker to rise and fall as the ice is made.
Sep 26, 2014 | Sub-Zero 690 Side by Side Refrigerator
I have a GE Profile fridge PSS25MGNAWW with an ice maker that is not working properly. The ice maker doesnt fill with water. If I turn the ice maker off then back on it will squirt water in for about...
HI this is just a test the icemaker runs when you first turn it on, its not suppose to fill up the tray, it will fill it when the icemaker reaches the correct temperature, if its not cold enough in the freezer it wont kick on, if its been sitting for several hours and still wont fill or make ice, you need a new icemaker. The new icemaker part # is WR30X10093
Sean
Mar 30, 2011 | GE Freezers
Ice maker flap don't shut all the time
The flap may be getting stuck on the ice guide which is mounted on the arm you push in th dispense the ice . ( pt # 2180224 ) . Try pushing the arm in and look to see if the flap is catching on the clear plastic piece .
Aug 24, 2009 | Whirlpool Freezers
Flap on refrigerator door will not close
You will need to replace the solenoid kit for door.Call us 704-819-6557 same day shipping
Mar 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer side has icing problem
check to see if the flap for the ice maker is open and or in need of cleaning, also look at the gaskets on the unit. Put vaseline on them if they feel brittle and it wilkl rejuvinate them.
Feb 01, 2009 | GE GSS25JFM Side by Side Refrigerator
Icemaker works fine, only dispenses water
make sure that the ice shoot is not clogged up with ice or the in the ice basket where the ice goes through. Sometimes the ice can be stuck together and jam and nothing will come out.
Nov 25, 2008 | GE GSS25JEMWW Side by Side
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Ge refrige freezer ,water to ice maker.
HI.YOU NEED TO CHECK THAT THE WATER VALVE IS WORKING OK THERE ARE TWO SEPARATE VALVES FOR THE FRIDGE
GOOD LUCK MOHAMED
PLEASE RATE THIS
Oct 19, 2008 | GE Monogram ZDI15C Automatic Icemaker
Icemaker flap/door does not mechanically open
The description says you have an LG fridge?  I may need the entire model # from the sticker inside the fridge to tell for sure, but there is a motor behind the dispenser controls that opens the door.  Let me know if you need more help.  Also, you can view parts and diagrams at http://www.appliancepartspros.com/.
Oct 21, 2007 | LG LFX25960ST Stainless Steel French Door...
Danby DCR412 Compact Refrigerator Logo
67 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
