Question about Kenmore Washing Machines
The lights in my house flicker when I use my washing machine.
  • 585 Answers
The washing machine is not at fault for this. You should consult with a qualified electrician to find the problem with your electric service or house wiring.
Posted on Nov 15, 2009
When I on the machine LG WF-F5700PCX ,all the lights are blinking. water is not flowing in.
Washing machine all the lights flashing, error codes on ...
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - In this video I'll be showing how to fix a washing machine with all the lights flashing and how to identify error codes or fault codes on Hotpoint, ...
Washing machine lights flashing - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - Flashing lights Many modern washing machines display error codes if they detect a fault, but they don't all display a readable error code.
Flashing Lights on Washing Machine How to Repair ...
? 8:05
https://www.youtube.com/watch?v=P6WZNLO6wE4
Oct 22, 2014 - Uploaded by how-2-repair.com
Flashing Lights on Washing Machine How to Repair Hotpoint, Ariston, ... flashing like this.error faults are available at our website for all makes.
Indesit Washing Machine Repair: Flickering Or Flashing Lights
? 4:36
https://www.youtube.com/watch?v=S1L2N7srXKs
Mar 27, 2014 - Uploaded by DextersLab2013
Indesit Washing Machine Repair: Flickering Or Flashing Lights... Since making this video i have had to replace all of the remaining capacitors ...
Jan 11, 2016 | Washing Machines
Tip
How to reset the machine
Reset Procedure for Equator / Hirundo ( EZ3612CEE / EZ2512CEE / EZ1612V )
If the door of the machine is opening you can follow the below reset procedure so that the machine will function properly but if the door in your machine is not opening you need to first get the door to open by following the procedure as stated in the link http://www.fixya.com/support/r4240518-door_not_opening_in_equator_hirundo
Resting the unit will make sure that all the memory storage in the chip will be erased and hence the unit will be ready for a new cycle.
Reset Procedure
  1. Make sure that the machine is turned OFF.
  2. Make sure that the door is opening.
  3. Set the dryer & wash temperature knobs to the off position (12 o'clock / pointing vertically upwards)
  4. Make sure that the door is latched properly.
  5. Set the washer knob on the Red Reset position and switch on the power.
  6. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  7. Once the light starts flickering slowly turn off the power.
  8. Set the washer knob to the Green Reset Position and switch on the power.
  9. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  10. Once the light starts flickering slowly turn off the power.
  11. Set the washer knob to the Grey Reset Position and switch on the power.
  12. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  13. Once the light starts flickering slowly turn off the power.
  14. Set the washer knob to the Reset Position on Delay Time and switch on the power.
  15. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  16. Once the light starts flickering slowly turn off the power.
You have now reseted the unit and the unit should work fine now , in case you observe that the washer knob/Dial is going round and round all by itself now please go through the link for fault codes for further diagnosis.
Hope this procedure helps.
on Mar 02, 2010 | Washing Machines
Blinking lights
? 8:05
http://www.how-to-repair.com We are working on a tvm570 but this is usually the fault with most boards ...
? 4:36
In this video i remove the Computime control board on an Indesit WIXL163S washing machine where the front ...
Dec 02, 2015 | Washing Machines
Agitator not workng right lights flicker
The washing machine is probably not at fault for this. If it really were to have a problem of drawing excessive power, it would trip a breaker, and you didn't indicate any such problem. You probably should consult with a qualified electrician to find the problem with your electric service or house wiring.
Nov 28, 2009 | GE WWSE6260B Top Load Washer
Washing machine wont turn on
If the lights flicked when you tapped (hit) the fuse box or breaker box then the problem is in the box, not in the machine.
Jul 29, 2009 | Washing Machines
I have a Kenmore washing machine Model 82670110. It will drain the water but will not spin, it makes a very loud clicking noise when it should be spinning. Please help me know what to look for.
Is the clicking consistent with the motor cycling on and off (are the house lights flickering)?
If so, look for loose wiring at motor capacitor located inside the console.
If not, look for a broken motor coupling (connects motor to transmission), you will also have little to no agitation.
If the motor coupling looks ok, it could be the transmission (gearcase) that is defective. The transmission usually comes with a 10 year warranty so get it serviced.
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Severe drum? shaking and display lights flicker during spin cycle
Loose mounting points or broken pins. If not that then possibly drum shaft could be cracked.
Nov 10, 2008 | Indesit W 123 Front Load Washer
My Hotpoint 960 is 18 months old and has develped a fault where the mains light and programmer display flicker simultaneously, and the machine cannot proceed through the programme. It does not respond to...
Flickering lights might just be caused by loose wires in the mains plug on the machine's power cable. I would suggest checking that first - for some reason the neutral wire seems more likely than the others to come loose. There might be brown / purple marks around the terminal inside the plug if this is the case. Also try replacing the mains fuse in the plug.
While you are there you might also try plugging a normal table lamp into the socket you use for the machine - if the house cabling to the socket is defective the lamp should flicker too.
If neither of these ideas is productive, the problem would appear to be within the machine, so please ask again. Good Luck D.
Jun 29, 2008 | Hotpoint Washing Machines
My washing machine is tripping the circuit breaker
sorry to hear about the problem it will be your motor or module try online for recon both these parts are prone to go on bekos
Jun 14, 2008 | Washing Machines
Washing Machines Logo
43 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
