Blue spots and areas are appearing on my sony KDF-E42A10 Grand Wega rear projecyion LCD TV...Why?
  • wildtunabill Nov 15, 2009
    it is dedfinitely more than a cleaning problem
    President:
  • 1,462 Answers
The blue spots on your sony TV is a optical block issue, it's just that usually you can see these spots on a dark screen or for a few seconds when you turn the power off, since the bulb stays on.
If there is a spot or other issue that is absolutely stationary and is there regardloess of input or screen format, it has to be the optical block. It's possible that Sony may cover this under warranty, so I would advice you contacting a Sony authorized service provider and see what they say.
If it's not going to be covered, this will be an expensive repair to have a new Sony optical block installed. But there are rebuilt optical blocks available, and that is worth looking into.
If you'd like more info on this, take a look at All About Sony's Optical Block Issues from the following link
http://sites.google.com/site/sonylcdrptvproblems/sonyrearprojectionlcdtv-opticalblock
Please leave me comment, if you need further assistance
Thanks for using FixYa!
Please rate this solution
Rnj VINODKUMAR
Posted on Nov 15, 2009
  • 350 Answers
First thing to do is see if the problem is coming from inside the tv set ,if the tv set gets too dusty inside the compartment these can happen where you start seeing blue spots green lines etc... going along the screen. Moreover on the link below you should have step by step on how to clean the inside of your tv set ,be very carefull when doing this the tv set does carry high voltage,unplug the tv set before you start. If after cleaning, the Problem still persist then you might want to change out your lamp (optical block) which is going bad or already bad.
CLICK HERE
One more site to check out seems to be very helpful fix for a lot of problems with projection TVs. Read the whole thing, it is informative and has helped many people who thought they would have to buy a new TV.
CLICK HERE
I hope this helps and good luck!
  • CURT
    CURT Nov 15, 2009
    You asked why correct? I gave you multiple options. The easiest to correct 1. Dirty inside with proof from others in the link that it helped them. 2. you have a problem with the optical block or will have soon and 3. a link to a site where literally thousands of people have with similar problems or worse corrected their TV problems by adjustments with detailed pics to assist. These are the most cost effective things to try for self help. If you want a more expensive fix without attempting to even try any other solution, buy a replacement and follow the diagram. Good luck!!!
What causes a large blue area on sony grand wega lcd projection hd tv
the optical block (light engine) needs replacement Very common issue with the KDF sony models
Apr 01, 2012 | Sony Grand WEGA KDF-55XS955 55" Rear...
For KDF-E42A10 When picture is black, a bluish fadded spot appears in the center of screen. When picture is white, a yellowish fadded spot appears in the center. Do I just replace the bulb?
no this is a problem with your Optical block your LCD chips have gone bad you need to replace this part to fix this issue the bulb will not solve this kind of issue
Oct 15, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue blothes on LCD screen
Blue blotches spreading over the screen are failure of the optical block
contact Sony to see if you are eligable for a free repair.
Sony will cover the cost of the optical block repair (parts and labor) at no charge through December 31, 2008 for 2004 Model Year Grand WEGA™ Televisions with the blue spot problem.
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
http://esupport.sony.com/US/perl/news-item.pl?news_id=
Read more: Help from Sony for LCD rear projection with blue spots - Home Theater Forum - Home Theater Systems - HomeTheaterShack.com http://www.hometheatershack.com/forums/sony/5351-help-sony-lcd-rear-projection-blue-spots.html#ixzz0gm8a3718
Don't bedeterred by the dating of this announcement, it is a manufacturing fault and they have been pr5etty good to a lot of people with the same problem.
Please rate my help++++Thanks for using FIXYA
Feb 27, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
I have a Sony WEGA backlit LCD 42 with a blue spot.
sony canada is replacing the color block on all of the 2006 2007 model year of the Grand wega
Oct 16, 2009 | Sony (XL-2400) Projector Lamp for...
Dark picture after purchasing a new lamp. didn;t help at all
CHECK FOR COLOR CONVERSION OPTION IN THE MENU,,TRY THAT ,,ALSO TRY NEW CONNECTIONS ,,AND RCA JACKS AND SO ON
May 05, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Crack in the screen 42" sony kdf-e42a10
You can find a new Sony replacement lenticular screen and fresnal screen for a model # KDF-E42A10 from a major Sony distributor at the following links:
Sony KDF-E42A10 Replacement Part Lenticular Screen
Sony KDF-E42A10 Replacement Part Fresnal Screen
Feb 16, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Bad picture
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Sony LCD Rear Projection TV - Optical Block Problems
http://splinke.googlepages.com/sonyrearprojectionlcdtv-opticalblock
Jan 19, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
Top Televison & Video Experts
