Question about Kenwood VR-505 Receiver
No sound from Receiver
Receiver does not work in TV mode, only for DVD movies.
  • jill49120 Feb 21, 2008
    Hi, My friend just bought a new Sony DVD/Video. It doesn't have a tuner connection. The manual said to use the old VCR and plug the Cable wire into it. She has the Denon AVR-1200. The speakers work on her CD player, but won't work on the tv or DVD/Video. Does anyone have any suggestions? Thanks.
  • Anonymous Mar 23, 2014
    Watching movies on DVD player then no sound
    Genius:
  • 1,067 Answers
Well u nee dto plug the tv in it from tv outs rca to the kenwoods video 1 input ok or tv in and make sure tv settings output is on if it has any
Posted on Jan 10, 2008
4 Suggested Answers
6ya staff
SOURCE:
robotek
Graeme Ross
  • 1512 Answers
SOURCE: kenwood 606 receiver
disconnecting the tv from the audio connections on your amp may have created a powersurge in the audio input selector IC. Try powering down the amp at the wall completely for 5 mins and turn it on again. Check to see if operation has returned. If not then it may need an audio selector chip replaced.
This problem can be caused when connecting or disconnecting rca connectors from non earthed equipment like TV and VCRs, By the nature of this type of connector, it will spike the input line by connecting with voltages floating often over 100volts.
to avert this problem occurring, wire all the equipment up and with aerial disconnected and tv / vcr turned off at the wall socket. Turn the equipment power on at the wall last thing.
Posted on Dec 15, 2007
Anonymous
SOURCE: no sound on tv after watching a movie
It was just a loose connection.
Posted on Dec 15, 2008
Anonymous
  • 133 Answers
SOURCE: I have a Sony BlueRay
alot of times , you need to go into the bluray menue under audio, and make sure audio output is set to hdmi, and not componant
Posted on Jan 11, 2009
I installed a HDMI cable and an Optical cable to whatch movies and shows from my LG HD LCD TV, but nothing seems to work. The stereo is also a LG LHB336 system. Which is compatible with the TV. We were...
Hi,Even though you have done some cabling already,for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
TO WATCH DVD ON THE TV:
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or HDMI IN connector of your TV ,
** than just switch to DVD mode on Receiver and play DVD
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
TO LISTEN YOUR TV ON SURROUND SYS.
** AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or "Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input"
or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
** than just switch to respective SOURCE mode on
Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the
Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 24, 2011 | LG 42LC2D 42 in. LCD HDTV
Everything was working fine, then the sound quit working when we play the DVD player. Switch back to TV-DVR mode and sound is fine. Change o DVD and it goes silent. We have to turn up the volume on the...
please try to find new firmware for this model, I guess it is HDMI version compilable problem. maybe after update firmware could fix your problem
Mar 17, 2011 | Yamaha HTR-5560 Receiver
Volume control works in DVD mode but not in TV
Where is your TV sound coming from? Is there a volume control at the source?
May 05, 2010 | Denon AVR-485 Receiver
YAMAHA HTR 5560 KEEPS TURNING OFF
sounds like you have the polairity reversed on the speakers
and yes it does make a difference
check polairity also make sure unit is well ventelated
you wouldnt use your compouter if it was inside a card board box
so make sure the reciever can breath also
recievers get too hot and they start blowing chips off the board
Jul 25, 2009 | Yamaha HTR-5560 Receiver
Unable to get surround in dvd mode but can hear thru tv speakers?
Is your DVD player hooked up to a surround sound receiver, or directly to your television?
Mar 18, 2009 | Mitsubishi M-VR600 Receiver
What to listen to radio, dvd movies and tv in surround sound
we bought a flat screen tv and now surround sound does not work with tv but will work with the radio on surround sound What is w
rong
Dec 17, 2008 | Audio Players & Recorders
Can't get Surround Sound with Movie
hiya
do you get full 5.1 when watching a movie from the dvd player...........??
as when u watch tv the reciever must be set to pro logic to enable 5.1 upmix as its only a stereo feed....
Dec 15, 2008 | Technics SA-DX1050 Receiver
No sound when playing dvd
HDMI may not output sound. Go into the setup screen of the DVD player and go into audio setup. Make sure you have it set for PCM or equivalent DIGITAL setting. If you set that and you still get no surround sound, you will have to use and optical cable between the receiver and the DVD.
Sep 06, 2008 | Audio Players & Recorders
Kenwood VR-505 Receiver Logo
148 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
