Question about Cosco Alpha Omega Elite 5-Point 22-155
REMOVING COVER COSCO ALPHA OMEGA ELITE
I NEED TO TAKE THE FABRIC OFF THE CAR SEAT TO WASH IT AND AM AFRAID TO PRY IT OFF AT THE PLACE THE BUCKLE GOES THROUGH IN THE SEAT. HOW IS IT ATTACHED.
  • Anonymous Feb 27, 2008
    I have the same problem to remove the cover to wash yet am having difficulty figuring out how to remove the seats buckle and headrest.. I am afraid to yank out the buckle holder and cannot find any screw or lock anywhere to remove them.. desperately need help as I need to wash it for my 2nd child to use.
  • b_ball_sarah May 03, 2009
    My son had a blowout in his car seat and i can not get the material off to wash it. I can not figure out how to get the 5 point harness off.
The straps need to be removed from the metal clip in back, and then the plastic grommets must be pried loose from under the fabric with side pressure and an upward push. Its not easy. Bad design. There are no screws involved, but a standard screwdriver can help with the release. The oblong grommets have ridges that must be compressed to release.
Posted on May 04, 2009
Remove the base by pushing the metal rod on the bottom through the side that is open. This will allow you to remove the straps that hold the covering in place.
Posted on Feb 12, 2010
My base and seat do not come apart. Here was the easiest way I found to remove the cover: * Gather a ziplock bag, a flat head screwdriver, and a Philips head screwdriver. * Curse the manufacturer for making such a stupid design. Go ahead, you will feel better. * Flip seat over so that you're looking at the underneath & back sides. * Unhook all the elastic straps. * Loosen the shoulder straps and locate the metal clip they are hooked on. Unhook them. * Locate the plastic clips that secure the cover at each potential strap location. Use flat head screwdriver to wedge one side of the clip inward. At the same time pop the plastic clip downward with either your finger or a twist of the screwdriver. Repeat until all clips are removed (a total of 8). * Immediately place these clips in the ziplock bag. * Use Philips head screwdriver to unscrew the two screws with washers that hold the headrest on and remove the headrest. Trust me, it's just easier this way. Immediately place those screws/washers in the ziplock bag. You can choose to remove the fabric from the headrest also, but I didn't bother to since there wasn't any ick on that in my case. * Return carseat to upright position. Pull shoulder straps out from the backrest. Slide the armrest covers off. Begin from the seat bottom and peel fabric cover up. Thread the harness pieces through the lap level holes. I manhandled the **** buckle through with a bit of force because I didn't want to unscrew it. I pretended it was the person who designed this seat cover and found it quite easy to be forceful. * Now the backrest should slide off easily with all plastic clips and the headrest removed. *Congratulations, you have successfully removed the cover! Now place your screwdrivers in the ziplock back and close it. Keep the bag with the car seat until it is time for reassembly. You're on your own with that. Good luck!
Posted on Apr 27, 2010
Do NOT unscrew the buckle. You don't need to. If you remove the base from the seat you will be able to access a medal clip that holds the buck in place. Once you find that you can just twist it and slide it up through the hole.
Posted on Dec 14, 2009
    Master:
  • 619 Answers
Unscrew the bolt of buckle and housing of the belt are below nbot attached to the carset.
Posted on Jan 10, 2008
Wash car seat fabric
Hi Tova
Please contact the USA customer care team for assistance
2525 State Street
Columbus IN 47201
1-800-951-4113 (Toll Free)
812-372-0141 (Main Line)
www.djgusa.com (Website)
Sep 15, 2013 | Cosco Alpha Omega Elite 5-Point 22-155
How do I convert the car seat into a booster seat?
Turn the car seat over and remove the pin that holds the base in place. Then remove the belts and the buckle. voila, a booster seat.
Sep 03, 2010 | Cosco Alpha Omega Elite 5-Point 22-155
Cosco Alpha Omega 22-150
Get a new seat!  They have a recall!  Save your kid's fingers! If you still want it... Call 877-639-0659 to order parts and repair kit for finger hole problem!
James Mac
Sep 09, 2008 | Cosco Alpha Omega 22-180 - with Shield
Cosco Alpha Omega Elite car seat
Manual is available at the manufacturer's website
http://www.coscojuvenile.com/instructions/
Mar 19, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
I have the cosco alpha omega elite 22-155 and i need a new cover
Dorel Juvenile Group manufactures these car seats for under the Cosco brand. You should check out their web site.
  • Check out the recall notices and make sure your seat is not listed.
  • Register your car seat so that you are informed of any future recalls.
We have taken our car booster seat apart and ran the cover through the laundry. We used the delicate cycle and COLD water. We also soaked it overnight. This resulted in a very clean cover. MAKE SURE you take several good quality photos of it so that you can get it back together again. Online manuals do not seem to exist.
Nov 08, 2007 | Cosco Alpha Omega Elite 5-Point 22-155
Removing seat cover
There does not seem to be any Manuals on their website, but they do list a phone number. 1-800-544-1108
When I took mine apart I did the following.
  • Take many pictures of it first so you can see how it goes back together.
  • Put all of the parts in a container so you don't lose any.
  • Start by removing the screws on the headrests. There are four of them.
  • Using a flat screwdriver on the left side and a pair of pliers on the right (as you are facing it) pull the metal rod from the hinge to the right. Make sure you don't damage the springs.
  • The screwdriver can be used to gently pry the square metal strap anchor from the plastic holder. It is tight!
  • Then fish the anchor through the seat and fabric.
  • The shoulder straps have to go from the front through the fabric.
  • There is a front clip that is located between the child's legs. I had to finesse the fabric cover around this.
I think that is all I did. We washed the cover in COLD water on delicate and soaked it overnight to get it clean. Hang dry!
Oct 13, 2007 | Cosco Alpha Omega Elite 5-Point 22-155
Cosco 5-point omega carseat
ok I had such a hard time with this, i looked on the internet for hours and found NOTHING!! haha so i went to babies r us and checked out a similar one so here it is.
first the strap goes on the bottom, pull them even and the add the buckle, plastic buckle thing, and the other thing soft thing. then put the strap through the back of the seat (you should have two ends) not the must go OVER the adjusts! now take the metal piece that adjust the length and pull it long enough for it to reach the two straps and hook them up!! haha if this isnt good enough go to a store that carries the alpha omega elite car seats and check it out! GOOD LUCK!!
May 10, 2007 | Cosco Alpha Omega Elite 5-Point 22-155
Cosco Alpha Omega Elite 5-Point 22-155 Logo
5,976 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
