Question about LG Heating & Cooling
Need to decommission LG LS-K2463HL split system ie draw down gas before relovating unit.
  • 2 more comments
  • dave_newland Nov 15, 2009
    I have all the gear (work on cars) - I do believe it is possible to draw the gas back into the compressor using the remote control and in some makes you can do it by using the manual switch on the header unit - I just don't know what buttons to press.
    I have the gear gauges etc to monitor process - I believe you can draw the gas back into the compressor utilising the remote control or in the case of some other makes the manual over ride switch. I have an LG LS-K2463HL model and wish to relocate the header unit inside the room
    Apologies.
    Split System Home Aircon - LG LS-K2463HL - wanting to move header unit and believe it is ssible to draw back all the gas to the compressor and isolate while moving. I have all the gauges etc.
    Brigadier General:
  • 3,489 Answers
So far, there is nothing i can find. im assuming that these are overseas units and they are bringing in new models or decommisioning certain sites. the info i have is that the refrigerant is unknown. you need to check all the lines going to the pump(that being the low side) as apposed to the ones coming from the pump(should be smaller) these being the high side. just be careful.
Posted on Nov 15, 2009
  • Kori Policy
    Kori Policy Nov 17, 2009
    not trying to be disrespectful, i have searched and searched and even called some euro friends and they cant find anything. i wish i had better news. if you know anybody who works for kbr they might have some info.
  • 986 Answers
A charging hose or air con. gauges hook hose to low side of unit open vavle bleed off freon but i dont know why you would want to do that first you should hook up gauges to unit to read how much in pounds or onces you have in it your tag on unit will tell you how mucj the compressor will hold NOW law wise it is against the law to realease freon into air the laws are different in eack state you can release a small amount like when removing hoses most units are under charged not over unless some one put in too much if you have to bleed off some freon i it can be done. As far as removing all gas you should call a profesional with the proper recovery system.
  • Roger Campbell
    Roger Campbell Nov 15, 2009
    You never said in your question that you had the gear. Thats why I told you what I did.
How to open front grill on LG split ac Model No:LSA3ER3N
If it lg might have pull down filters in grount of the unit two fingers pull down the middle of the grill botom
Jun 06, 2015 | LG LS-L1210CL Mini Split Air Conditioner
Air-Con Mini split --gives error code 4 shuts down after 25 minutes
Hi Emanuel,
Your out door unit could be very dirty or the outdoor unit temperature sensor is out of position.
May 04, 2014 | LG LS-K1830CL Cool Mini Split Air...
My split system keeps kicking out it runs for a while if i shut down and restart but compressor kicks out after 5 min. it is contrlled with remote
The unit is usually low on freon when this happens...the machine will over ride the freeze stat and the low pressure control for five minutes and then shut down...
Have a tech. check the system for leaks and repair them.
Then recharge the system and you'll be good to go...
heatman101
Jul 05, 2011 | LG LS-L1210CL Mini Split Air Conditioner
System 3 in-door with system 4 out door inverter. all in door unit show error code CH24 pls help
CH 24-Splits and Multi Splits = High or low pressure trip. Low at 1 bar High at 35 bar check pressures. Multi V = High pressure trip.
Nov 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Good day: The unit has a ice buildup on the coils. How do I prevent this from happening? Thank-You
Gas Pressure is low in your system.
Recharge it.
And Give remarks if that works.
Goodluck :)
Sep 12, 2010 | LG LS-K1830CL Cool Mini Split Air...
I have a split system model ls-k2464hl the remote works but will not turn on the unit.The unit will force run but only in cold
It sound like a defective receiver pcb. Have this professionally checked. I take the time to help, so please rate me!
Jun 15, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
Need a manual for a LG split system
You should be able to get a service manual from the manufacturer online and down load it? Or go to where this unit was purchased and they should be able to help you.Get the model, serial, and product numbers from both indoor and outdoor units to take with you. The more info you have the better. The outdoor serial number shows the manufacture date.Have you removed the excess panel on the outdoor unit to see if a manual may be inside? they sometimes put them there instead of handing them to the owner. Good Luck!
Sincerely, shastalaker7
Oct 19, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Lg split system ch 05 error outside fan not working
Solution # 1, Check Condensor Fan Motor Capacitor 4uf or MFD
# 2, Check Motor Windings
# 3, Check Relay OR Defination Contactor
# 4, Check Connection Terminals
hope will help u 2 solve this
GOOD LUCK
Jan 26, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Only fans work on split system model ls-k2463hl earth breaker trips when compresor tries to start
Does the compressor try to start and the shuts off or is the breaker slamming off as soon as it is turned on. If it takes a few seconds the comp could be locked up and trying to start, high amps and tripping breaker. Tripping breaker right now would indicate a shorted or grounded compressor. Really would need to be ohmed out with a meter to check for ground. Not good either way.
Apr 25, 2008 | Heating & Cooling
Heating & Cooling Logo
197 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
