Question about Kenmore 20722
Want to take the top off to clean around the drum. Model 110 20722 990 Ser CJ 4103804 Type 111 How does it come off?
  • 1632 Answers
SOURCE: need to open top to clean
Insert blade in to top and body seam to release latch to oppen top. Vitally
Posted on May 12, 2009
localwonder
  • 6784 Answers
SOURCE: model 238322100 ser cm4768086 type 111
Check the following.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Posted on Jun 22, 2009
  • 1937 Answers
SOURCE: Model 110-20052992 Ser CJ-3604836 Type 111does not
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110-20052992+
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 16Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, the kit cost us $15.00 which is a lot less than the $170 for a new transmission.
Posted on Sep 22, 2009
  • 401 Answers
SOURCE: I have a Kenmore washer model 110-24962300
There are plastic parts called "dogs" that need replaced. They are inexpensive and not hard to do.
Posted on Jan 02, 2010
  • 1937 Answers
SOURCE: I need an owners manual for troubleshooting for a
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Based on the 20722 Stock Number, the following might be the Sears diagram site for your washer. Check under the Lid for the exact model number:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20722990&pathTaken=partSearch
Two possibilities:
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
These models don't really have a filter but I'd check the hoses to and from the pump and inside the pump to look for any obstructions in addition to the Motor Coupler (about a $20 part) and the clutch.
Posted on Jul 01, 2010
Some times the washer machine will spin and then
sounds like your clutch is slipping,,,,you can put a #10 washer in one of the clutch spring caps and that stops the slipping! thats a low on cash fix or just replace the clutch ,cost about 40 bucks!
Mar 30, 2010 | Kenmore 22422 Top Load Washer
Model 238322100 ser cm4768086 type 111
2. Water Pump
Jun 22, 2009 | Kenmore Washing Machines
Whirlpool Washer Model:LSN1000KQ0,SER: CM4267948, Type: 111 - Need nylon gear in transmission gearbox.
From the information provided, it sounds like you need WPL 285362 (gear and pinion kit) which you can find at appliancehelp.com for $59.95. You can type in your washer model and see the diagram of each part before ordering so you get exactly what you need.
Apr 16, 2009 | Whirlpool Clothes Washer Timer Knob -...
All funcions of the washer work except the drain at the end
is your drain hose kinked near the back of the washer. try to look behind the washer without moving it. if the hose is not kinked its probably the pump..
Feb 03, 2009 | Kenmore 24032\24036 Top Load Washer
Have kenmore 70 series washer model #20702991 ser #1069231 type 111 will not drain. It starts the cycle by agitating then stops and will not go to drain cycle. switch on top lid does not ckick, tried...
The lid switch must close for the washer to spin. I've seen a lot of these break where it's mounted to the top. You may still be able to reach under the top to grab the switch to close it and get it to drain. You'll almost certainly need to replace the lid switch.
Jul 21, 2008 | Washing Machines
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
