Question about Pentair Clean & Clear Filter and Dynamo Pump Package 2 Hp, 2 Speed 6' Hose
Pentair Clean & Clear 200. Filter core gets stuck to filter.
I have a Pentair Clean and Clear 200. Lately, the bottom of the filter core is getting stuck to the bottom of the bottom of the filter and somehow that affects the overall pressure of the pool. The water is not flowing with sufficient pressure. I have done everything from changing gaskets and O rings and cleaning everything. To test the pressure I had the pump running without the filter cartridge inside the filter and the pressure is perfect. I've this pool for 7 years. What could be causing the filter core to get stuck and why is this causing the loss of pressure. I already order the filter core because I noticed some minor wear and cracks. Could this be the cause? When the bottom of the core gets stuck to the bottom of the filter is extremely difficult to remove. This has been happening recently. Typically, when you remove the filter cartridge the entire core should also come out without major force. In my case the bottom of the core remains stuck inside the bottom of the filter. Any suggestions will be greatly appreciated.
Pool plumbing diagram
You may experience a little pressure loss, but if the catridge fliter housing has a 1 1/2 input you should be fine.
Jul 17, 2014 | Pentair Clean and Clear Cartridge Filter...
How do I backwash pentair ccp420 system?
you cant backwash that is a cartridge filter you have to take the big ring off the center drain water out of the filter then remove cartridges soak them in a solution of tsp Tri sodium phosphate (you can buy at hardware store soak of rinse with this solution then rinse with water then use filter cleaner on them then rinse then put back together
Jul 14, 2014 | Pentair Clean Clear Plus Ccp420 Pool...
How do you change the center core for pentair 160317 cc150
If you are talking about the cartridge, You first have to make sure filter is off. turn and open the pressure gauge to release pressure. Now If you can reach the bottom drain plug, unscrew it. If you can't that's okay. Your filter has a center belt - ring, and it has two push tabs. Push up and turn it counterclockwise. Take that off and you should be able to pull out lid. If you have a hard time taking off the lid, get a flat head screw driver and pried it open.. Good luck.
Mar 15, 2014 | Pentair Clean and Clear 150 Sq Ft...
Why wont my pentair ccp320 wont get any pressure
make sure top seal is ok if ok check intake union see if loose or check impeller for debris clean with piece of wire
Jul 05, 2012 | Pentair Clean and Clear 320 sqft Cartridge...
Low pressure in filter after pump 5-10psi
This would indicate a problem on the suction side of the system. Make sure all the baskets are empty and clean. Debris stuck in the impeller will also cause this problem. You may be able to reach the impeller and clear the debris without taking the pump apart. Just make sure the pump is not going to start running while you have your fingers near the impeller.
Sep 03, 2011 | Pentair "Pentair" In Ground Pool Pump ...
Have a pentair ccp320 filter.brand new last year.pool water has been cloudy for two weeks.water is balancedexcept akalinity is high at 200.suspect filter problems.water was clear for a month.cleaned...
Total alkalinity can be lowered by adding muriatic acid or sodium bisulfate. Acid may be added in doses of up to 1 quart per 10,000 gallons. Total alkalinity tests and further required additions of acid can be made every 2 hours.
Jun 28, 2011 | Pentair Clean & Clear Plus Ccp320 Pool...
I tried to clean my Pentair CC-150 pool filter but when I tried to lift the cartridge up and out of the filter shell it wouldn't budge. Any suggestions? Thank's Greg Hamlin
This is a common problem with cartridge pool filters, but it should come out with a little elbow grease. Try gently twisting it back and forth like a steering wheel using firm even pressure.
Aug 16, 2010 | Pentair Clean & Clear Filter and Dynamo...
Why does water constantly flow out of the backwash, even if the filter is on "filter"
You have sand or somthing stuck in you spider gaskit.
Take apart and clean.
OR
Move handle around and hope it will dis-lodge iteam.
Be-careful not to damage spider gaskit 'O' ring.
Jul 11, 2009 | Pentair FILTER TANK BOTTOM, 48 SQFT
Pentair Clean & Clear Filter and Dynamo Pump Package 2 Hp, 2 Speed 6' Hose Logo
112 people viewed this question
Top Pentair Garden Experts
Dennis Key
Dennis Key
john h
Are you a Pentair Garden Expert? Answer questions, earn points and help others
