Question about Sony Televison & Video
Sony big screen lost remote and pip will not go off how do i fix this
Magnavox 27MT3305/17 picture dropping down from top of screen
Posted on Nov 15, 2009
No picture on my flat screen sony. got sound. remote works. no picture. can it be fixed?
Sounds like an older tv---to help I need to know the model number (KV or KP?)
Mar 31, 2012 | Televison & Video
I have a sony (model KP61V75) a split screen came on (two pictures) and I cannot figure out how to get it back to one screen. Im going crazy!
Some television remote controls have a PIP OFF button, while others only have a PIP button that needs to be pressed repeatedly until the PIP/Twin-View window disappears.
NOTES:
  • Some Sony rear projection televisions have a FLASH FOCUS button that will turn off the PIP/Twin-View feature.
  • Some Sony universal remote controls, if programmed to operate a Sony TV, can disable the PIP/Twin-View feature by pressing the REC or ENT button.
  • If the original TV remote control is not available or is not functioning properly, auto programming the television tuner orperforming a power reset may deactivate the PIP/Twin-View feature.
  • If pressing the appropriate buttons on the TV remote control does not work, then the PIP/Twin-View window might be from a two-tuner cable or satellite set-top box. If this is the case, use the remote control provided with the set-top box to remove the PIP/Twin-View window.
Jan 25, 2011 | Sony Televison & Video
I want to turn off the pip, the square turned up in the right top corner a different channel then the big screen. I forget how to get it off the screen, sony wega 2003 how do i turn the pip off. i have...
try this..press the set up button infront of the TV control... not the remote control.... and try all the menus.... it worked with my TV... or I just get lucky!!!!. It would be nice to know that I will be able to help someone....
Aug 29, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Don't have original remote control. Somehow, a window for PIP opened, and I can't get it to turn off. Have a new sony remote RM-V310A, but the PIP button won't activate the remote. Any...
Many TV functions can be controlled from the on-screen menus using buttons on the TV itself. These include all kinds of settings however Sony did not include PIP in these menus. Therefore a valid remote is required to operate PIP. One thing you could try is removing the cable from the secondary input on the TV which provides the signal for the other picture. Without an input signal PIP may be disabled. Also, try buying a universal remote and setting the proper code for your TV. Original remote could be hard to find but remotes.com may have one.
Aug 05, 2010 | Sony KV-27S45 27" TV
I have a pip on my screen. Can't remove it
somw sets you need to set up in the set-up menu what signal source is shown in the pip box. to turn it off push the pip button on the remote once
Apr 26, 2010 | Sony KP-53XBR200 53" Rear Projection...
I lost the remote and cannot remove the PIP.
Hi, I have the same TV, remote too. From what I can see you will need the remote to turn off the PIP, but if you unplug the TV and the plug it in again it may reset it to original values. As long as it is plugged it will retain certain low power settings.
If your Comcast remote is a learning remote, you can probably program it to mimic/replace the remote you lost, but you will need the codes from the Sony remote, or borrow one so the codes can be "learned" by the Comcast or some other learning remote. The codes would likely be available online, from Sony.
Worst case - I'll buy for you a cheap learning remote and dump the codes from mine if you want.
Also, you may find a used remote on line.
Mar 09, 2010 | Sony Televison & Video
I have a sony trinitron XBR 32 inch... The pip was turned on by accident, but i don't have the original remote. How do i turn off the PIP? Thanks in advance.
pls. use remot menu key and open main menu use DW key and select system menu see the PIP option is "ON" set option is"OFF" .
See the PIP screen is clear.
Oct 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Lost remote..can get PIP feature back to one image
try to get into the menu and reset to manufacture defaults, if not a universal remte made by sony will work
May 09, 2009 | Sony KP-44PX3 44" Rear Projection...
Picture in Picture
I have the same TV. My remote control has a PIP OFF. If you don't then you have the wrong remote control.
Aug 06, 2008 | Sony KP-53V45 53" Rear Projection...
Pip is stuck and i don't even have a pip button on my remote!
The problem was solved by using the TWC cable remote control and selecting "TV" on the top and the press the big blue "Select" button. DO not forget to put the remote back into "CBL" mode. Apparently this is a hidden feature, which works even on TVs, which officially do not support PIP. I works only with the one tuner, video 2 and video 3 but not video 1.
Dec 05, 2007 | Sony KV-32S26 32" TV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
