Question about JBL EON 15-G2 Powered DJ Speaker With EQ Speaker
My jbl eon g2 cuts off and on while playing - JBL EON 15-G2 Powered DJ Speaker With EQ Speaker
  • 11,896 Answers
Your best bet would to test with an ohmmeter the internal components. Expecially the capacitors which commonly burn out and overheat. 25-30 ohms (about 5 volts)
If it is way lower or far higher, Then I recommend discharging the capacitor with the special too, solder it out and replace with the new one(s)
Posted on Nov 15, 2009
My jbl eon 15 g2 smell like burnt and everything works but the big speaker
The voice coil in the big speaker could have been damaged if driven to loud. See if the burnt smell is strongest near the center of the big speaker. If the voice coil is fried, you may be able to still find a replacement as there is a part number for the voice coil (V/C Assy, EON-G2220-27005-00) and the cone (EONG2
Cone Repl. C2REON15P-2)
Jan 18, 2015 | JBL EON 15-G2 Powered DJ Speaker With EQ...
How do you remove the HF driver in the JBL EON 15 G2's??? Cheers Glen
If the cabinet is all taken apart, unplug the white and blue wires and unscrew the driver counter-clockwise to take it out
Feb 28, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Jbl eon g2 not giving any low sounds only tweeter works
open it up and check cables leading to sub (large speaker) they're notorious for falling off - getting banged around
Feb 17, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
How much for speaker
JBL EON 15-G2 Powered Sale Price: $649.95
Jan 04, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
I installed a brand new tweeter in my JBL EON 15 G2 & the new tweeter blew. What else could be the problem?
These are "powered" speakers and any little bit
of distortion can be amplified enough to "blow" it!
Also the amp could be "shorted"! Have your JBL
dealer test it!!!
Apr 20, 2010 | JBL EON 15-G2 Powered DJ Speaker With EQ...
My JBL EON cuts out from time to time (usually when there is a lot of base) and will go back on with a good tap to the side. It has been in for repair and has some solder joints checked and re-soldered. ...
hi there... i have same problem and i believe the main amp (part 339555-001 EON 15 G2) have to be replaced. jbl prosound sell it for $112.80 and you need to do the job yourself, which is not too big deal but not too easy either.
i did not start yet.
please post later if you did it. thanks.good luck. joel.
Dec 01, 2009 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL Eon G2 Speaker
from our experience rebuilding woofers once the lead wires get pulled too much or start to strain you have been running too much power into the woofer and making the cone move too far in and out.You need to cut the input signal from your preamp down and cut the volume down on the speaker input on you eon. We keep seeing too many of these amped speakers blown from too much signal.
Oct 12, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL EON 15 G2 clicks and pops
my son and i fixed an eon a decade ago that had this problem. we swept a sine wave through the audio spectrum and discovered it started barking somewhere around a low D on the piano.
Turns out the mains connection was intermittent right where it enters the eon from the wall. Soldered the ac power connections and the problem went away.
Nov 25, 2006 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL EON 15-G2 Powered DJ Speaker With EQ Speaker Logo
121 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
