Sharp AQUOS Blu-ray Disc Player Logo
Posted on Nov 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It shows "Incompatible Disk" on both Blu-Rays and regular DVD's --- some play and some don't. You just can't ever tell.
Anonymous
Level 3:
  • Master 405 Answers
  • Posted on Nov 15, 2009
Anonymous
Master
Level 3:
Answers
405
Questions
Helped
233881
Points
1272
Hopefully,it still under warranty, looks like disc drive is going bad, repair would not be economical outside warranty sins drive cost more the new machine
1helpful
DVD player won't show the picture and says F750 on display what should I do To unblocked it?
DVD player won't show video ' Apple Support Communities
discussions.apple.com > Support > Apple Support Communities
AppleHi sany42 welcome to the forums. You don't say which MacBook Pro you are using. Which graphic chip is running? Do you use third party software to manage ...
DVD Player not showing picture. ' MacRumors Forums
forums.macrumors.com > Macs > Mac Apps and Mac App Store
May 1, 2010 - Hey everyone, My DVD player application is not showing the picture. ...wttheninja said: ? ... So it seems DVD Player won't show a picture when my macbook pro is connected to my 30" Dell monitor via display port cable.
Mac's DVD Player won't show the image? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Dec 29, 2010 - When I put a DVD in my computer, DVD Player starts up and the DVD starts ... I can select things on the main menu, but the picture isn't showing.
db:: 3.91::Blu-ray player does not show picture ca - Hivmr
www.hivmr.com/db/jmcpaz9zsspf7s3m9zxfcs3383kma1sk
Still blu ray does not play says, Blu ray not set to region, but could play other blu rays from ... DB:3.66:I Just Brought Blu-Ray Disc/Dvd Player (Bdp-Bx59). ...... Help Request: My Blue Ray Disk Player won't "play", once the main show was to start. ....DB:3.36: How Do I Watch 3d Blu Ray Movies On Qosmio F750-1013x? 33.
2answers
No disc message from player
Blu Rays are more complicated from a information point of view--you most likely have either a dirty or bad (failing) optical pickup in the player--this always shows up first with blu rays.
My samsung blu ray home theather does not play blu ray dvd''s, first time that i used it, it did played like for 10 min long, but then the image stoped and did not wanted to play any more, i t
Players often when the optical pickup in them is either dirty or beginning to fail will first have problems with blu rays because of technical standards are much more refined for the blu rays.
2answers
It does not play the newer blu rays
Hello, A Blu-ray disc cannot be read on a regular DVD player unless it specifically says it can. The reason is the DVD player does not have a BLUE Laser assembly installed in it. Some newer blu-rays are backwards compatible and can read DVD's, but not the other way around! You will have to purchase a BLU-Ray disc player to see these newer discs.
Good Luck! Rich Lilja
I have Power DVD DX that came installed with my Dell. It has worked with my BluRays in the past, however how it continually tells me that I require an update. When I click to download the update, it says...
Some new Blu rays require a rom update. Try going to the drives manufacturers web site and get a rom/bios flash to update the drive. Blu rays are updated that way when new Blu rays come out such as AVATAR. Lots of info about that on the web.
Want to unlock to use all region DVDs
Australian and U.S. televisions have different amounts of pixels and are incompatible.
Cheers, Timo.
1helpful
2answers
PS3 will play blu-rays just fine, but not DVD
A bad laser could affect the sound cause it can't read all the information from the disc. Try games as well and see if it does the same thing, sounds like a new drive is in order. There is one laser in those drives and require different strengths to read different discs. Also try a music disc that you know is good. If your still getting the same issue then get the drive replaced or just replace the laser if you have some technical knowledge.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
