Question about Apple iPod nano
Forgot the code to get into my apple ipod - Apple iPod nano
  • 4 more comments
  • geigelaa1920 Nov 15, 2009
    DO I HAVE TO BUY AN ITUNES CARD
    WHAT DO I NEED TO CONNECT TO THE COMPUTER.. THE ONLY THING THAT I HAVE IS THE IPOD. DO I NEED TO BUY SOMETHING ELSE
    I ONLY HAVE THE I POD WHAT DO I NEED TO BUY TO CONNECT TO THE COMPUTER
    I FORGOT MY IPOD ENTER CODE
    NEITHER I MOVED AND I THOUGHT THAT I DIDN'T WANT IT ANYMORE SO I PACKED IT AWAY. NOW THAT I SETTLEING IN I'M THROWING THINGS OUT THAT I DON'T WANT. I CAME ACROSS THIS I POD.
    IT BELONGED TO MY GRANDSON WHO DOESN'T KNOW WHERE THE PARTS ARE. THANK YOU
    Genius:
  • 3,422 Answers
HI,
Now there are 2 ways to fix this issue.
FIRST METHOD:
Connect your iPod to your pc
  1. Make sure you have enabled viewing of Hidden files and folders in windows explorer, if not Open Windows Explorer -> Tools (Menu) -> Folder Options -> View -> Show hidden files and folders.
  2. Open "My Computer" and then double-click your iPod device icon to open its file-system, now navigate to folder "iPod_Control" -> "Device" folder.
4)You will see a file named _locked rename this to _unlocked, now to reset the password open the file in notepad and delete all contents in it and save.
Now, Eject the iPod and reset it.Your iPod Screenlock is now disabled.
If you don't know how to reset ipod then here are the instructions:
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
SECOND METHOD:
If you are not an advanced pc user then you can use this method.But i highy recommend the FIRST METHOD To fix this issue.
Screen Lock only locks users out of the user interface. It does not encrypt data on your iPod. For example, if you use Screen Lock and then connect your iPod to a computer, you'll be able to manage music on your iPod with iTunes and access all data on it in disk mode (contacts, notes, and any other files you have stored on the iPod). This support document also provides additional information on locking and unlocking the iPod. According to Apple, if you have forgotten the code, you can unlock the iPod by doing the following:
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the iPod, which will erase all music and data."
Thank you for using fixya.
Posted on Nov 15, 2009
  • Apple Master
  • 13,433 Answers
Hi To remove the code from the ipod, you must restore it. How to restore your iPod: For Windows: 1. Make sure you've reinstalled the latest version of iTunes. 2. Open iTunes, and then connect your iPod to your computer. 3. After a few moments, it will appear in the source list in iTunes. 4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows. 5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are: Restore Option 1: Restore - Restores with same iPod Software version already on iPod. Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer. Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer. 6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore. 7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off. 8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time. IF YOU HAVE A IPONE OR IPOD TOUCH THEN YOUR IPOD NEESD TO BE SET INTO RECOVERY MODE - http://support.apple.com/kb/HT1808 The above page has the instructions for that. Thanks, Ekse
  • Ekse Nov 15, 2009
    sorry, my message was turned into a big pile of text, let me re-write that.
    For Windows:
    • 1. Make sure you've reinstalled the latest version of iTunes.
    • 2. Open iTunes, and then connect your iPod to your computer.
    • 3. After a few moments, it will appear in the source list in iTunes.
    • 4. Select your iPod in the source list and you
      iTunes windows.
    • 5. Click the Restore button. You will be
      • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
      • Restore Option 2: Use Same Version - Restores
      • Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
      • Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
    • 6. A progress bar will appear on the computer
    • 7. During the stage 2 of the restore process,
      display may be off.
    • 8. After stage 2 of the restore process is
      the first time.
    Thanks,
    Ekse
  • Ekse Nov 15, 2009
    YOU NEED THE CABLE BETWEEN THE COMPUTER AND THE IPOD, IF YOU DON'T HAVE THE CABLE, DID YOU STEAL THE IPOD? RETURN IT TO THE OWNER OR TAKE IT TO THE POLICE.
  • 14 Answers
SOURCE: forgot screen unlock code
For those forgetful people
all right guys i have a solution for this but it will require some work first:
  • Mount the nano (plug it in)
  • Navigate to X:\iPod_Control\Device\ (where X is the drive letter of the iPod)
  • Find the file called "_locked" and open it with Notepad or TextEdit
now u should get some thing like : Vôáijåö\féúPbíþT~ñâHzõæLvùê@rýîD as the text but its not that con fusing to show here are two diffrent codes
the same!
]óãhjåö\féúPbíþT~ñâHzõæLvùê@rýîD
so in fact the part that matters is the first 4.... and its a 4 digit code!!
soooo i have made a guide line.. for u to match up your code with
0000
^ðàk
1111
_ñáj
2222
\òâi
3333
]óãh
4444
Zôäo
5555
[õån
6666
Xöæm
7777
Y×çl
8888
Vøèc
9999
Wùéb
now how does this help ?? well i set my code as 1234 and this is what the first 4 digits were: _òão
if u look at the first one and compare to the guide it shows that the first digit is 1 the second 2 the third 3 and the last is 4! taaa daaaa!!!!
Rock on people hope this helps!!!!
~Thimolas the awesome :P
Posted on Mar 11, 2009
  • 14 Answers
the same!
0000
^ðàk
1111
_ñáj
2222
\òâi
3333
]óãh
4444
Zôäo
5555
[õån
6666
Xöæm
7777
Y×çl
8888
Vøèc
9999
Wùéb
oppps!! forgot to mention that eagle btc helped me find the folder...... the little bit at the begining was from
http://forums.ilounge.com/showthread.php?s=&threadid=118446&highlight=combination+lock
SOURCE: forgot my pass code to my apple ipod touch 8g
just type in random codes till u get it right
Posted on Apr 19, 2009
  • 699 Answers
SOURCE: HELP i forgot my apple ipod toches password and it
You will need to do a 'Hard reset' !
This is how the the procedure goes for the ipod touch:
- While plugged into ITunes, Hold down the power and home keys down for 10+ seconds. - - Screen will go black
- Release the power button but keep holding the home key until itunes says 'We have detected an itouch in recovery mode'
- Restore as normal via iTunes
Hope it helps!
Posted on Dec 24, 2009
hunter19_46m
  • 7482 Answers
SOURCE: 8GB APPLE IPOD
According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes. When you disconnect iPod from the
If you can't unlock IPod using either [the code or connecting it to the
to your iPod.
If you want to change the primary computer that your IPod is associated
with, do this:
computer.
IPod, which will erase all music and data."
Good Luck, I hope this helps
Please do not forget to rate me...Thank You
Posted on May 26, 2010
I have an apple 8gb ipod and i forgot my pass code
Plug it into your computer and launch iTunes to reformat everything.
Feb 04, 2010 | Apple iPod touch
I locked my ipod and i forgot my code for it and i
get in touch with apple and they will reset it for you
Jan 26, 2010 | Apple iPod touch Second Gen (8 GB,...
Forgot my pass code to my apple ipod touch 8g
i entered in my pass code and went on a vacation with out my ipod and forgot my pass code. is their somesort of universal code to enter to unlock my ipod? pllzz help me!!!!!!!!!!
Apr 18, 2009 | Apple iPod touch
Forgot code to my ipod nano
PLUG IT INTO THE COMPUTER AND RESTORE FACTORY SETTINGS
Apr 09, 2009 | Apple iPod nano
How to screen unlock my apple ipod ?. pleace tale me the code.
If you have a code to input then it will be one that you put in. If you cannot remember it or do not have it, then download the latest version of itunes from apple.com and plug your ipod into the computer. Then click on the ipod image on the left hand pane of the screen and when the ipod page opens choose to retore, this will take the ipod back to its original settings.
Jan 31, 2009 | Apple iPod nano
How to unlock my ipod
Plug the iPod into your computer - it will unock.
Aug 18, 2008 | Apple iPod touch
I for got my code and cant unlock
my friend sold me a ipod and the screen got locked and he forgot the password
Dec 14, 2007 | Apple iPod MP3 Player
Apple iPod nano Logo
21 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
