Question about JVC DR-MV80B DVD Recorder / VCR Combo
I recorded from tv to dvd and cannot play back video
  • 127 Answers
Upload it to your computer, and check the file type, and possibly convert it to the correct file type and burn it to a DVD.
Posted on Nov 15, 2009
I have a DVD/VCR recording device and I need to hook up my camcorder to record videos to a DVD to submit to an organization for my son to receive a service dog. I can hook up camcorder straight to TV...
To record to the DVD, connect the A/V cables from the JVC GR-D347U to the A/V In on the DVD recorder. Since the DVD already plays to the TV, you just have to keep the TV set to that input. Put a blank DVD in the recorder. Set the DVD recorder to record on from the appropriate Line In (input) with the DVD as the target recording media. To make sure that all of the devices are on and receiving the output from the camera and DVD recorder, start playback on the GR-D347U and check that it displays on the TV. Forward the tape in the camera to the point where you want to record to the DVD. Stop playback. Press REC for the DVD recorder and restart your playback. Press stop for both the DVD recorder and then the camera when the desired video segment has been played back.
See page 21 of the manual for the GR-D347U. Treat the DVD recorder as a VCR for this situation. The manual is available here: https://www.manualslib.com/manual/82266/Jvc-Gr-D347u.html?page=21#manual .
I hope this helps. Please add a comment with the details of the DVD recorder for more information on connecting the unit in this daisy chain.
(Many recorders have at least two composite video Line In inputs. That's why you need select the correct one for recording.)
May 19, 2017 | JVC GR-D347U Camcorder
I cannot get the VCR/DVD to record from my tv. I have a satellite dish. The input from the dish receiver to the tv is HDMI1. The DVD receiver hooks into the AV1 inputs. I can set the timer, but nothing...
I have no direct experience but you should note no recording will take place unless the signal format is suitable/compatible. HDMI is a digital signal and your VCR/DVD will probably require an analogue signal.
A tv processes the digital into analogue but sockets at the back of tv sets tend to be input only. A minority of tv sets have two scart sockets, the second one usually providing an output sound and video of what is playing on the tv at the time.
I believe it is possible to buy a box that will convert digital to analogue or vice-versa.
Nov 16, 2017 | Philips Magnavox MWR20V6 DVD Recorder/VCR
HOW TO INITIATE SET-UP PROCEDURE FOR 2ND HAND VIDEO/DVD PLAYER
You should have the main aerial going into the dvd and then a black flylead going back into the tv.If you go into the on screen menu you find a set section so you can re-tune the stations.
Aug 17, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
How do I hook up my vcr to my dvd recorder so I
You will need one RCA video cable it will have a yellow, red and white plugs. On the back of your VCR locate where the color inputs are find where it says VIDEO OUT hook it up there. On the back of the DVD Recorder look for the same color input jacks NOW find where it says VIDEO IN hook it up there. You may have to turn on your TV,DVD recorder and VCR to get the right channel. your Recorder may have one or more video inputs if it does turn on all three. Use the channel on your TV you use to watch DVDs make sure you see your DVD screen. Now to record to a DVD. Change the channel on the DVD Recorder. Look for the input channels It may be Video 1 Video 2 etc... depends on the inputs you have. ( A great way to tune your DVD Recorder is to play a prerorded VCR tape. Turn the channel on your DVD Recorder unil you see the prereorded tape playing. )
Jul 21, 2009 | Toshiba Audio Players & Recorders
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Lost manual...I cannot get DVD or VCR to record
You need to decide which set of inputs or outputs you want to use. To record, and watch what you have recorded on your TV, you will need TWO sets of audio/visual patch cords. One for recording and the other for playing. Let's start with the recording. Look for the Line in or video in plugs on your DVD-VCR unit. Some recorders have separate inputs for the VCR and DVD. Others let you select with the remote. Usually Line 1 is at the back and Line 2 is on the front. Your remote will have "recording source" to let you select, or sometimes you can use the channel up and down arrows to select your input source. Your remote will also allow you to select either the DVD or VCR for recording. Connect the Yellow plug to the Video In socket, and the red and white plugs to audio in., Connect the other end of the cord to the TV or cable box. Yellow goes to Video Out, red and white go to audio out. Recording from the cable box is much easier because you wiull always have a signal going into the DVD-VCR recorder no matter what happens at the TV.  Now look for the Video out connection on the DVD-VCR recorder. Connect the Yellow plug to video out and the red and white plugs to audio out. Ignore the other connections at this point. They are for RGB component video. Your DVD -VCR should have one output for both functions. Use that one.
Now connect that cord to a Video one or Video 2 input on your TV.
Test the set-up. Play a DVD or a VHS tape and try to bring it in using the TV remote.
Then turn on a program and try to record it on  the DVD-VCR, then play it back.
This sounds very complicated, but all that's involved are two patch cords with three plugs on each end - 12 connections in all and color-coded. YELLOW is always video.
Dec 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Can't get picture to show up . .
You should be connecting video in of Dvdrecorder to video out of Tv.
Samir
Feb 29, 2008 | Lite On LVW-1105HC DVD Recorder
Playing back footage on pc
don't know u're cam, but usualy the camera haz to "close" the dvd sesion, so that the computer/dvd player .... to be able to play it ...
Ofecourse u can play the video on PC, using cd/dvd data recovery software, that accesses the data directly and not track based ... (that in the case that the dvd got damaged and the recorder can't finish it ...)
Feb 17, 2008 | Video Cameras
How to Record From a TV Using PV-GS13?
connect a lead via your tv video out audio out jacks. Select tha appropriate channel (You may have to go through the av channel on you tv and tune in the channel you want to record) or, video or dvd player audio out video out jacks. connect other end to your camcorder. Select on the camcorder menu video in audio in. Turn on tv. If connected to video or dvd player, press play. Press record on your camera. When finished recording press stop. Presuming the camcorder is tape, you can buy a tape adaptor to play or record your mini tapes in a standard video recorder, then take them out of the adaptor and play them back on your camcorder. You can also do all this via a computer. Also if the camcorder is disk or hard drive it can be used the same way as a regular dvd recorder to record tv programmes once connected to you t.v. Let me know how you go 26 red
May 08, 2007 | Panasonic PV-GS31 Mini DV Digital...
JVC DR-MV80B DVD Recorder / VCR Combo Logo
184 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
