Question about LG WM2487H Front Load Washer
Washing machine will not drain. Check the drain filter and cleaned that. Made sure the Drain hose was not twisted or bent. What do I do???
    Brigadier General:
  • 4,088 Answers
Does the pump run when it is supposed to? If ok, check the drain hose where it is attached to the bottom of the outer drum. If there is water in the drum and you pull the hose loose at the drum, the water should run out of the hose fitting (into a bucket). If nothing or very little comes out, look for something inside the drum blocking the outlet (a stray sock or similar). If there is no removable plate nearby, then the machine must be dismantled to the point that the inner drum can be removed. Major job!
Posted on Nov 15, 2009
  • 11,896 Answers
Check pump to see if it is running or if it is jammed with something. Another good idea would be to test power to pump with a voltmeter.
How to fix drain hose on LG WM2487H M
The following are a number of things to check for the OE (drain error) indication.
If the washer does not drain then the drain pump may be clogged, damaged, or defective.
Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Open the drain pump filter tray at the lower left of the machine and check whether it is clean, check also that the pump impeller spins freely. Remove the hoses from the pump and check for any obstructions.
First, check the drain hose to determine if it is kinked, twisted, or bent. If the drain hose is bent, straighten it out. In addition, remove the drain hose and check it for obstructions. If the drain hose has any obstructions, try to remove them. If necessary, replace the drain hose.
Check the machine's water level frequency by pressing the WASH/RINSE + DELAY WASH buttons simultaneously. Check the reading on the display, if it is below 260 (26 Khz) then have someone measure the resistance of the pump motor coil.
It should be between 10-20 Ohms resistance, if too high or too low, replace the pump assembly as it cannot be repaired.
Mar 08, 2016 | LG Washing Machines
I have a Haier HWD1600 washer dryer combo that I am getting an error 2 on. It will not drain the water out and I have not been able to clear it for the past two months
Its a common error,
Error message:Drain error, water can be not drained fully within the required drain time
Reason 1. Pump filter is blocked.
Solution 1. Please open and clean the pump filter. (Filter access door is on the bottom right, at floor level of the washing machine)
Step 1.Push a flat blade screwdriver into the slot on the filter cover and pull it open ,do not use excessive force.(Fig 1).
Step 2.Remove the rubber hose from its clip and stand a suitable container under it, remove the bung to drain the water (Fig 2-3)
Step 3.Replace the bung and fit it back into its clip (Fig 4-5).
Step 4. Unscrew the filter and rinse it under running water, replace it and close the flap(Fig 6-7-8).
Caution:
1. The filter must be in place during operation, ensure it is in place after cleaning to avoid leakage.
2.Place a container under the drain pump filter, to collect any excess water that may come out of the drain pump when the filter is removed.
Reason 2. Drain hose end is higher than 100cm above the floor level.
Solution 2. Please adjust the height of drain hose to 80-100cm above the floor.
Reason 3. Drain hose is blocked or twisted.
Solution 3. Please check and clean the drain hose for blockage.
Reason 4. Drain hose is too long, or water is back filling from waste water pipes.
Solution 4. Remove any extension to the original drain hose.
Ensure the highest part of the drain hose is nearest the washing machine.Check the waste water pipes in the building are clear of any obstructions and flow freely.
Nov 08, 2015 | Haier Washing Machines
I need to find the reset button. It will not drain. This has happened before but I can't remember where the reset button is.
Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Remove the hoses from the pump and check for any obstructions.First, check the drain hose to determine if it is kinked, twisted, or bent. If the drain hose is bent, straighten it out. In addition, remove the drain hose and check it for obstructions. If the drain hose has any obstructions, try to remove them. If necessary, replace the drain hose.
Jun 24, 2015 | Samsung Washing Machines
What does OE mean
OE indicates a Drain error. This is because the washer is not fully drained within 10 minutes. You have to check whether there is a twist in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge.
Jun 05, 2015 | Washing Machines
F& P bottom dishwasher draw won't drain. Top dish draw draining fine?
Excess water in
the DishDrawer
Drain hose(s) bent or
kinked.
Straighten the drain hose(s).
Blocked filters and/or drain
hose(s).
Clean the filter plate/drain filter. Unblock
the drain hose(s). Refer to the user manual
Aug 28, 2014 | Fisher and Paykel Dishwashers
Hi there, my friends Bosch WAE24162GB washing machine wont drain the water out, im pretty sure its just a blockage but cant for love nor money get the filter out!! is there a trick to it- it turns a...
The error indicates that the machine has taken too long to drain the water. Do the following.
  1. Switch off the machine and disconnect the mains power.
  2. Remove the access panel on the lower right front of the machine.
  3. Remove the filter by twisting anti clockwise and pulling forward and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Oct 20, 2009 | Bosch Washing Machines
I have an OE code on my WM1814CW LG Washer
OE code - Check for clogged drain filter on end of hose, bent or clogged dain hose. Make sure hose doesn't go too far down drain pipe.
Hope this helps
Bob
Jul 06, 2009 | LG WM1814CW Front Load Washer
My washing doesn't smell clean? Help
the drain water pump its not working properly , needs to be cleaned the drain hose needs to be check for posible bent or clogged , ,please be sure that the drain hose ,and drain pipe are installed ,no more than 12 inches above .of the machine, and avoid long hoses. let me know thanks
Jun 20, 2007 | Whirlpool AWM5145/2 Front Load Washer
LG WM2487H Front Load Washer Logo
307 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
