Question about Frigidaire ATF6000ES Front Load Washer
Middle of cycle and won't start, just hums
Our Frigidaire front load washer is in the middle of a load and is stopped and full of water. When we push the start button it just has a low hum. (softer than the louder buz that occers when the the door is not completely shut.)
  • 77 Answers
You have a drain problem check the hose going to the pump.I bet u find a sock or such in it.
Posted on Nov 15, 2009
My frigidaire LTF6700FSO will not spin
Your symptom sounds like a jammed drain pump. Was it spinning and then stopped before the spin cycle should have ended or did it not begin spinning when it should have?
Jan 17, 2013 | Frigidaire ATF6000ES Front Load Washer
When tub drains beeps twice and won't continue
Hi - Does the drain pump make a humming noise as well? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if what pump out. Supposing that it does not, I would suggest contacting a professional to diagnose either the pump or timer.
Oct 23, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front loading washer stopped at rinse cycle. 3 beeps
When in doubt check the easiest thing to check. The pump can cause a number of errors to come up. Since the unit stopped in rinse I would start but checking to make sure there is nothing obstructing the pump before going to the expensive parts.
Feb 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
My front loader has stopped in the middle of the cycle.
you need to clean your pump something is stuck not allowing the pump to drain
Dec 25, 2008 | Washing Machines
Frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Estate washer stopped after filling with water
will any of the lights come on when you try to turn on a cycle?
Nov 21, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
115 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
