Question about Goldstar GR131CN Compact Refrigerator
Gr142bp compact refrigator
The unit worked fine until it was moved to another location,i can hear it run but it doesn't get cold. Any suggestions or trouble shooting?
  • costarica_kd Jun 09, 2008
    my goldstar compact has worked fine for years and maybe it's just tired... I did find the freezer door open when i got home from work the other day and the food was 80% defrosted. Simple solution....Close the door! But now, days later, I am noticing that although the freezer is functioning fine, the refrigerator is not working properly. It's barely keeping things cool....even on the highest 'pull down' setting. Could leaving the freezer door open all day have done something to mess up the refrigerator function?
We have the same problem I found out that the magnetic gasket (door gasket) is not sealing well. Need to check it out use a dollar bill close the door and see if it is holding the bill tight if not replace the gasket. hope this helps. I am also looking for a place to purchase a replacement gasket for our frig. can anyone supply me a parts supply store?
Len jlenv2@yahoo.com
Posted on Oct 23, 2008
    Sergeant:
  • 288 Answers
Although this is unlikely not the problem, check the outlet (plug) make sure its getting good power and not fluctuating. If you are not sure, use an extension cord on a plug that you know is good. All this aside, moving the fridge can cause a problem if you layed it down on its side during transport and plugged it in immediately after turning up right. then you may have burnt out the compressor by not letting the oil drain back into the bottom of it. Basically the equivalent of the oil pan on a car. If it was transported upright and all that jazz, then check the fan in the back by the compressor. Sometimes insulation or other debris will get tangled up in the blades preventing the fan from running. If all this is good, then I will need some more info. to help you any further.
Posted on Jan 09, 2008
Kenmore Freezerless Refrig - temperature is not getting cold. Everything was fine until a couple of days ago and when removing the milk, it was not as cold as usual. Any help would be appreciated.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 05, 2011 | Kenmore 16.7 cu. ft. Freezerless...
I HAVE A SIDE BY SIDE REFRIG. THE FREEZER WORKS FINE, THE OTHER SIDE IS BARELY COOL. WHAT COULD BE WRONG? THANK YOU
the damper vent door from the freezer to the refrige located between the 2 sections has frozen shut and cannot open to let cold air into the refrige from the freezer,its behind a plastic grille near the top of the units divider you should be able to hear a fan in this area too its in there open this up and defrost with a hand held hair dryer if iced over,then make sure fan is operating,then move the temperature control and see if it opens up
Mar 22, 2011 | General Electric Kitchen Ranges
Hi, Have a kenmore bottom freezer refrig. we moved and it powers up, fan works but both the freezer and refrig. part get cold. worked great before we moved it
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 14, 2011 | Refrigerators
I have a profile refrigerator PDS20SCPARSS, SN TF047061. If youopen the door alot ( 4 kids) te refrigerator temp goes all the way to 60deg and the freezer goes to -30. If you don't open the door at all the...
If this is struggling to maintain temperature like this, either the system is low on gas (motor running all the time) or the fan has stopped which you should be able to hear. Make sure that the fan is not just jammed.also check the return air vent in the fridge as if this gets stuck with a spillage ie O.J. etc, the fridge cannot get air from the freezer and the freezer runs continually (-30) but the thermostat never cuts out in the fridge. Last idea most likely.
Dec 10, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
My GE Adora side by side refrig. has stopped making ice and I am having a hard time regulating the settings on it. The freezer is too cold and the refrig. section isn't cold enough. I also have noticed...
Defroster circuit/timer has failed.
The water line to the icemaker has probably frozen,so no ice. The cooling coils are in the freezer, and the cold air moves to the fridge via vents and circulation fan.
When it all ices up, no air gets to fridge, fridge gets warm.
Many models have a mechanical defroster timer located under the lower front kick panel. Manually rotate the timer until you hear the compressor stop.
Defroster heater then should come on and you hear scorch/hiss/gurgle of defrost sounds. If the timer is working, the fridge should come back on after about a half hour or so.
Sometimes timer fails, sometimes heater element fails. There is also a defrost thermostat that's part of the heater assembly.
http://www.appliance411.com/faq/howdefrostworks.shtml
Oct 23, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Warm in freezer and refrig
On some Amana refrigs , the defrost thermostat has to close before the fan will come on . The coils will get cold and since the bimetal clips onto the coils , it will get cold as they do . When cold enough , bimetal closes and the fan will come on . Are the coils getting cold ? If so , then the compressor is working . You could also have a bad fan motor instead of bimetal . Recheck to see if you hear the fan in freezer now .
Aug 15, 2009 | Amana 23.1 cu. ft. Side-by-Side...
Moved refrig. and compressor will not kick in
The unit may have gone into the defrost cycle. The fans and compressor will be off during the defrost cycle. Has the unit been plugged in for more than 30 minutes since you noticed it stopped? If so, you will see a round plastic knob recessed about 8" back in the console on the fresh food ceiling. Rotate this knob clockwise with a flat blade screw driver until a distintive click, louder than the tiny clicks made while rotating the knob. If the fans and compressor come on, replace the timer (68233-3).
If the fans and compressor do not come on after rotating the timer, you may have a bad cold control of loose wire in one of the molex connectors from the move.
Apr 29, 2009 | Refrigerators
Refrigerators Logo
318 people viewed this question
Top Goldstar Refrigerators Experts
Marvin
Marvin
AJMAL KHAN
Tom Chichester
Are you a Goldstar Refrigerator Expert? Answer questions, earn points and help others
