Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
LC-46D43U Lcd display broke on inside. The screen is fine. Have sound no picture, just a bad spot and some lines. How can I fix this?
  • 4 Answers
The problem i have found after changing the Tcon board is the display here is how to check.
1. open television
2.remove cover from Tcon board
3. re-secure Tcon without cover.
4. plug in talevision and check ic at upper right of tcon has two caps above it.
5. when you apply power the tv cpu will check all circuits pin 4 goes to ground and ic should switch on if there is no excessive load at pin 5 to 8. which feeds the display the voltage at that point is 15 volts dc to ground.
if it not present then display bad.
also to further verify unplug two connections to panel the supply should apear at pin 5 to 8.
Posted on Aug 21, 2014
  • 405 Answers
Unfortunately, if LCD panel is broken it can't be fixed. It has to be replaced, which not economical.
Posted on Nov 15, 2009
  • 668 Answers
If the LCD Display is broke, only replacing the LCD Panel will fix it. The Main problem is that the cost of doing this would exceed the cost to replace the whole unit. I am sorry about the bad news.
Skyassoc
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
? 2:01
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Hi there, I have a Sharp Aquos LCD TV model number: LC-37PX5M. Out of the ordinary, i have encountered a problem with it. When i switch it on, the screen comes on for 2 seconds and vanishes off. It...
it sounds like the light tube in the back is going dead. i hate to be the bearer of bad news but thats the most likely problem. kind of common especially if there was a power spike. hope the bad news doesnt effect my rating lol but this is what i found after researching your model
Mar 19, 2011 | Sharp LC-37PX5M 37 in. LCD TV
Sharp Aquos 46D43U no pic no sound
I have the same problem right now and i dont understand the solution. help?
Jul 31, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Thin blue line down middle of screen
The red line driver at that point isn't working or there is a bad connection to the panel for that line. (I assume the intensity and hue of the cyan line varies witht the picture). What type of screen is it? Plasma or LCD? The following is for LCDs and may not apply to plasma panels. (I haven't had to fix those yet.)
Once in a while you can solve the problem on an LCD by gently massaging the connector to the display panel edge at the bad spot, although there is a risk of causing other lines to drop out. I once fixed an LCD that had a hair caught between the elastomeric connector and the display glass, but if that were the culprit in your case, you'd probably be missing more than one line. It could also be a problem with the driver chip for that line.
Be very careful about tearing into the LCD. The connections are very delicate, the fluorescent backlight tubes are glass and have mercury inside, and the potential for electrostatic discharge damage is always a concern. It's easy to cause more problems than you fix when you get into the connections, although those can usually be reversed with patience and steady hands. The worst case is a misalignment that would mess up your color registration (color drive going to the wrong line). Most panels have a sticker inside warning against removing the driver electronics. It's there for a good reason.
If I've scared you off, or if the connector massage doesn't work, there are companies like Moniserv that specialize in repairing LCDs. They have the equipment and dust-free facilities needed to repair bad panel drivers.
Mar 22, 2009 | Polaroid TLA-04011C 40 in. LCD TV
TV screen is blank but I still get sound
its probably the motheboard. i got one for sale cause i broke the screen. or you can sell me yours so i can fix mine. if your interested email me at quoc5539@msn.com
Mar 02, 2009 | Sharp LC-26SH10U 26 in. LCD Television
Lc-46d43u aquos lcd tv
The remote code 31 worked on my Motorola cable box.
The REmote is for a Sharp LC-32GP1U
The code was listed under one of many for Jerold. I entered codes one by one testing the secondary power button each time.
Code 31 works fine.
Oct 28, 2008 | Sharp LC-26D6U 26 in. LCD Television
Flat panel displays half screen, mirrored on bottom half of screen
Have several problems with either a bad LVDS cable from Main unit to the LCD controll bd. Sometimes the cable is just not connected properly. If you reseat this cable and the problem still exists you most likely have a bad LCD control bd.
Jan 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
236 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
