Question about Braun Shavers Male Pulsonic System 9595CC with LCD Screen Electric Shaver
One day the Braun 7 790cc simply did not turn on. Two months old. Anyone else deal with this problem? Thanks Peter
Had this same problem with mine. One month after warranty was done with. I ended up opening the thing up and pulled the monster battery out of its socket and put it back in. Worked fine after that. One week and still strong. Another thing I did was to carefully bend up the flat pieces of copper around the battery to make sure they were still getting a good contact with the pins on the cover. Hope this works for you....
  1. The black rubber/plastic cover on the back will pop off if carefully pried apart from the gray plastic. Start around the middle of the razor body.
  2. Once the black piece is removed you will see four screws holding on a plastic cover. These can be removed with a sharp flat head screwdriver.
  3. The plastic cover can then be pried from the razor body. Be very careful though as there is a rubber seal around this to keep water out. I broke mine.
  4. Inside you will see a somewhat large red battery with prongs on either end. Pop it out of its location and wait a couple of seconds. Press it back into position and you should hear a click for both ends.
  5. After this, I took all of the flat copper pieces and gently bent them towards myself (without making them touch of course... this could cause a short and potentially cause the battery to explode).
  6. Replace everything and see how it works... Hopes this fixed it for you and saved you $100-200. Have a good day!
Also... I am not responsible for any damages that may occur.
Posted on Feb 02, 2010
My Shaver will not charge or turn on
Model 7526 is not a new shaver. It was made about 8 years ago. If no lights illuminate when the power cord is attached, the circuit board is bad. Unfortunately, Braun no longer makes internal parts for this model
If you like this shaver model and want a similar one, you will find one at shaveroutlet.com. This model uses the same shaving head as the 7526
http://shaveroutlet.com/braun-series-1-195s-mens-cordless-shaver.html
Oct 27, 2014 | Braun Syncro 7526 Electric Shaver
Bought a Braun series 3 razor (#340 wet and dry). It hardly shaves the whiskers but it really messes my skin up. ( I was using a Norelco which did a pretty good job) I think there is something wrong...
You should be able to run your finger over the foil mesh on the Braun shaver to feel if there are any rough spots causing the problem you describe. If there is damage you may also be able to see it.
It could also be that the Braun shaver simply does not agree with your skin type. There are many people who are sensitive to different kinds of shaving methods. Foil shavers like Braun may not be the type of shaver for you
Apr 04, 2017 | Braun Syncro 7680 Electric Shaver
My 2 1/2 year old son "washed" my Braun 360 by
I would first suggest that you disassemble it to make sure all water is out. You will find an instructional video for disassembling this shaver at shaveroutlet.com. See link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
Nov 11, 2010 | Braun 360° Complete 8985 Electric Shaver
Making a funny noise and not shaving well
8585 shaver gave higher tone and stopped cutting especially after a few days growth, even with new cutter and foil. Cutter wasn't pressing against the foil properly due to a bit of wear on the spring clip holding the cutter pin. Fixed with about 1cm of cigarette paper moistened and rolled into a 1-2mm ball. Stuffed that into cutter pin hole and rammed home with the cutter pin. Take the foil off and wiggle the cutter - if its feels loose, this might help, though the battery might just be getting old.
Jul 10, 2010 | Braun 8585 Electric Shaver
Braun Series 7 760cc dead after 2 months
Apr 10, 2009 | Braun Shavers Male Pulsonic System 9595CC...
Braun 360 shaver. How to replace the cutter.
You simply have to pull it hard enough to get it out. I had hesitated to do this, fearing it would break.
Jan 04, 2009 | Braun Replacement Foil/Cutter for Select ...
Braun Tassimo 3107 lost instructions
where do i get instructions on how to use the braun tassimo 3107
Dec 29, 2008 | Braun Tassimo Espresso Machine/Coffee...
Saeco Incanto power loss.
You either have two things i think, my first thought is a leak.
The two most usall leaks on a incanto is either from the boiler or the steamvalve.
alitle more long shot is a defective fuse on the bioler.
Jul 22, 2008 | Saeco Incanto Classic Espresso Machine
Braun Shavers Male Pulsonic System 9595CC with LCD Screen Electric Shaver Logo
633 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
