Whenever the washer gets into a spin cycle, it is extremely loud shaking the whole house. I was informed that there are some screws that hold the basket, which should have been removed but were not removed during the product installation. I couldn't find any info about those screws in the installation manual. How can I make the washer quite during the spin cycle? Please help.
  • 1 more comment
  • obahat Nov 15, 2009
    Where should I be looking for the ties and/or the screws? Are those inside the washer (do I have to break anything apart to get to it)? Or just in the back of the washer? Can you please post step-by-step for dummies? (I'm not technical)
    It is ~5 months old and has been used twice, so it's brand new.
    Thank you for your comment. I'll have my technician come in on Monday and give it a shot, and then reply here.
    Thank you again.
    It has always done it. That's why it has been used only a couple of times (couldn't really use it because it was too loud and only now got around to fixing it). The washer is in a closet and has a dryer on top of it, so it'll have to wait for the technician. I don't have access to the back. I'll keep you posted in 2 days or so.
    Thank you very much again.
  • 10,515 Answers
Here are the two things that may be causing this washer to shake or move!
If one spring is bad it will do this action.
Then change all the springs together.
Suspension Springs
If one or more of the suspension springs are weak or broken, the tub will move excessively and the machine will be off balance and shake .
Suspension pads
Check to make sure the suspension pads or suspension arms are properly in place. Replace as necessary.
Let me know how it goes!!
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 15, 2009
  • 6,826 Answers
Most of the time they are plastic ties,look on the back of the unit,and see if you see any,just break them,if there are screws they will be ovious,just remove them.
  • 1 more comment
  • Ronny Bennett Sr.
    Ronny Bennett Sr. Nov 15, 2009
    Different makes and models,and years,but they should ber in the back,if not turn the machine over on the front,and look under it.
  • Ronny Bennett Sr.
    If it is 5 months old and used twice,did it do this before?It is not to hard take your time and look,they should stick out the back,it will be a plastic tab,just pull on them real hard and they will break loose.
  • Ronny Bennett Sr.
    The tabs are white,or blue or orange,so you can see them.
Loud shaking in the spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Jan 19, 2011 | Kenmore HE2 Plus Front Load Washer
When in the spin cycle it now makes a horrendous noise
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | GE WPXH214A Front Load Washer
GE Front Load washer shakes whenever any type of load is put in. GE service has been out at least 4 times and say that its fine..perfectly level, etc
All front loaders shake to some extent. It depends on the balance of the load. It is especially evident in the spin cycle due to the high speeds. Also these machines are best placed on a solid cement floor. They can shake an entire house if on the first or second floor and the floors are not well reinforced.
Feb 25, 2010 | GE WSXH208A Front Load Washer
Model WFW83005W05, Serial HLY1329780. It shakes the whole room when spinning, even when we put it on the lowest spin.
There are springs that hold the tub in a balanced position. If they're loose the spin cycle will shake the washer too much. The springs can be tightened with a wrench and stop this from happening.
Jan 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
It shakes so violently, it knocked 2 holes in the wall. During the spin cycle, it also turned completely around backwards!! It's so loud it practically shakes the whole house.
take bottom panel off,check the shocks,if it is making loud noise it's probably spider gear,if you keep using it the boot could rip off and you'll have a flood,get rid of washer it will cost as much to fix washer that you could buy a new one but that's up to you to decide
Nov 06, 2009 | Frigidaire FTF2140F Front Load Washer
There's an extremely loud noise during the spin cycle. Sounds like a rock or screw rattling around in side the machine.
WELL ITS VERY SIMPLE TO FIX ALL YOU HAVE TO DO IS TAKE YOUR LEFT LEG AND XTEND TO GROUND FOLLOWED BY YOU RIGHT NOW GO AHEAD AND HOP DOWN....NOW PLEASE TRY TO REMEMBER THAT SPIN CYCLE IS FOR CLOTHS ONLY...YOU HOUSE WIFES ARE SOOO FUNNY
Nov 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
LOUD BANGING AND SCRATCHING NOISE ON SPIN CYCLE
Urgent stop using it !!!!
The drum suspension is coming to bits , get someone in to look at it before the drum comes through the side of the machine
Jun 16, 2009 | Frigidaire GLTF1670A Front Load Washer
Spin cycle shakes the whole house everytime why
check first if any of the legs are not sitting flat on ground,check the roughness of bearings by placing your hand in the drum and rotate slowly back and forth,loose balance weight could also be a cause but id say it sounds like bearings
May 07, 2009 | Washing Machines
New front load washer shakes my whole house
remove the shipping material...read install instructions that came with owners maneul
Dec 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
