Question about Apple iPhone Smartphone
Proble with i phone home share it install both out`contact info what can i do
I pressed on accesability and did voice something and my i phone has wiered texture for it and not let me scroll down
Posted on Nov 16, 2009
How do I retrieve photos and contacts that "disappeared from my iphone 4?
Can you acces with program Recuva to your Iphone? that's for images..
As for contacts, do you have icloud?
or try this one : 1. Open message app - Pick a message thread which has a name.
2. Scroll up and open contact info. There was the contact.
3. Then select - 'share contact' - choose 'by message' - and send it to yourself.
4. Then you will recieve this message as 'attachment: 1 contact'.
5. Open it and then select 'add to existing contact'. When this opens you can see all of your contacts.
She did this three or four times and played around some more with different messages and suddenly by the fourth time you could see all the contacts through the contact app. This last bit is a little vague but at least by step 5 you can see that all your contacts are still in your phone somewhere. Play around after that and with a little luck someone can add the details of the last step.
Good luck - hope you can also save $99 buying software to do this for you.
or
Double tap home button
Hold down on an icon that appears on bottom of screen and close all running apps
Tap home button again
Power off your phone
Turn phone back on
Open contacts and they should be restored.
or
Feb 16, 2015 | Apple iPhone4 4G iPhone 4
How to connect my phone using Bluetooth
touch bluetooth app will pop up make sure bluetooth is on and in discovery mode after make sure you choose option on phone to connect and hit accept.. also can connect other bluetooth to your phone to share info pic and contacts... besafe... aka mia
Jul 31, 2013 | Cell Phones
How to install?
I don't think there is any rocket science behind it .I would like to advice you that just follow the instructions on the user manual .
If you still getting some problem call the service engineer .
fertile mind pty ltd
Jul 20, 2013 | Home Security
When i am trying to connect internet through my tata indicom prepaid usb modem sxc 1080 getting error 691. How to solve this proble?
Remove the modem and un-install the software. Then connect the modem to be detected once again and installed as a new hardware. Now enter the settings, user name and pass word as mentioned and log on. If this wont work then contact the Tata help center.
Apr 15, 2011 | Cell Phones
For key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install...
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose your o/s
now run it and presto......
regards, dean
Jan 08, 2011 | Keyspan USB Server US-4A (d47710) Print...
My nokia 3600 slide phone is not switching on. but when i tried to charge it shows charging display. What should i do? Some peoples says the its due to software problem, and can be repaired by flashing. ...
no this is not a software problem, the proble is with the on off power switch, it might e broken or come off the pcb, try shorting two contact with a tweezer phone will power on surely, you can also replace power micro switch at a service center or at home if you know little soldering.
Dec 22, 2010 | Nokia 3600 slide Cellular Phone
I have window 7 64bit and the keyspan software installed fine but the server utility does not recognize the print server. I allowed port 3842 tcp and udp through the windows firewall but still no luck.
for key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install windows virtual pc, start it up and insert a windows xp pro install disk. for info on this google 'workaround to install windows xp mode in windows 7 home premium and home basic') Once you have windows xp mode running, install the keyspan server utility int he virtual machine and setup as usuall. then share the printer. go to windows 7 devices and printers and add a printer, chose a network printer, select the new virtual machine and select the shared printer. In order for the printer to work just start up the keyspan program from windows 7 and print....your welcome.
Sep 08, 2010 | Keyspan USB Server US-4A (d47710) Print...
How to set up uverse home network with 2wire gateway
To use AT&T Uverse for a home network, you need to get the AT&T "Homeview" Network Management software. AT&T provided this software in the past freely.
This software must be run on each PC on your home network, and then each PC can see the others. You then use go to My Computer, select each disk drive you want to share, right-click and select Sharing and Security, and select to share the drive. Then go on the drive to the folders you want to share and right-click and set them to be shared. Then the Homeview system will show these are shared folders. You can also share printers on the same network using the Homeview software.
Jun 13, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Contact info on Blackjack won't sync with home PC?
you probably need to reload the drivers for your phone onto your computer.
Here is a link to the samsung download center. choose your provider and phone and click
http://www.samsung.com/us/support/download/supportDownMain.do
Once the drivers are loaded it should hook up and communicate with your phone.
Jun 01, 2009 | Samsung BlackJack II Smartphone
Please solve my problem its urgent and importante
hi
you can download driers here
http://in.lgmobile.com/web/web.support.manualRF.laf
but i sugest to you connect t with bluetooth....just buy cheap bluetooth device and paired your mobile with pc then make a dialup conection for your pc
May 04, 2009 | LG KG110 Cellular Phone
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
