Question about Epson RX595 Photo All-In-One Printer
Well, it turned out that i decided to check if
Well, it turned out that i decided to check if there was a foreign object bockinig the rollers.... and i got a good light and turned it around and right away i see a piece about 1 in. of staples that had fallen in the back from the shelf above it. So just when i was ready to trash the damm thing. thanks to someone in here that had a similar problem. i will keep my epson printer after all. it works fine now.
  • 2,973 Answers
Yes your decision is correct. Epson is in the top bracket of printers if not the top most. Have you been able to remove the staples from wherever they were.
Posted on Nov 15, 2009
My mp250 is taking the paper in sideways and I have looked and the rollers do work. What could be the cause and am I able to fix this problem myself?
oh dear, Never spray lubricant or anything other than air into a printer. I presume when you say "sideways" you mean "skewed".
If so then you have an object in the paper path that will cause this.
Let the machine try to feed the paper then when it jams VERY SLOWLY pull it back out. No look at the leading edge of the paper for a nick in it. The nick is caused by the paper hitting an object. Now lay the paper on top of the paper that is in the feeder. Look at where the nick is. Now refer this to the machine so you are looking into the machine in the position of where the nick is. Shine a torch into the feeder and you should hopefully see the foreign object and try to remove it with an opened paper clip bent into a "L" shape.
Good luck.
Nov 29, 2014 | Canon Pixma Mp250 Printer
How i will find foreign object inside the printer
Hello
To find the foreign object inside your printer go to control panel then click printer and faxes then double click on your printer installed in your computer then click maintenance then click roller guide clean put a half folded paper on your printer then the printer will perform the cleaning you notice that the paper will goes in and out elevate the printer where the paper tray will drop the foreign object inside your printer.
Jul 29, 2011 | Office Equipment & Supplies
Problem with canon ip 2700 .....the printer show error 6000 :s wtf i can doing ? :)
Canon IP2700 6000 Error
Error 6000 tells you that the paper feed roller is not turning, check for any foreign objects in the paper path, a flashlight and small mirror is the best way to look.
yes.. i agree on this statement..
just try this one., its tested by my own experience., first turn off the power of IP2700 printer
then just try to turn the gear of paper feed roller in order to release
the foreign objects..
if error persist, just try to turn the gear again until it works ok.
pls send feedback if its work., salamat., mabuhay pinoy.
Mar 24, 2011 | Canon Pixma iP2700 InkJet Photo Printer
My epson stylus t13 have a problem general error... foriegn objects into my printer... i have opened my printer to see what foreign objects but theres no objects or paper in the rollers side and in the...
Hello there,
This is called a false paper jam. normally, a reset is required for this.
Hold the power button for 30 seconds and this should prompt a shut down.
next, make sure that the rollers are clean inside. use a lint free sloth and some distilled water. Dampen the cloth (Q-tips works fine too, please do not use cotton) and rub the rollers.
Then as it dires up. turn the printer on and do a test page.
Please don't forget to leave a feedback and testimony if it works.
Mar 12, 2011 | Office Equipment & Supplies
It makes noise during the drying cycles
There are 4 possible sources of noise:
1) Drum support assembly - Open the door and turn the drum by hand. If there is a grinding sound and it feels rough, the roller suppot bearings are suspect.
2) Belt tension assembly - Same test as 1 except if you hear the grinding sound but it feels smooth, check the tensioner roller bearings
3) Fan assembly - this can have bearing failure or get foreign objects in it. Access isusually via the back panel
4) Foreign objects - check for things like coins in the space between the front of the drum and the trim around the door opening
Sep 09, 2009 | GE DBSR453EBWW Electric Dryer
Prints crookedly
make sure roller is same height as other, then clean that roller with an eraser. have a great day please rate bama46, thank you
Aug 25, 2009 | Dell 924 All-in-One InkJet Printer
Paper jambs in the feed. The right side seems to pull down first then just jambs up.
Solution: Remove foreign objects from Rear Tray MP210
Remove foreign objects from Rear Tray When printing, if there is any foreign material (such as a piece of metal or a pencil) in the printer, the printer my be damaged. If there is any foreign material, remove it at once. Follow these instructions to remove foreign objects from the Rear Tray.
  1. Power the printer off.
  2. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder. (If there is any foreign material, remove it by hand or with tweezers.)
Open the scanning unit (printer cover) and confirm that there is not any foreign material in the printer. (If there is any foreign material, remove it by hand or with tweezers.)
Note : After confirming that the scanning unit support < 1 > is fixed into position, release your hands.
Caution: To prevent injury or damaging the unit, avoid touching the inner parts.
  1. Close the scanning unit (printer cover).
    Caution: Be careful not to pinch fingers when closing the cover.
  2. Power the printer on and confirm that the printer operates normally.
    Note: If you cannot remove the foreign material in the above procedure, the printer may require servicing.
And
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the Printers folder.
    - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
    - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
    - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
    - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
  2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
  3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  1. Remove all sheets of paper from the rear tray, then click 'OK'.
  2. Confirm the following message, and click 'OK'.
  1. Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
6efb7a7.jpg After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
Note: The following message is displayed when the paper is fed and ejected.
  1. Click 'OK'.
Roller Cleaning is completed.
Cyber Kaka
Dec 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Every time i switch my printer on i get this message: "Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes, turn the printer back...
there may be some paper fragments in the roller assembly..one trick..turn off the lights, close the door, and use a pen light to peer into the usually dark and black area..the paper will glow brightly if it is in there..
the print jobs are usually located on the lower right tray, behind a right click on a printer manager icon
Oct 13, 2008 | Office Equipment & Supplies
Printer will not take paper, makes noise but will not take
check if the rollers (that pull the paper inside are moving).
Oct 20, 2007 | Canon PIXMA iP90 Mobile Printer
Epson RX595 Photo All-In-One Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
